Question about Durabrand DWT2405 24" TV
Low Volume from headphone jack...
I am using a small 4 ohm remote speaker plugged into the headphone jack for private listening in bed and the volume is sometimes very soft...even at full volume. The extension wire for it is about 20' long and is 16 gauge copper wire.
My question is: Would using a different 8 ohm speaker increase the volume if I used that instead in the headphone jack???
Thanks
PC
Morris, IL
  • nrthwds Jul 24, 2008
    Thank You for your quick reply.... I thought the model # was included.
    It is a Durabrand Model DWT2405 24"TV with mono headphone jack.
    Thanks
    PC
  • Jaime Hernandez May 11, 2010
    What is the model of your TV?
    In some TVs the volume control for the headphones is not the same that controls the speakers.
  • 2,334 Answers
I do not think that this TV does not have a separate circuitry with its volume control for the earphone. If your earphone is mono, are you using a plug that is mono to connect the speaker?
Try using AWG 20 if you could to see if that helps.
Good Luck.
Posted on Jul 24, 2008
What ohm and watt speakers can I use with a craig CM402 cd am fm player? It came without them
Speaker requirements are likely to be 8 ohm, most modern hi-fi speakers are. A few low-fi systems have used special high impedance speakers and the old hi-fi standard for valve amplifiers was 15 ohm and 3 ohm or lower has been used in televisions a lot.
4 ohm speakers are commonly used where a higher power output is desired at the cost of some quality of sound reproduction but depending on how the sound is listened to can soon overload some amplifiers primarily designed for 8 ohm as it will try and deliver more power into the lower impedance speakers and perhaps exceed the rating.
8 ohms is a safer choice. The lower the wattage rating of the speakers the more efficiently they tend to be able to reproduce sound at low volume levels so for background music in a small domestic environment the average power requirement will be in the order of half a watt so even with a high powered amplifier the volume would rarely be turned up above 1 - 2 on the typical scale of 10 and ten watt speakers would be more than adequate. It is unfortunate that it is almost impossible to obtain quality speakers rated at such an unfashionably low power rating.
With the stiffer cones of a higher power rated speakers the volume has to be turned higher before the speakers become efficient and listening at low levels can be difficult. In a domestic environment a 50 watt rating is perhaps the best compromise as if there are neighbours to consider a ten watt average power output will be sufficient even if the amplifier is capable of higher powers. Just don't turn the volume up more than necessary.
The greater the power rating the more power will be required for efficient reproduction. For electrical and mechanical safety of the speakers the rating should exceed the maximum output of the amplifier but listening at low levels with quality of sound can become virtually impossible.
It is all a matter of taste and environment.
May 30, 2016 | Craig CD Shelf System with AM/FM Stereo...
Four weeks ago I bought an iPod Touch 32GB. After listening to my iPod on an external speaker I tried using the headphone and the sound is just too low. I thought my headphone was damaged but I tried it on...
Sounds like plugging the external speakers in has damage the spot were the headphones go in. If this is under warranty that bring it to apple store.
Jan 19, 2011 | Apple iPod touch
Intermittent audio...picture fine
Does this model have a headphone jack? If so, plug a pair of headphones or external speaker into the jack, turn the volume to an acceptable listening level and see if the problem goes away. If so, the headphone jack may be bad.
Mar 02, 2009 | RCA E09344 Under Counter Kitchen TV 9"...
No sound through the headphones
The way the headphone jack works is:
plug your headphones in and then mute the television using the remote.
While the TV is muted you can still use the volume up and down controls to adjust the volume through the headphones. I find that having the volume at 60-75% is more than loud enough on the headphones.
Just be careful when you unplug the headphones and take the TV off of mute, if your volume levels are still turned up you will be in for a jolt :)
Jan 10, 2009 | Dynex DX-LCD37 TV
Headphone Jack on Envision LCD TV
just bought a coby tf-tv2617 our cable company uses a unilersal remote ur2-cbl-cv02 where can i find the code to make them work
Dec 26, 2008 | Televison & Video
There is no sound on my computer
1. Open Device Manager by clicking the Start button , clicking Control Panel, clicking System and Maintenance, and then clicking Device Manager.‌ If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
2. Expand the Sound, video and game controllers category. If a sound card is listed, you have one installed. If no sound card is listed, You will need to install one.
3. Right-click the name of the sound card, and then click Properties.
4. Click the General tab, and then look in the Device status box to identify problems with the sound card.
• Make sure your speakers are plugged into a working power source and turned on.
• Make sure your speakers are correctly connected to the computer.
On your speakers, find the cable that plugs into your computer. Make sure that the speaker cable is plugged into the speakers and the correct jack on the computer.
• Make sure that the speaker volume is not muted or turned down too low.
1. Open Volume Control by clicking the Start button , clicking Control Panel, clicking Hardware and Sound, and then, under Audio Devices and Sound, clicking Adjust system volume.
2. Under Main Volume, move the slider up or down to raise or lower the volume.
NoteSome mobile PCs have an external volume control on the outside of the case. If you're using a mobile PC, check the external volume control. • Make sure your headphones are not plugged into the line out (headphone) jack of your sound card or computer (unless you want to be listening with headphones rather than speakers). When you plug in headphones, most computers automatically cut the sound to the speakers.
thank you
Dec 23, 2008 | E-Machines eMachines Desktop PC
Logitech z4 speakers
turns out, you can just plug into the headphones plug and just restart the program you want to listen to and the music blasted through the speakers. worked liked a charm.
Mar 29, 2008 | Audio Players & Recorders
Headphone jack is weird...
HAVE YOU TRIED THE BEST QUALITY HEADPHONES LIKE SONY AND DID YOU CHECK YOUR COMPUTERS VOLUME?
Mar 25, 2008 | Logitech Z-5300 Computer Speakers
Headphone volume?
Unfortunately, I believe this is by design. The knob does not control the volume of the headphone jack on those speakers. The best you can do is set the volume control in Windows so that the headphone volume is acceptable and turn the knob up higher for speaker listening.
Mar 07, 2008 | Logitech X-530 Computer Speakers
Durabrand DWT2405 24" TV Logo
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
