Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
FDW40 My dishwasher has just stopped working mid cycle. The rinse and prewash lights are both flashing and the water will not drain away. I tried to empty the existing water out........put it onto a new cycle.......the water came in but again wouldnt empty.... Please advise
  • 99 Answers
This is a blocked pump,Strip down pump and remove blockage.
Posted on Oct 12, 2008
When the 'wash' cycle finishes, the machine stops at the 'rinse and spin' cycle, and the 'prewash' LED flashes.
Victor. The prewash flashing is indicating a water fill issue. Rinse uses cold water only. check for clogged inlet screen on the cold water valve, and check if there is a screen on the supply valve also. If the inlet screen is all clogged up at the valve on the washer, you can clean it with a little windex and an old soft tooth brush. gently brush away any sediment or debris. If no filters are clogged, you will need to replace the fill valve assembley.
Apr 10, 2014 | Hotpoint WMA50 Front Load Washer
Zanussi tempoline not working, son twisted nob mid cycle it then stopped and wouldn't drain. Now not doing anything! Any ideas? I assume its a error code flashing up
The first step of a dishwasher is a drain / rinse drain. I would turn the dishwasher off at the socket, turn the nob to the off position only turn this in a clock wise direction IE: the direction the nob would naturally move. Turn on back at the wall and start as you would normally. The dishwasher will empty the water out in its first step then should cycle through as normal.
Feb 08, 2013 | Dishwashers
Why did my quiet partner II whirlpool dishwash just stop mid cycle?
see this possible causes:
Water-heating cycle
heat, wash, and rinse has the 3 cicle, principal problem is the heat cycle, when the water reach the level ( by heating water elements) test the heating elements , most ot the time fixing this .the problem is o.k
Timer
sincerely. God bless you
May 04, 2012 | Whirlpool Dishwashers
My Dishlex Global 300 dishwasher stops mid cycle and the rinse light keeps flashing ?
I think I had the same problem. I don't know much about dishwashers, but the "Flashing Rinse" has something to do with the drain, or the drain pump (which is why the water doesn't drain).
My dishwasher stopped its cycle, after having filled up with water, even though everything else worked fine, because the drain pump was not even turning on. So I guess, the first question I asked was, is the drain blocked? No. When this happened the first time, the flashing rinse cam up. After that, the dishwasher just wouldn't drain, and there was no longer a flashing rinse.
So then, I figured, the drain pump is probably rooted. The drain pump is found underneith the dishwasher, just behind the front panel on the left hand side.You'll need to remove the metal covers from the front and the left.
When this happened to me, I thought I'd need to buy a new pump, so I pulled the other one out (its a bit fiddly, you have to disconnect the two electrical wires, then remove the drain pipe from it, and then wiggle it off. But when I got it out, I unscrewed it (it has the special hexagonal screws, not phillips or flathead), and it turns out, a fairly large fruit seed had got into the drain pump and blocked it, preventing it from spinning. I put it back together again, and it worked.
It so far has beaten paying $100 for a new pump.
If you want a visual of what the drain pump looks like, look up the dishwasher part number #8905912, you should be able to find it on the internet. Hope this helps.
Jul 29, 2010 | Dishwashers
Stops mid cycle often
Hi there, did you ever find out what was wrong with your dishwasher? I have a Westinghouse 904 doing the same thing but when we moved into this house the manual was long lost. Any thoughts would be greatly appreciated.
My email address is shaneane@clear.net.nz
Jun 02, 2009 | Westinghouse Dishwashers
Dishwasher not emptying
either the pump is not working or the discharge hose is clogged, if you have an air gap on the sink take the hose off and hold it down see if the water comes out by tself if so the pump is bad if not the drain is colgged take out the bottom tray you will need a 1/4 inch nut driver take the plastic screen cover plate off clear it of debris, there is a sharp metal blade in there so be careful, after cleaning it out turn on to rinse and see if it drains if not you will need to either replace the dishwasher or the pump, dollar for dollar new dishwasher time
May 30, 2009 | Westinghouse 24 in. MDB421 RF Built-in...
Motor starts but no water entering dishwasher
TRy priming by putting a jug of water in bottom of inside of dishwasher
Mar 04, 2009 | Westinghouse Dishwashers
Flashing lights on Hotpoint FDW20P Dishwasher
No solution! tried resetting to factory defaults but ended up that even the drain pump stopped working. after flooding the kitchen (nearly). I decided it was terminal and am loking for a new dishwasher urgently as I type. Cheers.
Feb 18, 2009 | Hotpoint 24 in. DWF32P Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
438 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
