Question about NEC VT460 Multimedia Projector
No smell smoke or anything
No it didnt smell or smoke or anything  joe
  • 10,594 Answers
How many times that Red light Flashes?
Posted on Jul 24, 2008
Bang
was there smoke, or the smell of smoke/burning. Its more than likely a compasitor, and unless you know how to electrical trouble shoot, and sodlier then you will need a new one. We call if magic smoke in the electrical industry, and its never good.
good luck
Apr 30, 2013 | Epson PowerLite 77c Projector
My NEC lt30 is smoking after installing a new bulb. There is a rectangular, hollow plastic piece that seems to be touching the bulb and smoldering. Is there supposed to be metal over this? Is it part of...
First, stop using the unit IMMEDIATELY. Is the replacement a genuine NEC bulb or knock-off? If it's genuine, they'll replace it. We have had issues with the cement used in the knock-offs in several different projectors. They all work fine at first, but the cement will break-down very quickly, and will let the actual 'capsule' move-around inside the lamp module. The reason I'm serious about not using it, is that we had one capsule slide backwards and melt-into the wiring. That caused the $200 ballast board to fail.
Aug 31, 2011 | NEC LT30 Multimedia Projector
Professionally clean a three year old liesegang dv 560
LCD are very septable to dust thats why they use filters where most DLP dont. These lamps get so hot that smoke and other things in the air can cook inside the unit.
These things use mirrors and lenses and some use light disipators so smoke can really affect their brightness over time.
DLP units use a spinning wheel and they dont seem to have as much of a problem with dust blobs like LCD but i would guess smoke can still darken their images over time as well.
Jun 28, 2010 | Liesegang dv 560 flex LCD Projector
A fart-like smell emanates from sharp notevision projector model XGC40XU when the unit is turned on. The smell is the strongest immediately after being turned on. However, the smell is still strong while...
You have a small electrolytic capacitor leaked or blown up on the circuit board. The unit needs professional repair. Take it to a reputable Sharp center and get an estimate.
Mar 21, 2010 | Sharp Notevision XG-C50X Multimedia...
Smoke on the water
Check for a fried bug on or near the lamp. I've seen that a couple of times.
Mar 20, 2009 | InFocus Proxima UltraLight X350 Multimedia...
No power in multimedia projector
is the lamp burnt out?
try it in another outlet?
smell the unit and see if anything smell burnt.
it could be the power supply in the unit as well causeing the issue if non of the leds are displaying as well. make sure all connections are tight as well.
hope this helps a bit.
Aug 02, 2008 | 3M MP 7740i Multimedia Projector
Reply to your question
One more question... when you plugged the projector in ac outlet, did it give smoke, smell or something?
Jul 24, 2008 | NEC VT460 Multimedia Projector
CRT Projector Fault
What is a 701? try turning down the screen control!
Mar 10, 2008 | Office Equipment & Supplies
2 ISSUES: 1) Pencil tip size dot in the middle of the projection. 2) weird smell coming from projector vent.
might be a speck of dirt on your lens, possibly on the inside. I assume youe have wiped the outside of the lens? ;-) (I have to ask) If the dot seems to be following pixels exactly your projector might be broken. The smell might be from some dirt or possible an insect in the projector. Try using compressed air to blow out any dirt and dust. It might just be dirt acumulated over time that is burning to create the smell. t t might be a long shot, but if the bulb is easily removed, yo ou might try to shine a flashlight through the lens to see if there is dirt on the lens inside. If you adjust the image size mechanically, or use lens shift, does the speck move on the picture? If so, it's probably on the lens.
May 17, 2007 | InFocus ScreenPlay 5700 Multimedia...
NEC VT460 Multimedia Projector Logo
53 people viewed this question
Top NEC Office Equipment & Supplies Experts
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
