Question about HP Deskjet F340 All-In-One InkJet Printer
Cannot scan with hp f340
I installed the driver from online download, but I cannot scan, can you help me.
Raul.
  • Anonymous Aug 15, 2008
    I am trying to scan with a HP deskjet F340 all in one and it will not scan
  • 622 Answers
Here is a link to the scanner install walk-through... HP Deskjet F340... http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01585107&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=1128309&lang=en
Posted on Jan 06, 2010
Computer and printer quit communicating. Lost printer icon on desktop. How do i reload printer software?
    Follow these steps to install the beta driver for your printer: From the Apple menu, select System Preferences. Highlight any Epson printersand click the button to remove them from the Printers list, then click OK. Select the folder labeled EPSON and drag it to the trash.
    How to Uninstall and Reinstall Your Printer Driver - Epson
    www.epson.com/cgi-bin/Store/support/supAdvice.jsp?noteoid... Epson
Jan 27, 2016 | HP Deskjet F340 All-In-One Printer
Photosmart for 300 series
Depending on what operating system your running. You need to make sure your product is plugged in through a usb connection. Now if your computer doesn't find the product that's ok you just need it to be plugged in. then you need to download the proper drivers for it. For instance if your running windows 7 64 bit, you need to download the drivers making sure you have 7 64bit drivers. In this case you want to install the firmware update make sure you see a yellow smiley face after the firmware is installed to your F340 HP Deskjet F340 All in One Printer Drivers
Apr 27, 2012 | HP Computers & Internet
After getting Windows 7 I can't use the scanner button on my F340 aqll in one and I can't figureout the scanner feature on Windows 7
It sounds like you installed the generic OS driver from Windows 7. This driver only works for the printer. (Alternatively, you do not have the monitor program running or the destinations set in the HP software.)
If you plugged in the data cable before installing the HP software, uninstall the printer (Devices and Printers) then disconnect the data cable (USB). Go to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1128309& and select your Win7 version (32- or 64-bit). Then click Next. Expand the section marked driver and download the Full Software. Install the software. Connect the data cable when prompted to do so. (Try a new USB cable since scanning requires bi-directional communication with the printer and can fail when the printer works). Avoid using a USB hub or print server.
If you do have the HP software installed, check that the monitor program is running (Start > Control Panel > System and Security > Adminstrative Tools > Component Services > Services.) The line for the HP monitor should say started. You may need to download and install the patches or the diagnostic utility from the above site to find a specific problem with the Win7 installation.
Next launch the HP software and attempt to scan from the computer. Next use the settings that give good results to program the defaults for the scan destination buttons. Now try to use the scan buttons on the all-in-one.
Once you have the HP drivers for both the printer and the scanner installed, the Windows 7 Fax and Scan and Paint programs should let you successfully scan from the computer. (New scan for fax and scan. File > Import from Camera or Scanner > New Scan for Paint.)
I hope this helps.
Apr 24, 2011 | HP Deskjet F340 All-In-One Printer
I miss place my disk for my all in one hp f340
The drivers for teh printer can be downloaded online at:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&product=1128309&dlc=
Select te OS and start your download.
Please accept the solution if the onformation provided has been jelpful.
Jun 05, 2010 | HP Deskjet F340 All-In-One Printer
HP Deskjet F340 Printing, but not scanning. I have a MAC.
go to your mac hard drive on your desktop go to applications if you installed the drivers correctly you should have a hp folder if not I suggest installing the drivers for your os check your os version by clicking on the apple icon top left and go to about this mac, In the hp folder you looking for scan pro and you can use that for scanning
Jan 26, 2010 | HP Office Equipment & Supplies
I have a F340-all-in-one. Will not scan
i would suggest to download the software from hp.com
for this printer.. and then try to install..
note : download the full feature software only..
Oct 22, 2009 | HP Deskjet F340 All-In-One Printer
Hp f340 will not scan
Scanner: Hi there, " Unplug the Scanner cable from the computer. " Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the Scanner. " then you can connect the Scanner and and try to Scan.
Aug 18, 2009 | HP Deskjet F340 All-In-One InkJet Printer
I can scan, but can't print.
okay u need the installation disk or a copy of one at least it seems the HP download server has been corrupted i had problems on a reinstall NOV/19/08 when i allowed the install program to contact server for updates. when i chose not to contact server the program installed correctly and i have not had a problem yesterday or today try to download a torrent of the cda_Express file and use that as your installation disk. if u dont know what a torrent is read up online about them and then try to find your disk through utorrent or bitcomet both of those are programs used to download torrents. frostwire can be used for torrents as well pretty straight forward if you know a little about software and downloading. best of luck the only other solution would be to order a new installation cd
Nov 14, 2008 | HP Deskjet F340 All-In-One Printer
F340 issue
You need to uninstall any printer software you have installed. Reboot your computer and go to this site to download the Vista software.
F340 Vista Downloads
You can get the full feature software and driver or order a CD.
Nov 08, 2008 | HP Deskjet F340 All-In-One Printer
My hp all-in-one wont scan
First unplug the scanner and install the printer drivers from the hp website. If you all ready have the drivers installed reinstall them. Then go to the printers scan software and try it. If that fail go to start bar-control panel- cameras and scanners and set the printer up. If all else fails call hp directly and they will fix the problem.
Oct 11, 2008 | HP Deskjet F340 All-In-One Printer
HP Deskjet F340 All-In-One InkJet Printer Logo
244 people viewed this question
Ben Johnson
