Question about Black & Decker String Trimmer Cordless 12" 18V
White lever. sounds like I have the samr problem. How do I replace it?????
    Champion:
  • 313 Answers
Remove the cap the line/spool assy.them you will see the lever.
you can pull the lever by pliers gently or you can push the lever from the back if you can get in to the back.
Posted on Jul 24, 2008
Dust particles being projected onto screen with BENQ MP 525 projector
White spots on the screen are generally caused by a bad DMD chip.Multiple elements of the chip remain continuously on causing these spots.Solution is replacement of DMD chip.
Samr
Jan 14, 2013 | BenQ MP511 Projector
Display show SE from samsung microwave range hood
The keypad has a short in the membrane, which means the keypad control board will probably need to be replaced.
May 05, 2012 | Samsung SMH8165STE Microwave Oven
How can I purchase a presser foot lever for a White 3300 embroidery machine
It is an issue more to due with regular maintenance than replacement part....have it serviced and cleaned properly.
Dec 12, 2011 | White Sewing W3300 Computerized Sewing...
Customer installed a kohler tub/shower faucet and it leaks out of the head. We've changed the cartridge but the results were the samr.a Any recommrndations?
If it leaks out of the shower head and not the faucet tap, then I would look into the scald guard setting or the selector lever or even for a small scratch around the cartridge.
Jul 16, 2011 | Kohler Plumbing
Timer will not turn water heater ON at set time, has to be done manually. However, it will turn water heater OFF at set time.
If this is new installation, check wiring. Hot and Load wires might be reversed.
Check that ON OFF trippers are both attached to yellow dial.
http://waterheatertimer.org/How-to-wire-WH40.html
If timer worked fine before, and started missing recently, then tripper pins probably worn out.
Trippers contact mechanical lever, and push lever on-and-off.
Trippers are softer metal and designed to wear out before lever.
If lever is worn out, timer needs to be replaced, but try new trippers first.
Buy trippers at Grainger
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
How WH40 timer works:
Clock motor rotates dial.
ON-OFF trippers on dial contact lever.
ON tripper pushes lever one direction.
OFF tripper pushes lever other direction.
Lever moves electrical contacts together, or pulls contacts apart.
When lever moves on-and-off, manual override lever also snaps back and forth with audible clicking sound.
Using q-tip, add touch of white grease to lever where trippers contact.
Nov 25, 2010 | Intermatic WH40 - Water Heater Time Switch...
How do i replace the toner?
Open the white door
pull bypass door towards you
move the blue lever towards you
slide lever to the side ,lift out the old cartridge
pull tape on new toner
snap in new toner firmly
push blue lever forward
close doors
Oct 27, 2009 | Kyocera Copystar CS-1820 Black and White...
Printer/Toner Problem
Sounds like it may be a remanufactured toner cartridge, and the 'reset lever' has not been installed or replaced. If you look at the side of the toner unit, you will see a sort of 'half moon' notch, that should have a white coloured lever within it. This lever is pushed backward when the cartridge is installed. So, on a new cartridge, it should be pushed forward (or towards the printer as you install it).
Note: This lever is not installed on the cartridge that the printer was shipped with (starter cartridge).
Mar 17, 2009 | Brother HL-2040 Laser Printer
Phone
You charging Port need to be service or replaced, so take the phone to a mobile service center to have it fix.
Aug 28, 2008 | Motorola Mobility SLVR L7 Cellular Phone
No Picture
I have the same TV samr problem, so far I have dicovered a cap on the power card AA41-00342A has gone bad, c812 a 2200uf 250wv. I can't find a cap or replacement card. I'm still working on it, when i get more answers I will pass it on.
Aug 20, 2008 | Samsung PCL545R 54" Rear Projection...
13 inch diamond vision t.v. shut off and will not turn back on
I have the exact same problem with a 20 inch tv of the same brand , Maybe possible recall i dont know what to do
Jan 13, 2008 | Yahoo Diamond Vision DVDC803-04 DVD Player
Black & Decker String Trimmer Cordless 12" 18V Logo
137 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
