Question about GE Dishwashers
Food particles left after wash
I know I need to clean the trap. I have already removed the upper screen (part#165D4188-Cav 5), the lower screen (Part#165D4164). Does the actual food screen remove, or is this as far as I can go?
  • 12 Answers
SOURCE: dishwasher is leaving food particles everywhere
Dishwashers need cleaning too :) Take a look inside your dishwasher: Click here http://www.appliancepartspros.com/partsearch/model.aspx?model_id=41284 then click on PUMP AND MOTOR diagram on the left. Number 47 on that diagram is a filter. Make sure that filter is clean. Then, using a dishwasher cleaner (see below) run your dishwasher through the entire cycle on empty. This should help, post back if it doesn't. Dishwasher cleaners: 1. Vinegar - good cheap solution, if you don't mind the smell :). Dump a gallon inside an empty dishwasher tub and start up the regular wash cycle. 2. CLR - I've been told it works, but never tried myself 3. Dishwasher Magic - This stuff works pretty good. One bottle per use. http://www.appliancepartspros.com/accessories.aspx?part_id=2675393&cat=62&rdr=%2faccessories.aspx%3fcat%3d62 Hope this helps, APP tech http://www.AppliancePartsPros.com
Posted on Aug 08, 2006
  • 9 Answers
SOURCE: Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Posted on Jan 26, 2009
rylee_smith
  • 8619 Answers
SOURCE: FOOD PARTICLES ON DISHES
Hi
If your dishwasher is cleaning poorly, check these:
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Please do rate this solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Posted on Mar 26, 2009
plnolte
  • 62 Answers
SOURCE: Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
Posted on May 12, 2009
SOURCE: Maytag dishwasher filter (?)always clogging
How do I take apart and clean the filter, I've gotten the screws out but to do now?
Posted on Sep 18, 2009
How to remove large food particle trap in a electrolux dishwasher model # EWDW6505GBO
Good Morning Friend,
I understand you want to know how to remove large food particles that are trapped in your Electrolux dishwasher, model# EWDW6505GB0. First, I would suggest that you scrape away large pieces of food before putting any dish in your dishwasher.
Your dishwasher is equipped with a state of the art wash system. Periodically, the Glass Trap Filter and Large Food Particle Trap may need to be cleaned to maximize wash performance. The Glass Trap Filter is located in the center of the Large Food Particle Trap. The Glass Trap Filter is designed to collect pieces of broken glass, straws, bones and pits. To remove items in the Glass Trap Filter, grasp the handle, lift out, empty and replace. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Electrolux EWDW6505GS Fully Integrated...
Heavy film left on dishes. when rinse only frunction is used in empty dishwasher with no soap, the door and interior are still not clean. soap scum remains.
Hi and welcome to FixYa, I am Kelly
Most of the time when you start having dirty dishes post wash there is either an internal blocked screen under the lower wash arm tower or a problem with the drain. The drain problem shows up mostly inside the Air-Gap cap or at the garbage disposal / sink port connection. Pull the cap / cover off of the Air-Gap and then NOTE the installed position of the inner cap. Unscrew the cap nut and lift the cap off of the Air-Gap assembly. Food particles block the drain inside the cap. You should see a blockage as soon as you lift the cap or the particulate falls away as you lift the cap. Look into the Air-Gap with a flash light and clear any debris. Re-install all Air-Gap parts after cleaning. Make sure to pull the hose off of the garbage disposal port and clean the port.
Add water via cycle fill and then test the drain cycle. The dishwasher should be empty in less than 90 seconds. After 90 seconds interrupt the drain cycle. There should NOT be standing water in the dishwasher sump. If you have standing water in the sump after 90 seconds you will have to remove the lower wash arm and tower to clean the screen or drain holes in the tower. (depending on modeL) Another thing to pay attention to is exactly HOW the lower wash arm is installed on the tower. Some of the 2 part lower wash arms can be a nightmare to re-assemble.
When in doubt take pictures first.... (Lesson learned the hard way too many times when a 30 minute job goes in to the 2nd hour on my time!) Just make sure you do NOT remove any motor pump mounting hardware where it mates to the tub base. Even loosening a motor pump bolt or screw can cause a leak after your done.
While the lower wash arm is removed make sure that you inspect and clean the inside of the wash arm. Often food particles can block the water spray holes in the wash arm.
IF you have a direct / no Air-Gap sink connection then pull off the hose at the sink connection and clear the connection hole of any debris.
One last thing to look for is clogged upper spray arm water holes. Just inspect for signs of blockage. Only remove it if you note food particulate in the holes or under the wash tower base.
I am speaking from many many years of in home appliance repair experience. The steps above should stop the dirty post wash dishes. If you still have the same issues please respond with an EXACT Make and Model Number so I can look at the mechanisms of your dishwasher before responding again.
Thanks for choosing FixYa,
Kelly
Jan 17, 2011 | General Electric Spacemaker® GSM1800N...
IT is leaving food on the dishes
You do not have to prewash your dishes before loading them. In fact, by prewashing, you actually defeat the purpose of most dishwasher detergents. These detergents are activated by the grease and oils in food and work better. You should only scrape your plates of solid materials that are not recommended to go into a dishwasher (i.e., celery, popcorn kernels, tough chunks of meat, gristle, etc.).
If you are getting food particles on your dishes, this is known as "redeposition". Most commonly it is caused by food particles trapped in the filter of the main wash pump. You will need to remove the lower spray arm and access the filter screens and clean them of all debris.
If you need further assistance on how to disassemble your dishwasher to access the filter, please post back with your MODEL NUMBER. I hope this information is helpful to you.
Mar 29, 2010 | Dishwashers
Does not get dishes clean
There is a filter/trap located at the bottom of the machine held in place by 2 1/4 screws. This trap will be located at the lowest point in the dishwasher. Once the two screws are removed there is a lower tub that may have a bit of food debris in it. Sometimes there is food particles that do not get flushed out into the drain. Clean this area and you should be in good shape
Dave
Jan 13, 2010 | LG Dishwashers
KitchenAid Dishwasher (model KUDS01IJBL) has black gunk inside
That black gunk is caused by soap deposits and food particles that do not get washed down the drain. This all collects in the area around the door gasket and front of the wash tub and forms a sticky black sludge. You need to periodically clean the interior of the dishwasher out with a non-abrasive cleaner with some bleach in it to kill bacteria. You should also check the wash pump sump (located under the lower spray arm) to make sure it is not being clogged with food and debris. In order to access the pump sump, you will need to perform the following:
1. Remove the lower wash rack and lower spray arm.
2. Remove the upper wash rack and spray arm.
3. Locate the screws holding in the upper spray feed tube. Remove the screws to the feed tube and turn the whole assembly 1/4 turn to the right (CW direction). The entire assembly will unlock from the wash pump assembly and lift out.
4. Remove the strainer assembly (known as an accumulator) that covers the pump sump area.
Inspect the sump area for food particles and debris that may be contributing to the mess inside the wash tub. If you need some guidance, pcappliancerepair.com has some very helpful exploded view diagrams to assist you.
If you have any questions, or require further assistance, please let me know. I hope this is helpful to you.
Aug 17, 2009 | Dishwashers
Food particles left on dishes
Many times this caused by food particles clogging the screen or blocking the jets on the spray arms. Find the screen in the bottom of your machine and clean it out. If this doesnt help, remove the spray arms and clean them out.
Jun 17, 2009 | Dishwashers
Residue and food particles left on dishes in upper rack.
Check the inlet screen at the bottom of the dishwasher that could impede the flow.
Otherwise the pump may be to blame.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore HE2 Plus Front Load Washer
Food particles and what looks like sand consistently left on dishes after cycle is finished
Clean the filter.  It is at the bottom below the wash arm.  Remove the wash arm by lifting it off.  The filter is a round ring the can be lifter out and cleaned.
May 20, 2009 | Dishwashers
Upper Rack not cleaning
id try removing hte lower filter plate . 5 torx 15 screws will gain oyou acess to lower sump and 2 more torx screws that will acess you the chopper assy, prhaps filled with debris not allowing good water flow,
Mar 25, 2008 | Dishwashers
Dishwashers Logo
82 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
