Question about Creative Labs Zen Touch MP3 Player
Sensor strip not working
All works apart from the sensor strip
  • notqytryt Aug 12, 2008
    I have the same problem. Ever=thing is working but the touch sensor
  • 65 Answers
When the touch pad fails, it is due to a hardware failure within the component itself. You will need to replace your touchpad/front plate component. Click here.
Posted on Aug 20, 2008
  • 55 Answers
The touch sensor wasnt made that sensitive that much so you may have to try harder to get it to work if theres still a probelm download firmware.
Posted on Aug 13, 2008
I have a Staples SPL-TXC15A shredder that doesn't start when paper is inserted. The power light is on and it runs in reverse but won't start when paper is inserted.
You need to change the direction or travel switch. Auto will only work when the direction of travel is into the bin, but you probably know that. There is an interlock on it. Use a vacuum cleaner crevice tool and then the brush attachment on both sides of the head. If that doesn't work, my guess is that the forward reverse switch is faulty. You would need to strip it apart and check with a meter.
Jan 03, 2017 | Kitchen Appliances - Others
Permanent press cycle keeps shutting down and doesn't finish.
Hello. I don't know what make/model dryer you have but the problem could be with load size and type of clothing. The sensor bars are usually located on the front of the lint screen housing(you have to put your head in the dryer and look back to see them--they are 2 metal strips, approx 1/2" apart and at least several inches long). The damp/wet clothing keeps shorting across the strips, telling the main board to keep the dryer running. If there isn't enough of a load, the dryer may think that the clothes are dry prematurely and count down too quickly. The sensor bar technology *is not* an exact science--it works best on large loads with like clothing. For smaller loads, use time dry and adjust the temp setting accordingly. I hope I helped you.
Aug 22, 2015 | Dryers
Rear winshield wipers won't work
Sounds like you have a stripped arm or the linkage has came apart in the rear for the rear wiper.
The sunroof? I am not sure. check fuses.
Dec 28, 2011 | 2006 Land Rover Range Rover
Dryer shot off
Try cleaning off the moisture sensor bars. (two 1/4 inch wide, about 5 inch long metal strips about an inch apart inside the dryer, near the lint trap.) These strips can get coated, often times from waxy residue from fabric softener sheets, and then no moisture is detected, so the dryer thinks clothes are dry, and after a short (5 minutes) cool down, it shuts off. If you use the manual / time dry, dryer should work fine even if the sensors are coated.
Apr 16, 2010 | LG DLE2514 Electric Dryer
The dampness sensor on the ge profile gas dryer is off - is it possilbe to reset and turn back on?
The dampness sensor is just the two curved metal strips (about 5 inches long, and about an inch apart) located very close to the lint filter. (stick your head in the drum and look back down to your right) These strips can become coated with a waxy substance from fabric softener sheets which prevents them from detecting the moisture correctly. Just clean them off with a little soap solution.
Nov 04, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Okay ihad to take the computer apart to put the
There is a small cable that leads from the power strip to the motherboard. If that came unplugged, the motherboard will not get the signal from the power button. Pull the keyboard and power strip back off and check for connection at the power strip and motherboard.
Oct 07, 2009 | Toshiba Satellite A105 Notebook
My speed odometer stopped working and it won't shift out of first gear, is it the speed sensor, or what?
The reason the speedometer stopped working would be the speed sensor.
Sounds like the vehicle speed sensor is not working or the gear on it is stripped. If you look at the rear housing of the transmission, you will see a black plastic sensor protruding from it with a two wire connector and the speedometer cable attached to it. The sensor might be coming apart or the gear that is driven off the output shaft is stripped. The speed sensor, along with the governor, tells the transmission when to shift. You can remove the sensor by simply taking out the bolt that holds it in. A small bracket around the sensor is secured by this bolt. Carefully look at the nylon gear to see if it is worn through the middle.
Thank You for using Fixya.com
Jul 28, 2009 | 1997 Oldsmobile Cutlass Supreme
Ford 1991 super duty speedometer stopped working and transmission wont shift
Sounds like the vehicle speed sensor is not working, or the gear on it is stripped. If you look at the rear housing of the transmission, you will see a black plastic sensor protruding from it with a two wire connector and the speedometer cable attached to it. The sensor might be coming apart or the gear that is driven off the output shaft is stripped. The speed sensor, along with the governor, tell the transmission when to shift. You can remove the sensor by simply taking out the bolt that holds it in. A small bracket around the sensor is secured by this bolt. Carefully look at the nylon gear to see if it is worn through the middle.
Jul 22, 2009 | 1999 Ford Super Duty F 450
Rear LED strip light not working
hi I have got the same problem , did you find a solution, i would appreciate some info. model is 2005 continental GT
Mar 10, 2009 | 2007 Bentley Continental GT Coupe
Dyson Vaccuum Cleaner
Hi.
If you need to strip the Dc05 right down try this site http://dysonmanuals.llc.nu/
Has manuals on how to strip machine down.
Jul 15, 2008 | Dyson DC05 Cylinder Bagless Canister...
Creative Labs Zen Touch MP3 Player Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
