Question about Kenwood KDC-138 FM / AM Receiver
Kenwood KDC-138 Operation Problem
I bought a used jeep with a Kenwood model KDC-138 cd player already installed. I did install an amplifier and subs on my own. This did not prove to be a problem as I have done so many times before. The system worked well for about a month. After fueling my vehicle one evening I found that when I started the jeep the stereo was not working. The only thing the unit will display is "dcer" and nothing functions. What could the problem be?
  • Anonymous Sep 19, 2008
    I have the same problem. I did what the manuel says, however, problem still persist.
Here's the quote from the manual regarding "dcer": "The speaker wire has a short-circuit or touches the chassis of the vehicle and then the protection function is activated. Wire or insulate the speaker cable properly and press the reset button. If the "PROTECT/DCER" code does not disappear, consult your nearest service center "
I believe the manual can be downloaded from crutchfield .com after you go to the Kenwood KDC-138 page on their website. The reset button is either on the lower left of the face or, removing the face, on the lower left of the body. Hope this helps you.
Posted on Aug 03, 2008
How to install a Kenwood kdc 138 in a 1992 Ford Escort LX?
if its anything like my 92 ranger you take the dash apart around the radio and the stereo should unscrew, in my ranger the new cd player went in without any extra harness as it was the same size as the stock, if not you can but harnesses to go where your old stereo did, to connect the speakers you can buy a ford wiring harness from walmart or any store with an audio department. these plug in to your vehicles wiring harness so you don't have to cut it out, after that you simply match colours from the wires of the new cd player to the wiring harness
Dec 25, 2013 | Kenwood DISCONTINUED - KDC-138 In-Dash CD...
What's your problem?I drive a 1999 ford crown victoria. This unit did not come with a a wire harness.. so how do i install my Kenwood KDC-138 FM / AM Receiver correctly
you need to go to any appliance store that cells cd players and buy a wire harness that connects to the cd players wires its called a ford wire harness, the people at the store should know where and what it is.
Oct 17, 2011 | Kenwood KDC-138 FM / AM Receiver
I bought a used car and it already had a kenwood kdc-x890 installed. my question is when i plug my zune or even just a mp3 player into the usb port it responds with [n/a data].
The KDC-X890 will play MP3s that are stored on a USB mass storage device, such as a USB thumb drive. It won't play music from another MP3 player such as a Zune through the USB port, but you could plug your MP3 player into the auxiliary jack.
Mar 04, 2011 | Kenwood KDC-X890 CD Player
Operation manual for Kenwood KDC 139 cd player
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Jun 22, 2010 | Kenwood KFC-1390ie Car Component System
Kenwood kdc-138, NO SOUND, CD PLAYER NO RESPONDING
First thing you need to do is make sure you dont have a short in the speaker wires.. if any one of them touches ground it kills the system.. then you have to remove all the wires and start over... disconnect the battery... remove all the speaker wires only and then turn it on and reset it... then again remove the battery from the car and install them all make sure nothing is touching then turn it back on and see if that works.. you can also test to make sure you speaker wires are good by using a 9v battery and touching positive and negative of each speaker to the positive and neg of the battery... JUST FOR A SECOND it will pop.. that means your wires are good and no shorted to that speaker.
May 12, 2010 | Kenwood KDC-138 FM / AM Receiver
Install
I hav a problen with ic amplifier of audio KKZ12 I need to remplaice or need more information with this
Nov 23, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
I had an amplifier and sub installed using the factory cd player and it worked fine. then i replaced the cd player and now the sub and amp are not working but the new headunit works fine. the amp is...
if the wire ur talking bout suppose to be connected then ur radio shouldn't *** on ..the wire suppose to connect to the back of the radio where a screw goes, its a ground wire...hop i was of help.
Jul 12, 2009 | Kenwood KDC-MP435U CD Player
CD won't eject
If it brand new take it back to were it ws purchased to have it replaced.
Nov 12, 2008 | Kenwood KDC-MP4028 CD Player
Kenwood KDC-138 FM / AM Receiver Logo
736 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
