Question about Amana Refrigerators
Refrigerator not cooling but freezer works - Amana Refrigerators
  • 1 more comment
  • Anonymous Aug 31, 2008
    Freezer seems to work fine, but refrigerator is not cooling. We cleaned the bottom and rear vents and coils as suggested in the manual, and made sure all vents inside the freezer and refrigerator were clear (there was some frost on the freezer vents). Turned the unit off for 5 minutes to see if it was stuck in defrost mode. No luck.
  • dave wright Mar 12, 2009
    I had to replace the the defrost timer in order to fix the problem.
    DW
    DW
Make sure the vent coming from the freezer are also clear. Clearing only the vents to the refrigerator part is only half the problem.
Posted on Mar 10, 2009
  • eliminator20 Mar 10, 2009
    Your fan from the freezer to the refrigerator section may need to be replaced if the vents are clear.
Freezer working ok, but the refrigerators not working
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 05, 2011 | GE GDS18LBR Bottom Freezer Refrigerator
Fan in freezer area does not turn on, refrigerator no cooling, freezer works fine
heatman101
Jan 18, 2011 | Kenmore 20.6 cu. ft. Top Freezer...
Freezer works, it's cool nolt cold in the refrigerator, fan motor doesn;t seem to be working
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 19, 2010 | Roper RT14DKX Top Freezer Refrigerator
EL7ATRR Refrigerator: Freezer working fine but fridge not cooling...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
May 17, 2010 | Whirlpool EL7ATRR Refrigerator
Freezer working - refrigerator not cooling
heatman101
dtiurt7
Oct 27, 2009 | Maytag MZD2766GES Side by Side...
Hotpoint htr17bb Top Freezer Refrigerator Freezer working, but refrigerator not cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 06, 2009 | GE Hotpoint® HTR17BBSL Top Freezer...
Not cooling but freezer works fine
heatman101
Jan 24, 2009 | Kenmore 50522 / 50524 Side by Side...
Not cooling refrigerator part
heatman101
fgjkgd
Dec 03, 2008 | Roper RT21SKXLQ Top Freezer Refrigerator
Top refrigerator part not cooling, bottom freezer and fan working
heatman101
Nov 26, 2008 | Amana ABB1927DE Bottom Freezer...
Open Questions:
Mullion heater connection for Amana 84" Integrated bottom mount refer model B136CAR3 mfg P1318402W. I need to hook up the mullion heater that is under the freezer, component P/N 12401301. But I cannot find the mullion heater connection point. According to the specs it's installed in the foam and not wired from the factory and is for service purposes. The reason for this is that the water from the defrost cycle re-freezes and clogs the drain hole. Eventually the ice gets almost an inch thick and it's SOLID. The freezer drawer cannot open, so I have to thaw it all out and pry it open. I've done this dozens of times over the years! The service tech never figured it out. But with help of my boat-refer-expert brother we found the solution at the high level. Devil is in the details. According to the instructions: make a slit and peel back the white vinyl harness sleeve that goes to the water valve, pull out two wires (black and white) that aren't connected to anything (yet). Then "locate the mullion heater leads at the left side of the cabinet and connect to the back and white leads". Then Wrap vinyl sleeve with electrical tape to seal the slit. OOOOOKAY.... I found the unconnected leads in the harness that goes to the ice maker water valve. They have male bullet style plugs and clips (a little corroded) but I cannot find anywhere to connect them... Is left side of the cabinet as viewed from the front or back? The main harness is on the left rear area. And if I make the slit long enough (which is very difficult, then the wires could make it back there. If I only could find where the mullion heater's connectors come out. Of course the wiring diagram only shows the mullion wiring as optional and not connected to anything. I really do not want to lay this 500lb (at least) beast on it's side. It already fell on me and my daughter, but a countertop and pallets save us. This refer has been nothing but a pain to deal with ever since I bought in 2001. I don't want to get rid of it, since it has custom wood panels that go with our kitchen, and I fell on hard times (due to illness) and cannot afford a new one. It fixed many things on it already. Such as the problem where the relays weren't soldered properly onto the main logic board, which fixed the non-defrosting problem and the freezer fan not working. But now the drain hole plugs with ice. So I read that many freezers have a 5W to 20W heater that runs all the time to keep the hole from freezing. Especially if water gets in the insulation under the floor of the freezer. Anyway, can anyone tell me how to find the connections to the mullion heater? Is it in the outside-rear channel up back of the refer? it's pop-riveted on. Thanks! Scott
May 12, 2017 | Amana Refrigerators
Refrigerators Logo
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
