2008 Ford Escape Logo
Posted on Feb 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ext temp is reading wrong external temps on dash board display. exsample: 40 degrees outside. Ext Temp dash display reads -17 degrees.
Ahmet Gunduz
Level 2:
Sergeant:
  • Expert 280 Answers
  • Posted on Feb 14, 2011
Ahmet Gunduz
Expert
Level 2:
Sergeant:
Answers
280
Questions
0
Helped
78758
Points
829
Sounds like the sensor is playing up, your local dealer should be able to assist.
  • was ok but after factory reset no reads - 40 degrees
1helpful
What would cause my 2010 Ford fusion to read -40 on my ext. temp?,i live in Alabama?
A bad temperature sensor on the engine. When there is an open in the circuit it will read -40.
1helpful
06 rendezvous that the digital temp display for outside temp is wrong. The display reads 32 degree and it is actually 80 degrees so the A/C does not cool vehicle down. What is the problem?
Suspect a failure in the ambient air temp sensor. Has the vehicle ever been in a frontal collision? This sensor is normally located in front of the radiator assembly bolted to the rad support. If it is reading a cold temperature, it will not allow the AC to operate
I replaced my temp sensoe and it reads ccd
Hi Glenn, I'm glad to help! Here's how you check the Ambient Temp Sensor circuit itself to see if its working properly. Disconnect the Ambient Temp Sensor Connector. If the temp reading go to the default mode it will show 40 degrees. If it doesn't go to 40 Degrees then thyere something wrong with the system. Could be wiring or display itself. If it does go to 40 degrees then I'd try another sensor and see what happens. Hope this helps and have an awesome day Glenn.
2003 Saturn L300 AC reads OC EXT and blows ambient air.
I'm going to say the outside temp sensor is damaged or disconnected.
The body computer does not know what the outside temp is so the system is disabled. The sensor is probably in the grille area or behind the bumper cover.
How to use computer of average comsuption, average speed, ext temp ?
if my memory serves me right,if you zero all the readings before your trip then when you get to your destination you can read off the readings.thats it.(ext temp dont have a clue,except its ON permanently)
Air temp indicator only reads temps below 50 degrees
Ambient air temp sensor could be the cause. Normally located in front grille area.
2answers
Hi I bought a 2006 Ford Explorer it has a outside temp. readout on the dash board. The temp is off by 15 degrees higher. What can I do to fix it?
if it is reading wrong al the time , replace the sensor. if reads off after car is driven sensor might have been moved to a spot near something warm and needs to be put back
Reset Heating/ AIr cond temp display as well as EXT temp ????
the temp display can be switched between celsius and farenheit readings, since the car is from europe the default is celsius, The manual has instructions on changing back, You have to hold 2 buttons on the display per the manual.
5helpful
2answers
Misreading outside temperature sensor on 2001 Audi A4
There are four sensors for ambient tempurature and they work in unison to provide information to the temp reading on the dash, the heater control head ( where to direct air, blending of warm/cold/outside/inside air flapper controls) depending on the ambient temp and the inside air temp sensor located just above the radio as well as the sun sensor on the top of the dash as well as the a/c compressor head.
When you start your car, the body control module takes the readings from all sensors, outside air temp located in front of the radiator, air temp sensor located in the airbox ( senses temp of air being drawn in from the outside into the air box), coolant temp, inside air temp sensor and the sun sensor on top of the dash (this is why it takes a few seconds for the climate control system to begine when you start the car). The intake air sensor is 1st priority, inside air second, coolant third, ambient 4th and sun 5th. For instance, if the sun sensor reads the sun is hot but the interior sensor reads cold, the inside akes priority. The goal is for the system to achieve a tempurature inside the car that matches the selected temp. It uses all of the sensors to set the system up to achieve that goal as quickly as possible.
Example; Its mid afternoon, sunny and 40 degrees outside adn your in stop and go traffic. The intake sensor reads 40 degrees, the outside sensor reads 60 degrees (heat from radiator...engine heat protrudes into cabin) and the sun sensor reads high (sun is strong). The system is set for 72. priority one sensor reads 40, inside sensor reads 65, ambient reads 60= system will blow hot air to the floor out put, dash outlets will lightly flow 65 degree air so the sun doesnt roast you yet your feet are cold(if it blew hot air from all outlets, your upper body would be hot but your legs/feet would be cold). as the interior sensor reaches desired temp, air will be distrubuted through thee dash, defrost and floor with the warmest air coming out the floor and defrost, coolest air out the dash vents. Its a complex system!
The two sensors that will screw the system up the most are the intake and interior sensors. the system will function reasonably well with just those two sensors though it wont blend air temps between outlets if the sun sensor isnt working. If the outside sensor fails, it simply uses the intake sensor, if the intake sensor fails it will rely on the front sensor. However, since the intake takes priority over the outside sensor, if the intake sensor sends incorrect resistance info rather than failing, it will take priority and cause the unit to malfunction such as in your case.
The intake air sensor can be changed from the outside with patience. If it where me, I would pay the two hrs labor and let the dealer do it right.
Kevin,
Kevins Small Engine service,
South Berwick ME. 03908
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
