Question about Andis Outliner II Hair Trimmer
Botton don't work on trimmers - Andis Outliner II Hair Trimmer
  • 62 Answers
Please send your trimmers into the Andis Co at 1800 Renaissance Blvd Sturtevant WI 53177. We will be able to repair your trimmer for you. If you would like to speak with a customer service rep first please call 1-800-558-9441.
Thank you,
Posted on Jul 30, 2008
Feeds line constantly
String wound wrong way or bump botton shot.
Jul 12, 2014 | Black & Decker 14" Grass Hog Xp...
I don't how to set the timer. please help.
keep central heat off (botton on left push down botton on right push all the way up. Turn dialclock wise and either push in the little white button or pull out the "advencor". that button works the speed of the dial by turning it also
Mar 11, 2013 | Heating & Cooling
When i press power botton half way works when i press full sometime work sometime don't
the switch is bad and would need replaced. MAKE note of the wiring if you attempt to do this yourself. Get back to me with the brand and model number and I will try and find you a parts source and breakdown.
Jan 24, 2012 | Drills
What ratio of oil and gas do I mix together? How do you start it? I bought the weed eater used.
If you bought it used, you can bet that they didn't run it out of fuel before they stored it, so the gas evapoated out of the carb and all that was left was oil, so mix your fuel 8 to one eight parts gas and one part oil, you'll have to hit the primer botton several times.
Jun 16, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
My battery will not keep a charge it don't last 10 minutes/ i like the weedeater but it just don't last long enouh
I had one of these a while ago, the batteries are just cheap. Trimmers also use a lot of energy and battery powered ones aren't the best way to go if you want them to run a long time. I highly recommend replacing it with a good gas or plug in model from your local hardware store, they can help you find the right one to fit your budget. If you don't want to get a new trimmer you are going to be fighting dying batteries every year.
Jun 06, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
I used my Worx trimmer successfully last season. This spring when I went to use it, it would not hold a charge. The light shows green on the charger but the trimmer only works for about a minute before...
Your battery is shot. I had one of these, the batteries are really cheap and don't last long. If you can afford it, ditch the Worx and buy a quality trimmer at your local hardware store. If you are short on cash you can buy new batteries online.
Clippers dont work at all, don;t cut hair and the dog hair is trapped
A reason your trimmer may not work is that the hair is trapped inside the trimmer and not allowing it to function properly.
Here is a link to a video to cleaning hair clippers.
If the problem persists, then you most likely burnt up the engine in the clippers and there is no easy solution other than buying a new trimmer.
May 02, 2011 | Wahl 8550
Gas mix ratio
Use a good oil for two cycles, and a 50:1 mixture will work fine. If the grass really is that high, you may consider two passes. Coming from the top down with the engine reved high is better for really tall weeds rather than a sweeping motion at the botton which you'd normally do.
May 29, 2009 | Husqvarna 28cc Gas Line Trimmer
Andis Outliner II Hair Trimmer Logo
Top Andis Health & Beauty Experts
Anglia Clipper...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
