Question about Maytag Dishwashers
I need to unplug and move a built-in Maytag dishwasher
  • 5,911 Answers
Follow these steps:
1. Locate the electrical service breaker for your appliance and turn it off at the breaker panel. If it is plugged in by a serivce outlet, unplug the unit.
2. Turn off the water source under the sink.
3. Disconnect the drain line under the sink.
4. Remove the lower panel under the dishwasher door.
5. Locate the small electrical junction box under the dishwasher and disconnect the wires leads. Remember, standard household wiring is as follows: BLACK (HOT - 110-120VAC), WHITE (NEUTRAL - 0VAC, GREEN (or bare copper) is GROUND. Make sure you reconnect the wires in this fashion with wire lug nuts. If you have a local outlet plug you may leave the wiring instact.
6. Locate the fill valve (Usually on the left hand side of the dishwasher). This is where the water supply line connects. Disconnect the water supply line from the fill valve.
7. The dishwasher should have a couple of mounting screws located where the top of the dishwasher cabinet meets the underside of the cabinet.
8. With everything removed, the dishwasher should now be free and slide out from under the cabinet.
Let me know if you have further questions. I hope this helps you.
NOTE: You can also remove the water supply line at the fitting under the sink if it makes things easier.
Posted on Jul 25, 2008
The water does not spray inside, it does fill but does not spray thus the bottom sprayer does not move
check your rubber seals to sprayer from back wall of dish washer. if ripped or dried out need to replace them.
Jan 24, 2010 | Maytag MDB9750AWS Built-in Dishwasher
I have a Maytag MDB4651AWW3 dishwasher that stops during cycle
is it making a humming sound ,then the pump is blocked see if any thing is stuck under spray arm, worst could be is the motor unplug before working on it. thanks
Dec 01, 2009 | Maytag 24 in. MDBH950AWS Built-in...
Mdbh940aws - maytag dishwasher not woking
It might be a thermal fuse. Check this thread:
http://www.fixya.com/support/t545481-dishwasher_panel_no_power
May 30, 2009 | Maytag 24 in. MDBH940AWS Built-in...
Maytag Quiet Series 300 only goes to RINSE ONLY
Try unplugging the washer to reboot the computer board. Sometime power surges at night can cause undervoltage on the board and make it do funny things. Rebooting by removing power for 10 min will drain the board and start with a fresh program. This is true for microwaves, dishwashers, dryers, etc.....
May 08, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Mdb 6600aww
i need your serial num its important
Oct 19, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Leaking dishwasher
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
du256
Oct 12, 2007 | Maytag 24 in. MDB3700 Built-in Dishwasher
Flashing lights
Try unplugging for a minute. If this don't work it may need a board.
Sep 24, 2007 | Maytag MDB6658 Built-in Dishwasher
RE : The stray arm of my dishwasher won't move
In some machines the schematics are glued under the machine upper cover. I don't know for what purpose you are looking for the drawing, but in case you have a problem and you need for any assistance, let me know and I will try my best to help you with it.
Apr 19, 2006 | Maytag PDB3600A Built-in Dishwasher
Dishwashers Logo
111 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
