you have chosen normal preview 1. change it to thumbnail preview 2. or click on "All" button in normal preview so you would scan multiple negatives.
increase your dpi setting or your target area or both I am also scanning color negatives at 3600dpi and 48bit. file is large but quality is very very good... Mehboob Riaz, SIPA, Lahore-Pakistan
You received a cd for the all in one. After Installing the CX4800, you should see an Epson Scan Icon on your desktop. Double click it open, then you should see this. Click on Scan and there you go.
Good Luck.
I have successfully used my Visioneer 9520 to scan 35mm slides, and they came out perfect. To do this, in my image editing software, I select File/Import/Acquire/Visioneer ScanManger Pro. This opens the VIsioneer scan manager window, where I select "Scan 35mm using:" and then I choose the desired scanning configuration, e.g., "35mm Better, 35mm Best, Custom" etc. See image below.
BTW: After several moves, I have lost my 35mm scanning template. Do you know where I can get another one, or do you know someone who could actually scan theirs and email the image to me? I could then create a duplicate from heavy black construction paper or card stock.
I've not ever seen "square" 35mm slides. By definition they are a rectangular positive film in an outer square "mount".
If you have a truly square piece of film then it is not a 35mm slide. You may have to use settings other than those for a 35mm film but these would be I don't know.
When were they taken (approximately)? What brand of film? Are they in a cardboard "mount?
To be honest, I have no idea of how you were able to scan larger transparencies in the past. The scanner and its software were never designed to do this and there is no workaround.
