When I start my Computer the On Screne message is Boot failure. Insert Boot Disc into A and Press any Key. I have tried to install Windows XP Pro but when the files are installed and i press enter,the on screen message is no fixed disks. is my dead what can i do
    Problem Solver:
  • 13 Answers
It looks more like hard disk failure.
If your PC is still within the waranty period, kindly contact your PC vendor to fix the problem for you.
If the warranty period has already expired, please switch off your PC and remove all power sources and open up your CPU and check if the hard disk cables and the power supply is fine. Also check if there is any loose connection.
This should fix the problem, else please provide more details.
Posted on Jul 24, 2008
Is this computer able to dual boot win 7 and xp
Which version of xp are you trying to install 32 or 64 bit ?
Your ability to install a second operating system on your Windows 7 system hinges on one thing: partitions. If your computer has only one partition, you can't dual-boot your system without erasing all information on your computer. Two hard drives, or two partitions, enables you to dual boot. Check this information first, before proceeding.
Click "Start" and type "disk management" into the search bar. Click on "Create and format hard disk partitions" in the list of programs to open "Disk Management." Look at the list of partitions and available drives. The information here will be different on every computer. "C" is your primary hard drive and active operating system partition, and this drive contains your Windows 7 installation. You can't install Windows XP here without formatting the system. Check for secondary drives and partitions in Disk Management. Your system may have a "D" or "E" drive. Some computer manufacturers create a hidden partition with recovery software: don't remove this partition. If you have a secondary partition called "D" with more than 2GB of free space, you can install Windows XP here. b> Installing XP b> Insert the Windows XP Setup disc into your CD or DVD drive and close any windows that appear. Shut down your computer with the disc in the drive. Turn the computer on and look for a message saying "press any key to book from CD." Press any key on your keyboard when this message appears. Most computers are configured to look to the CD or DVD drive first, before booting to the operating system. If your system doesn't recognize the disc, you will have to enter your BIOS and change the boot order. Look to your manual for information on changing the boot order. Press "Enter" on the "Welcome to Setup" screen to load the Windows XP setup program. Read the license agreement and press "F8" to accept. Windows will detect that an operating system is already installed on your primary partition and present a list of other partitions to install XP. Use the arrow keys to select your secondary partition ("D") and press "Enter" to confirm that you want to install XP here. Then choose what to do with the partition: leave the file system intact or format the partition using FAT32 or NTFS. Windows XP supports both file systems, but requires NTFS on partitions larger than 32GB. You don't need to format the drive to install XP. Follow the prompts on screen to enter your personal information, serial number, and date and time. The setup program copies files to your PC and reboots -- don't press a key to boot to the CD. When you have to operating systems installed, a DOS screen appears asking you to choose an OS; press the down arrow key to highlight Windows XP and press enter to complete the setup. You will have to choose this every time to boot into XP, otherwise your computer will boot to Windows 7 by default. Hope this helps.
b>
Jan 06, 2013 | HEWLETT-PACKARD Pavilion Desktop with AMD...
Tip
How To Repair Your Operating System
A Repair Install will replace the system files with the files on the XP CD used for the Repair Install. It will leave your applications and settings intact, but Windows updates will need to be reapplied. Here is how to run an OS Repair using the Operating System CD in XP, Vista, or 7:
Windows XP
1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will see the options below:
3. Press ENTER to start the Windows Setup.
4. Accept the License Agreement and Windows will search for existing Windows installations.
5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup.
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Windows Vista
If you have a Windows Vista installation disc, you need to restart (boot) your computer using the installation disc. If you do not restart your computer from the disc, the option to repair your computer will not appear.
Here is a step by step picture guide.
If you have a Windows Vista installation disc:
1. Insert the installation disc.
2. Restart your computer.
3. Click the Start button, click the arrow next to the Lock button, and then click Restart.
4. If prompted, press any key to start Windows from the installation disc.
Windows 7
1. If a startup problem is detected, Startup Repair will start automatically and try to fix the problem.
2. If the problem is severe enough that Startup Repair doesn't start on its own and you can't access the System Recovery Options menu on your computer's hard disk, you can get to the menu and start Startup Repair by using the Windows installation disc or a system repair disc that you created earlier.
on Jul 13, 2010 | Computers & Internet
How do I restore missing file
to restore missing windows file using the install disc:
1. with computer turned on insert xp disc into drive
2. reboot computer (make sure it boots from cd drive)
3. when message 'press any key to boot from cd' displayed, press a key
4. when disc loaded and started, press enter to install windows
5. press f8 key to agree eula
6. press r to repair window intallation
once it starts, it will look as though it's installing windows but all it's doing is deleting and replacing the windows files, your programs and documents should not be affected.
you will need to install all the windows updates to bring your machine up to date.
Apr 11, 2011 | Microsoft Windows XP Home Edition
Manual for instruction setup key windows xp software ,pls help me to do it my self ! what key to boot or format windows xp i am trying do doing this formating about 4 day ago but still not successful.what...
Follow these steps and ia sure you will be able to boot by yourself:-
1)Change the BIOS boot order so the CD or DVD drive is listed first. Some computers are already configured this way but many are not.
2)If the CD or DVD drive is not first in the boot order, your PC will start "normally" (i.e. boot from your hard drive) without even looking at what might be in your disc drive.
3)Insert your bootable CD or bootable DVD in your disc drive.
4)Restart your computer.
5)Watch for a Press any key to boot from CD or DVD... message.
6)When booting to a Windows setup CD/DVD and many other bootable discs, you may be prompted with a message to press a key to boot to the disc. To boot to the CD or DVD, you'll need to press any key on your keyboard (like the space bar) within the few seconds that the message is on the screen.
7)If you do nothing, your computer will check for boot information on the next boot device in the list in BIOS which will probably be your hard drive.
8)Some bootable CDs and DVDs do not prompt for a key press and will start immediately.
Your computer should now boot from the CD or DVD disc.
Feb 15, 2011 | Microsoft Windows XP Professional With...
When i turn the computer on it says windows root 32 is corrupt or missing please reinstall but i cant get it to reinstall it the install menu does not pop up
You need to re-install it using your disc not when your on Windows enable for it to install. Here are the steps to install Windows back in your system.
  1. Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
    Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.
  2. When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
  3. At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
  4. Read the Microsoft Software License Terms, and then press F8.
  5. Follow the instructions on the screen to select and format a partition where you want to install Windows .
  6. Follow the instructions on the screen to complete the Windows Setup.
Sep 12, 2010 | E-Machines eMachines Desktop PC
How can i fix my lenovo t60 ibm thinkpad. I just press the restart...but the message on the monitor said that the registry cannot load the hive...systemroot/system32/config/software...and its beggining to...
This problem usually requires the Operating System CD, but here are a few things you can try before having to have the OS CD:
Try loading the Last Known Good Configuration (your most recent settings that worked) by following these instructions:
  1. To load the last known good configuration in Windows, reboot the computer.
  2. Before the Windows Loading screen appears, press and hold your "F8 Key", this should bring up the "Windows Advanced Options Menu" as shown below.
  3. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
  4. As can be seen from the example below, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Still unsuccessful? You will need the OS CD, unless you have the Recovery Console already installed and available using the Operating System Selection screen:
  1. Start your computer by running the Recovery Console.
  2. Run the chkdsk /p command on the drive, and then restart your computer.
If you are still unsuccessful, you will need to run an OS Repair using the Operating System CD, here are the steps:
Windows XP
  2. When you see the "Welcome To Setup" screen, you will see the options below:d3573cb.gif
Windows Vista
    Click the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, click the arrow next to the Lock button eb058ccf-b21e-4dfe-9bb7-1ad6c83b705c.png, and then click Restart.
  3. If prompted, press any key to start Windows from the installation disc.
Windows 7
Jul 13, 2010 | IBM Lenovo ThinkPad T60p Notebook
How to install windows xp in sony vaio vgn-nw270F? tia
hello,
I will explain the process for you.
First of all if your computer has some windows like windows 98 or older than you can install the windows by simply inserting the disc and choosing the drive and install the windows.
However if you do not have any windows installed on your system or you have windows installed later than windows xp and want to install another operating system than use the following method.
First of all,
Please make sure you set the boot-priority first.
- you can go into bios by pressing the F12 or ESC key on your keyboard or if the key is different keep in mind when you turn your computer on you should see a small line at the first blink of your screen telling you to press a key to go to bios.
- Thank once you are in the bios please check the boot section and there set the boot-priority and by setting i mean the dvd drive or the cd drive should be apprering on the first section which means that your computer should boot from cd or dvd so that it can read your disc before it reads your hard-disk. remember to change this setting back once you have installed the windows.
- please insert the windows xp disc.
- than press enter on the bios screen and save changes and exit
- you comptuer will restart and
- it will take you straight to the point from where you can install windows using simple few clicks you just have to enter the serial number and your name etc. and the rest computer will do it-self.
Please let me know if there is anything else i can help you with.
Thank you.
May 18, 2010 | Sony XP Pro Upgrade - VS-E85-00087 Upgrade...
Misssing partmgr file how can I load this thanks
To resolve this issue, start the computer from the Windows XP CD, start the Recovery Console, and then use the Bootcfg.exe tool to rebuild the Boot.ini file. To do this, follow these steps:
  1. Configure the computer to start from the CD-ROM or DVD-ROM drive. For information about how to do this, see your computer documentation, or contact your computer manufacturer.
  2. Insert the Windows XP CD-ROM into your CD-ROM or DVD-ROM drive, and then restart your computer.
  3. When you receive the "Press any key to boot from CD" message, press a key to start your computer from the Windows XP CD-ROM.
  4. When you receive the "Welcome to Setup" message, press R to start the Recovery Console.
  5. If you have a dual-boot or multiple-boot computer, select the installation that you have to use from the Recovery Console.
  6. When you are prompted, type the administrator password, and then press ENTER.
  7. At the command prompt, type bootcfg /list, and then press ENTER. The entries in your current Boot.ini file appear on the screen.
  8. At the command prompt, type bootcfg /rebuild, and then press ENTER. This command scans the hard disks of the computer for Windows XP, Microsoft Windows 2000, or Microsoft Windows NT installations, and then displays the results. Follow the instructions that appear on the screen to add the Windows installations to the Boot.ini file. For example, follow these steps to add a Windows XP installation to the Boot.ini file:
    1. When you receive a message that is similar to the following message, press Y: Total Identified Windows Installs: 1
      [1] C:\Windows
      Add installation to boot list? (Yes/No/All)
    2. You receive a message that is similar to the following message: Enter Load Identifier This is the name of the operating system. When you receive this message, type the name of your operating system, and then press ENTER. This is either Microsoft Windows XP Professional or Microsoft Windows XP Home Edition.
    3. You receive a message that is similar to the following: Enter OS Load options When you receive this message, type /fastdetect, and then press ENTER.
      Note The instructions that appear on your screen may be different, depending on the configuration of your computer.
  9. Type exit, and then press ENTER to quit Recovery Console. Your computer restarts, and the updated boot list appears when you receive the "Please select the operating system to start" message.
Apr 13, 2010 | Computers & Internet
My windows Xp just lost because of power failure.. how i reinstall the windows xp for my laptop of NEC Versa pro NX
have you tried this ......
restart the laptop press F8 it will open to boot the laptop through various process like safe mode , last good known ..... select the last good known option and press enter .... it will boot the laptop with last setting
if this one not working then go for reinstall of xp ...for reinstall xp
  5. Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
  6. Follow the instructions on the screen to complete the Windows XP Setup.
Nov 25, 2009 | Office Equipment & Supplies
Enter BIOS Set CD rom drive to first bootInsert your CD reboot
folow the on screen instructions be patient, it may take up to an hour,  and then two houers to install drivers,
-> if you want me to find the drivers for you, plz state your computer name and model.
regards /Teis
Jan 11, 2009 | Microsoft Streets and Trips 2008 for PC
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
