Question about Onkyo TARW255 Single Dual Cassette Deck
Cassette Recorder play problem
Cassette player turns off within about 2 sec's after inserting a cassette to play. Rewind and FFWD stop also after about 1 to 2 seconds. When pushing button to play it turns back off right away. Cassette player turns off within about 2 sec's after inserting a cassette to play. Rewind and FFWD stop also after about 1 to 2 seconds. When pushing button to play it turns back off right away. Haven't taken any steps yet but this
    Master:
  • 382 Answers
Belts are prone to harden over time,the belt will be broken so replace it.. Also as you say the unit does turn off which is the problem of Take-up reel sensor ..Try to Take to any Service person and replace it,your player will be back in condition..Thank you..
Regards!!!...
Posted on Jul 24, 2008
  • 10,594 Answers
It is problem in Take-up Reel section and its not sending signal to processor. How old is this unit?
  • Shahid Electronics
    Shahid Electronics Jul 27, 2008
    Any one out there to rate the provided solution?
Video cassette player/recorder LGRC 689D wont rewind properly
The problem is in the idler assembly inside the machine, some use rubber that dry out and crack, or there is a spring loaded double clutch wheels that get weak over time. In order to fix this the idler assembly must be replaced.
May 04, 2012 | Televison & Video
Where is the rewind on this cassette player?
Cheap cassette players have no rewind feature. This allows the mechanism to be simpler and cheaper; they just 'pull' the tape forward constantly, without the pinch wheel for "fast" [sic] and with the pinch wheel for "play".
To work out if this is the problem with your cassette player, look inside with no cassette inserted. If one of the spindles is plain, without the "three-pronged" device to engage with the spool, then you have the cheap device with no rewind. Turn the tape over, and fast-forward.
Jan 19, 2011 | Audio Players & Recorders
I have a JVC (stereo, radio, cassette, recorder) and it's buzzing
If it is only when the tape is running, it could be motor noise.
Worn bearing in the motor or maybe a suppressor has failed, if it has one.
Oct 09, 2017 | JVC RC-EX25 Radio/Cassette/CD Boombox
Wont play cassette
Usually when this happens it is either the "Pinch Rollers" or the "Drive" motor, has failed. You need to get it looked at.
Apr 29, 2010 | Dictaphone 2740 Desktop Cassette...
Dictaphone ExpressWriter system - tape will not rewind, play, ff
Is this a standard-size cassette unit? Is the model number a 2740 or 2750? When you first plug the power in, does the machine make two clicking noises? Does the display show 'CAS' or 'No Cassette'?
Jul 24, 2009 | Dictaphone 2740 Desktop Cassette...
Foot pedal
If you cannot play, rewind or fast forward, but you hear a light "click" coming from the cassette compartment, then more than likely you have a broken drive belt, or the circuit controlling the play and/or rewind/ff mechanisms are out. In either case it sounds like you need to send it in or take it somewhere for repair.
Nov 04, 2007 | Dictaphone 2740 Desktop Cassette...
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
Teac A-21 Stereo Cassette Tape Deck turns un, but won't play cassette tapes...
very likely that the drive belt has broken. I have fixed a TEAC myself using a large O-Ring from a hardware store (I know I was lucky to find a very close match). Open the unit and find the broken belt and take it to a hardware store to "size up" a replacement. Use the opportunity to oil the gear shafts and clean the rubber pinch roller.
Jun 22, 2007 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Onkyo TARW255 Single Dual Cassette Deck Logo
379 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
