Question about Motorola Mobility RAZR V3
Unable to charge
My razor v3m just started to say, unable to charge. i replaced the battery but it did not correct the problem. I don't get the little tune when I plug it in to the charger anymore.
Had the same problem. dealer told me the phone was a dud and replaced it for me.
Posted on Jul 24, 2008
Razor Dune Buggy Problem
I have the same issue with mine. Batterys check out fine.. i'm starting to suspect the motor??
Jul 23, 2012 | Razor USA Razor Dune Buggy
RAZOR 500 BATTERY CHARGE MOTOR DON'T START OR EVEN CLICK DON'T WANT TO SPEND LOTS OF MONEY HOW CAN I CHECK THE MOTOR
Get a automotive battery charger that has 10 amps and hook it up to the motor. If the motor spins the motor is good. Just had to do this myself. Thought the motor was bad on ours and tested it found out it was good. Good Luck!
Jun 03, 2012 | Razor MX500 Dirt Rocket
I HAVE A REMINGTON TITANIUM R9500 WASHABLE RAZOR. I HAVE NEVER BEEN ABLE TO HOLD THE CHARGE FOR MORE THAN 2 OR 3 SHAVES. NOW I AM UNABLE TO CHARGE THE RAZOR OR RATHER IT WILL SHOW 60 MINS AND AS SOON AS...
The batteries need replaced. You will find the correct batteries at shaveroutlet.com. See link below. You will need two
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Remove three screws on the back of shaver to take off back cover. You will need to remove the trimmer to access the screw at the top of the back of the shaver. Once back is removed, you can access the batteries. One of them will have a diode 'glued' to the side of it. Use a razor blade to cut it away from being stuck to the sie of the battery. The batteries are adhered to the circuit board but can be gently pried away. Remove the black tape from ends of batteries if present and then unsolder the wires from the batteries. Solder in the new batteries and reassemble.
Charge shaver for 24 hours when repair is complete.
If you are not capable of doing this repair youself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Dec 19, 2010 | Health & Beauty
Razor charged but not running
You didn't specify how old you model is.
Generally I would say, the battery is failed.
You might try taking it to whereever you bought it and politely ask for a replacement. Its also a good idea not to leave these in cars during sub freezing weather.
Apr 09, 2010 | Norelco Cool Skin 7775X Electric Shaver
Can't synchronize my motorola v3m with the PC
The only way to sync is if you have the sd card in,and you can only sync the sd card, if you did not have verizon,you could use motorola phone tools and sync everything, but verizon turned off transfer
in your phone because there thieves, but if you learn how to hack a razor you can use moto phone tools.
Dec 30, 2008 | Motorola Mobility RAZR V3m Cellular Phone
My razor v3m battery
display brigthness is a factor along with blue tooth try fully charging the battery for a long time
Jun 21, 2008 | Motorola Mobility RAZR V3
V3 unable to charge
reflash the firmware this will correct the charging issues and if that does not fix it then have the mainboard replaced.
Feb 17, 2008 | Cell Phones
Unable to charge the razor
there may be a short in the wire or in the plug. try wiggling it around a little bit and see if you can get a connection
Jan 19, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
214 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
