Question about Quasar HQ2082UH Air Conditioner
Compressor for HQ2082YW
Serial 139301804 8000 BTU. Need a compressor. Where can I find one?
  • 143 Answers
Look in the phone book under air conditioners, parts and supplies.
Posted on Jul 24, 2008
Can a Fujitsu compressor unit be connected to multiple inside evaporator units that have different tonnage ratings. 18,000 BTU compressor and 9,000 & 12,000 BTU evaporator units inside.
call fujitsu engineering division direct and ask them about what is connected and if it works ok
logically as each evaporator has it's own tx valve as long as the compressor is large enough to run all together it should work but get the right information from the fujitsu experts
Oct 11, 2016 | Fujitsu Heating & Cooling
I have a Fedders A6X08F2A-B Service # and Serial # MP 178550 and I would like to have the specs on it eg: how many BTU's, model # etc
Hi, The numbers you have given tell me, this unit is a 8,000 btu unit.!2, 000 btu's equal a ton of cooling, so you are just under a ton. This is about all I can tell you. There should be a data plate that will give you amps, volts, compressor amps ect.
Shastalaker7
A/C, Contractor
Jun 10, 2011 | Fedders X Chassis A6X08F2A Air Conditioner
Compresser is shorted out across the fields. I want to comfirm the compresser size before I replace it.
You need a niminal 3 ton compressor...the "36" in the model number gives you the 3 ton rating...36000 BTU @ 12000 BTU/ton = 3 ton...
So you need a 3 ton 240 volt single phase compressor...
heatman101
Aug 23, 2010 | Carrier 38CKC036 Air Conditioner
Does the model no. of the compressor indicate
Yes the model will have a series of numbers that will look something like 024,030, 036,048, or 060 ... this is the btu output in thousands of the condenser...so those numbers range from 2 to 5 ton... a ton is 12,000 btu...
What Size Air Conditioner Do You Need?
http://www.fixya.com/support/r3636709-size_air_conditioner_need
heatman101
Jul 20, 2010 | Heating & Cooling
Frigidaire fac127p1a 12000 btu compressor
The compressor is probably going out on either a pressure related or heat related overload. Both are a result of low refrigerant. There may be a low pressure safety swich that protects the compressor. Otherwise it may be an internal thermal overload that is tripping. It resets itself and comes back on. The thermal overload heats up and shuts off the compressor to protect it from too much heat which is gernerated by not enough refrigerant in the system to keep the compressor cool. It may be cheaper to replace the unit than have someone try and fix it. It is pretty time consuming and you cannot try it yourself unless you have an EPA Certificate to buy the refrigerant. Check with your local appliance repair man to see if he will tackle it.
Jun 04, 2010 | Frigidaire 12,000 BTU Compact II Room Air...
Need help in AC compressor replacement. The existing compressor number is C-SB351H6B and its a SANYO.? What is the BTU rating for this compressor and what would be the replacement with a copeland scroll...
This compressor has a rating of 56700 BTU at 45 deg. F Evap and 130 deg. F Cond.
Your supplier will match a copeland scroll using this rating
Fuji
Aug 03, 2009 | Heating & Cooling
Looking for btu on airtemp imperial ll model
This information can usually be found on a small plate welded or glued onto the side/rear of your A/C units along with the model & serial #s. Although it would be a highly illogical place to put this plate, you may also want to check the bottom but if you turn the unit upside down, do not turn it on for 24 hours, as the gas & oils will be displaced & you can kill off the compressor by doing so.
Jun 15, 2009 | Airtemp B3Q06F2A Air Conditioner
Quasar HQ2082UH Air Conditioner Logo
71 people viewed this question
Top Quasar Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Quasar Heating and Cooling Expert? Answer questions, earn points and help others
