Question about NEC VT460 Multimedia Projector
Reply to your question
 in reply to your answer no the fans are not working when switched on joecowell
 Ive just bought a NEC VT440 projector from ebay uk now the power light is always orange and the status light is flashing red  ive looked at the bulb it seems fine ive check the air vents seem fine, ive followed the instruction manual and pressed every button bout still nothing happens no lights noise or anything is it a dud
  • 4 Answers
Here is a link to the manual for the vt440: http://www.necvisualsystems.com/Documents/UserManuals/MAN_VT440-540.pdf
near the end it lists the error codes that the lights give, so by counting them you can work out what the problem is. Also, it could be the bulb, as after 2010 hours on the bulb it won't turn on, to prevent the bulb physically blowing.
Posted on Nov 22, 2008
  • 10,594 Answers
One more question... when you plugged the projector in ac outlet, did it give smoke, smell or something?
Posted on Jul 24, 2008
NEC VT440 projector problems can you help
Please check its vantilation fans, are they rotating or not?
Jul 24, 2008 | NEC VT460 Multimedia Projector
VT440 NEC PROJECTOR
let it cool down then remove the lamp and see if it looks shattered or burnt- if it is you have solved your problem-change lamp!
May 27, 2009 | NEC (50019497) Projector Lamp for VT440,...
VT440K orange power flashing red status light, overheated.
Make sure all the air filter caps are all the way in and nothing is broken from it. that was my cause..i had the same problem
Apr 17, 2009 | NEC (50019497) Projector Lamp for VT440,...
Nec projector vt440 wont turn on
Hello. First check the lamp! From your description, it sounds like the projector is telling you that the lamp needs to be replaced. In "eco mode", when the power is green and the status is steady orange, that is the error message. In "high brightness mode" the status will be steady red. Hope I helped you.
Feb 22, 2009 | NEC MultiSync VT440 Multimedia Projector
No image
try switching your input source and make sure you select S Video. Also you can try to feed a composite (RCA - Yellow Cable) into it and see if you get an image. Are you able to get an image/blank screen? Can you access the menu and see it?
Jul 13, 2008 | NEC (50019497) Projector Lamp for VT440,...
Ballast Assembly Replacement
post the number on ebay see if any are availble
Jan 09, 2008 | NEC (50019497) Projector Lamp for VT440,...
NEC vt440 projector is overheating
Try cleaning the filters, there is one on the front and one on the side. When dust builds up on these it can restrict the cooling of the projector
Dec 31, 2007 | NEC Office Equipment & Supplies
AUDIO
Your post "...GET AUDIO FROM...PROJECTOR AUDIO OUT ...TO THE AUDIO IN...TEAC DVD..."
The normal answer is yes.
However in your particular case, even if you do it that way, there will be no sound getting into the Teac DVD setup since standard 4 pin S-cable carry only video signals (luminance & chrominance) and no audio component/signal. If you run an RCA cable pair from the cable box's audio out aside from the S cable to the inputs of your projector, then it will work.
An exception would be an 8 pin mini-DIN that looks like an S cable which carries also audio signals.
Hope that this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 31, 2007 | Office Equipment & Supplies
NEC VT460 Multimedia Projector Logo
232 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
