Question about Gateway FPD1960 19" Flat Panel LCD Monitor
FDP1960 Monitor Power Supply
How much and from where can you purchase the Power Supply?
Thanks,
Al
  • havanickel Jul 25, 2008
    Thanks,
    How much? For your working one?
    Al
  • mick4 Jul 27, 2008
    I had the power supply board fry on my FPD1960 monitor after only a little over a years use. I pulled the power supply and it appears to have some bad capacitors on the board. There is not anywhere a guy can buy a replacement power supply board for this monitor? Thanks
    Problem Solver:
  • 9 Answers
You can't purchase them anywhere to my knowledge. I repair all the broken ones I come across.
I may have a working one here somewhere. Let me know if you are interested in it. I'll give you a good deal on it if you ship me your broken one.
Posted on Jul 24, 2008
X2gen monitor power and all other front panel switches do not respond. i.e. power auto mute menu etc.. which caps do i need to replace to cure/
Robert,
Did you try opening the lcd ? all those switches connect to the power supply. I would go ahead and check and trace the switches with cabling to the power supply.
I just replace some transistors on 2 of these (22") and they work like a charm.
Al
Jan 05, 2014 | X2Gen MG19MY 19" LCD Monitor
I have an Acer AL 1914 Monitor. Green light
Check power supply section for bad caps first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 26, 2010 | Acer AL1914 19" LCD Monitor
ACER AL 1715 GOES OFF AND ON BY ITSELF FOR DIFFERENT LENGTHS OF TIME. SCREENSAVER SET FOR 15 MINUTES, REPLACED MONITOR CABLE. NO EFFECT THIS HADHELPEDIN THE PASS
sbra454016, Monitor has internal problem on "switch-mode-power-supply/ccfl inverter supply" printed circuit board. Check smps/ccfl supply board. Read my fixya profile to understand problem or skip the reading and trade-in for new wide screen unit. Reading is free. 12fixlouie
Mar 20, 2010 | Acer AL1715 17" LCD Monitor
I bought 2nd hand Apple Studio 15" monitor without power supply- where can I find one not over £50? Is there a generic supply I could use or is it locked down to apple supplies, which are thin...
Anytime I purchase second hand devices, especially Apple, I go on Ebay.com. It sounds like you're in the UK so you may want to search on Ebay.uk to keep shipping costs down. Just type in your model. I purchase quite a few Apple products and the particular power supply you're searching for should be under 15 pounds UK.
Feb 08, 2010 | Apple Studio (Metallic Silver) 15" LCD...
I have a AL 1716 monitor and the on/off button is
More likely to be bad caps with bulginh tops in the power supply, common problems, see some example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 06, 2010 | Acer AL1716B 17" LCD Monitor
MONITOR ACER AL1716
1. Unplug the AC power cord to make sure the power is off.
turn the monitor upside down, you need 2 people for this.
2. Pull the 4 hooks on bottom side of the base and hold.
3. Separate the monitor and base.
Nov 05, 2008 | Acer AL1716 17" LCD Monitor
Where can i purchase another power cord for my monitor
starlogi typically use a standard computer power supply cable you may find one at any computer service center commercial or mom and pop
Jul 13, 2008 | Star Logic 17" LCD Monitor
VX900
Hi
Even though you show 12 volts, you could still be coming up short in amps on your powerboard.
Updating the capacitors (all of them except for possibly the main) may correct this.
If that doesn't do it, then the inverter is the next target to check.
Fran
Jun 15, 2008 | ViewSonic VX900 19" LCD Monitor
AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
if this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
May 10, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
Monitor does not work
sounds like a slightly damaged power supply. try powering up with an equivalent supply. if only an ac wall cord is plugged in for power, then internal supply is at fault
May 28, 2007 | Acer AL707 17" LCD Monitor
Gateway FPD1960 19" Flat Panel LCD Monitor Logo
80 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
