Question about Motorola Mobility H700 Wireless Headset
Setup help trying to get the blutooth to locate my phone. do i need to enter all info.into phone again, the motostart says (2.) menu-setings-connection-bluetooth link-setup. Problem- link setup where do i enter the device info? it should offer motoroal H700, but on the 1st setup i entered this info it wasnt offered as an option, then the passcode at that time all was working fine, until now. problem- I cannot find where this info is or where it should be. ive looked in each of the settings in all options, nothing found, help.
  • MissShine86 Jul 29, 2008
    I know to pair the bluetooth with my phone I have to hold the button down till it turns purple. But it will turn purple for only 2sec. How do i get it to stay purple long enough for me to pair it? I have held it down for along time.
  • 27 Answers
To locate the bluetooth you need to set the bluetooth up into pairing mode. Do this by holding the button on the bluetooth till the ring turns purple. Then see if you can pair it to the phone.
Posted on Jul 29, 2008
Sir , I Have Nokia 2700 Classic. In This Mobile Whenever I Click On Browser then Browser is not Open.
restore ur factory settings and enter code 1 2 3 4 5
ur phone will restart and then try to open browser
Dec 24, 2010 | Nokia 5310 Cellular Phone
Plantronics Explorer 232 Oem Bluetooth Headset is my bluetooth. i need the pairing instructions thank you.
TURN ON UR BLUTOOTH OF UR DEVICE THROUGH WHICH YOU WANT TO PAIR.......
HOLD THE KEY OF UR BLUTOOTH HEADSET.....
THEN AFTER YOU WILL GOT A MSG IN UR DEVICE AS"add a new Handsfree(WHATEVR UR HEADSET NAME IS) device" THEN SELECT YESS......
then it ask for passkey ....enter "0000" or "1111" or "1234"
these are the normal passkey......or otherwise ask ur blutooth headset company for passkey.....
hope this will help u.....enjoy it
Oct 03, 2010 | Cell Phones
My phone is not connected with my laptop through data cable
on the cell, go to connection in tool settings...change settings blutooth/usb or data (blutooth is blutooth, usb is connection to cell storage and data is for cell vital info)... some cell also have infared
Jun 12, 2010 | HTC Touch HD Smartphone
I try to pair S9 Motorola bluethooth headset
well reset both phones and try again...if still wont work then it's blutooth version problem can't do any thing
Nov 19, 2009 | Nokia 5800 XpressMusic Smartphone
Unable to perform bluetooth operation
check wether your blutooth is on and also check wether other devices are in range of below 10 meters thats all else check wether you are using any applications releted to blutooth at the same time if you try to send something else re-start the phone and try again
Oct 20, 2009 | Nokia N70 Cellular Phone
2004 BMW 328i bluetooth
Are you sure the blutooth is active in your car? Contact the local dealer and have them run a "DCS" and confirm the car is fitted with Blutooth. Then go to www.bmwusa.com and check that your phone is apporved to work with the car. Provided nothing is wrong with the car you can then follow the instructions below.
  1. make sure your phone's bluetooth is "always on"
  2. get your phone all the way to the "search screen" and stop
  3. press the "menu button on the radio
  4. press the button below the "phone" in the menu screen of the radio.
  5. press search on your phone to locate the car.
  6. after the phone locates the car press yes to "bond"
  7. the phone/car will now ask for a password, enter 1111 and press enter or ok.
Ifyour passwrd does not work you will have to go to the dealer to get the correct one or you can locate the TCU in the driver's rear inner panel in the trunk and get the number off the unit. It will say "PK XXX"
Jun 01, 2009 | 1999 BMW 328 Series
BlackBerry won't pair with device anymore via Bluetooth
1. Go to Options/Bluetooth
2. Select device found
3. Select device properties
4. At Trusted select yes
It'll never ask again
Dec 30, 2008 | RIM BlackBerry Curve 8310 Smartphone
Blutooth security code
Hi, try these
1234 or 123
or 0000
cheers,
Sep 21, 2008 | Nokia 6126 Cellular Phone
Samsung sgh-d500
the same thing happened to me. enter the pin of your phone in both phones. It should work it did for me. you shouldn't have to enter it again. good luck
Aug 22, 2008 | Samsung SGH-D500 Cellular Phone
Bluetooth headset Nokia BH-600
You just have to press your blutooth on/off button a bit longer for 15 to 20 sec, when the LED blinking stops (noted that the LED should be turn ON but not blinking), try to search the device again with your phone. By that time your blutooth headset should be recognized by your phone, then select and enter the code 0000.
Jan 28, 2008 | Nokia BH-600 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
99 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
