Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Ryobi Line trimmer
Gas engine...I pull the cord,to start, it dosen't engage the engine...no resistance on cord...just spins and retracts.
  • 163 Answers
You have to remove the starter housing, inside will be 2 knobs that spring out when the cord is pulled that contact the flywheel cap of the motor and rotates the crank. check if they are missing or damaged and that they ejecting when the cord is pulled. if not; replace.
Posted on Nov 29, 2008
    Problem Solver:
  • 13 Answers
Watch you tube "how repair a pull starter" there lots of videos on there .. you can watch them again and a again
Posted on Oct 06, 2011
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
Aug 26, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
How to start a kawasaki th48 2 stroke engine
Typically:
1. Press primer button 6-7 times until you see fuel flowing
2. Engage the choke lever to full choke /--/ pull cord 3-5 times until engine begins to start
3. Move choke lever to 1/2 choke and pull cord 2-3 times until engine starts - - allow to warm up (about 30 seconds) and move choke lever to no choke / / /
4. If engine does not start, repeat 1-3
If engine does not start, repost with more detail. Thanks! :)
Sep 25, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Starting Pull Cord
You didn't list the model but those little rewinds are typically built very similarly.
It may sound a little crazy but it works, take the unit to a power washer such as a car wash and blow out the gook in the rewind with lots of hot soapy water and then rinse. Then using a probe or small screwdriver get the rewind unstuck. If it retracts you’re good to go if not let me know as you may have a broken piece in there and I'll need the model to know what to do next.
Jun 04, 2010 | Ryobi 15" Electric Factory Reconditioned...
I have a Ryobi gas click it system. Have been
Jun 04, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi BC30 trimmer - pull cord not engaging to turn over engine
The "pully" that you are refering to is called the recoil. There are a couple of simple reasons why this won't catch on the flywheel and if you try to fix it your self it will most likely fly apart and scare the living daylights out of you. Either order a new recoil unit off of Ebay or from a reputable dealer and save yourself the headache.
Jul 30, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Craftsman 32cc Line Trimmer pull start will not engage engine.
Hi I have a craftsman 4 cycle model no. 316.791970 gas trimmer. When I pull on the rode there is little resistance . I took the sparkplug out and put a flash light down the hole and there is a thing that is moving . What should I look next, or do you know what is wrong? Thanks for any help! I've had it only 3 years and already Sears have replace the clutch assy.
May 17, 2009 | Craftsman 25cc Gas Line Trimmer
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
947 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
