Question about Lexmark Office Equipment & Supplies
I bought a Lexmark6500series sn# 01300030788 model#X6570 last Oct 7 /07 now I can not get ink colour or black and white for my printer Can you tell me why I live in Lindsay On Canada The place were I got said they couldn't order it any more Why sell them if you cann't gte the ink Please reply to my Question as I need both inks Tank You Dyann
I found a store about 35 miles from my home town that had some so I got them there for now Thanx Dyomyite
Posted on Jul 25, 2008
Lexmark x6570 print black on colour cartridge
In your control panel, devices and printers, click on your printer. you can make it print black from there
Apr 04, 2012 | Lexmark X6570 InkJet Printer
The printer in out of colour ink, and still wont print in black and white
Replace the colour ink. Some printers mix-in a bit of coloured ink, when printing "black", in order to prevent the colour-inks from drying-out.
Feb 17, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
What does it mean when it says change k cartridge
There should be four ink cartridges inside the printer: Cyan, Magenta, Yellow and blacK.
While monitors build colours out of three emissive (active) base colours, red, green and blue, printers usually build them out of four absorbing (passive) inks, so-called CMYK. The black is referred to by its last letter to avoid confusion with Blue.
On most printers, since they usually print in black ink over white paper (and black is used to darken all other colours), the K cartridge is either bigger than the others, or needs to be replaced more often.
Mar 31, 2010 | Canon imageCLASS MF8180C All-In-One Laser...
Printer is refusing to print colour, with full colour ink tank.
Have you checked the ink levels in your cartridges? Ink can dry due to usage and also due to prolonged non usage.
Apr 13, 2009 | HP LaserJet 1100 Printer
Lexmark printer x6570 unable to allign after putting in new cartr
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the black on the left........ Good Luck
Feb 01, 2009 | Lexmark X2470 All-In-One InkJet Printer
I cannot print but i have only the black cartridge but i dont have the yellow cyan ang midget
Most modern printers use some colour when printing Black and therefore will not print if ANY ink cartridge is showing as empty.
Unless your printer has a setting for using Black ink only (this is not the same as printing a black and white document), then you will need to purchase and install the colour cartridges before printing can take place. The good thing about this is that very little colour ink is used when printing black and white documents - so they should last a long time.
Good luck.
May 09, 2008 | Brother Multi-Function Center MFC-240C...
Printing in black & white when color cartridge ran out
One of the possible reason why you can't print black in white because Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. More than that Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head.
Apr 15, 2008 | Epson Stylus Photo 1280 InkJet Printer
Printing in black and white
the only way i got mine printing was to replace the colour ink! sorry
Mar 12, 2008 | Epson Stylus C46 InkJet Printer
Won't print black
I found a solution to the Black printing problem :)
Under Printing Preferences: Set your Media Type to Photo Paper Pro.
We used edible ink cartridges and printed onto icing sugar paper. Same old... Just one day it refused to print black. In order to continue our small business, I degraded the color until I printed gray and not black.
Tonight, I browsed for the problem and came across this :)
Hope it helps you too
Nov 22, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
