Question about Sony KP-51HW40 51" Rear Projection Television
Sony KP-41S3U Projector TV HV Distributor Block
Hi
I am trying to locate part number 859895511 (or 859895514)
This part is the HV distribution block for the three projectors and has failed.
Do you know of a good supplier, preferably in the uk.
Thank you for you help
Regards
David
  • Sony Master
  • 8,617 Answers
The only place I know that would have your part and ship to the UK would be at the following link. Leave them a email if you dont see it listed as they only list the most popular parts they have.
http://servicemanuals.vstore.ca/
Posted on Jul 24, 2008
Hi, I have a sony rear projection TV. I am trying
The wire is the HV lead to the block or HV splitter.
At the splitter pull rubber boot back and press down and turn wire and it will come loose.
SD TECH
Jul 10, 2011 | Sony KP-57WS510 57" Rear Projection HDTV
When tv is on for a while it gradually turns gree.
Could be the video driver for the green CRT, HV Block or a bad CRT.
N Sabre
Nov 08, 2009 | Sony KP-51HW40 51" Rear Projection...
Kp-53hs10 High Voltage Block Buzzing?
That is the G2 Focus block and not any one will do. The Sony part number or the number on the block must be the same.
Jun 08, 2009 | Sony KP-53V35 53" Rear Projection...
How do I remove the HV lines on the D board?
Do not cut them.
Push and twist thicker wire in HV block and pull out. HV block has 3 more wires going to 3 guns in TV.
Never cut this wire.
Feb 25, 2009 | Sony KP-61HS10 61" Rear Projection...
Sony Projection Tv Model KP-51HW40
With both of error codes flashing, the problem is trying to figure out wich one to focus on. The flashing 6 code is an indication of HV failure which would then cause a vertical failure(4 blink code). There are so many things that would cause this problem. I can narrow it down to the "D" board to fix your problem. If I were there to troubleshoot it, I could narrow it down further I.E. flyback, HV distribution block. I suggest getting a tech diagnose the exact problem. I wish I could narrow it down better for you. Please take time to rate this solution and if I can be of further assistance, let me know
Dec 13, 2008 | Sony KP-51HW40 51" Rear Projection...
SONY KP-41S3U
tv sony kp 53u45 com centelhador proximo ao flay bak acendendo e desligando atraves da proteção.
como conseguir o esquematico da mesma
Jun 12, 2008 | Sony KP-41T65 41" Rear Projection...
Sony KP-41S3U
Good Day;
On that model look for a small yellow cap, half the size of coin, dime. LOOK very closely and you will see a small burnt spot on the cap. The TV uses about 4 of them, they are 120/110 @ 2 kv. There are located in the high voltage circuit.
This the most common, it could be flyback or HV devider.
Good Luck and Day, big irish.
LET ME know.
Jun 07, 2008 | Sony KP-51HW40 51" Rear Projection...
KP-43HT20 convergence box
Remove PCB w/largest heat sinks.Locate STK IC's. Replace both IC's for reliable repair. Check pico fuses near IC's-if open,replace with same value. Note:No hv to be discharged.However,care is needed removing HV lead from HV block- Slide rubber cap back,push lead in slightly,turn cc 1/4,then release straight out from block.Easy does it!
Oct 05, 2007 | Sony KP-46WT500 46" Rear Projection...
Green Screen then off...8 blinks
According to service manual, 8 blinks is a high-voltage error. A link to the manual and a how-to guide for retrace lines is here: http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
May 21, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
82 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
