Question about Lucent PARTNER18 Corded Phone
PHONE RINGS ONLY 3 TIMES BEFORE VOICE MAIL PICKS UP, NEED 5 RINGS
HOW TO CHANGE THE TIMES PHONE RINGS, BEFORE GOING TO VOICEMAIL.
    Champion:
  • 211 Answers
This is done on ext 10 or 11
Feature 00
Left intercom, left intercom
(for main aa)#506
Mode 1 for day, 2 for night
enter line number ex 01, 02 etc
input number of rings
Feature 00
Posted on Jun 17, 2009
How do i change the number of rings before voicemail picks up on a samsung rugby
For all of you that want a real answer here ya go. This isn't something you can change on your phone this has to be changed with your service provider. If you are with AT&T, like I am, then this is the solution for you (link of where I found it below as well). 1. enter *#61*11# and press send/talk on your phone.
2. write down the number your calls are currently forwarded to (usually +1401#######, but not always). this is your voicemail deposit number.
3. decide how long you want the phone to ring in 5 second intervals. the maximum time is 30 seconds. i'd recommend 25 seconds or less, as using 30 may cause you to be billed for a minute of airtime each time someone is forwarded to voicemail.
4. now enter **61*[number from step 2]*11*[number from step 3, use 2 digits]# and press send/talk.
example
voicemail deposit number is +14015551212
you want it to ring for 20 seconds
you would enter **61*+14015551212*11*20# and press send/talk.
if you have trouble with the above procedure, you can always call customer care at 800-331-0500 to change it.
OR QUESTION: How can I adjust the number of times my wireless phone will ring before the caller goes to voicemail? ANSWER: Contact Customer Care at 1-800-331-0500 or dial 611 from your wireless phone to change the amount of time your phone will ring before going to voice mail. The adjustments made by Customer Care are based on the traditional ring heard by the caller, not the unique Ringtone you hear from your phone. I just wanted to add that increasing the ring length to 30 seconds will not cause you to be charged a minute should the caller go to voicemail. This was confirmed by an AT&T technician.
http://forums.att.com/t5/Voice-Mail/Increase-the-number-of-rings-before-a-call-goes-to-the-voicemail/td-p/2576651
Aug 11, 2011 | Cell Phones
Uniden Dect1560 - For incoming calls it only rings 3 times. Is there a way to make it ring 6 times before it goes to voice mail?
Your model is a phone only, without an answering machine built in. This means that voicemail is provided by your phone service on your line, and that's where you need to adjust the rings before it picks up. The phone itself has nothing to do with it.
You may have to call your service provider for setup instructions because not all systems are the same, but here's how it usually works. Pick up your phone and call your own number to reach your voicemail. When your message starts, press the * button and the system will ask for your pass code (just like when you call to get your messages). Follow the voice prompts to reach the main menu, then mailbox settings, where you'll be able to change the ring count.
If these steps don't work for you, ask your service provider what you need to do.
Jul 24, 2011 | Uniden Cordless Phone
Set number of rings before voicemail iphone
This procedure allows your iPhone to ring for longer or shorter periods than the default setting of 20 seconds before voicemail answers. *** Attempt at your own risk but if you pay attention to the keys you input and follow the directions you should have no problems.
1. On your phone, dial *#61# and click Call
The screen will display:
Setting Interrogation Succeeded
Voice Call Forwarding
When Unanswered
Forwards to +1xxxYYYzzzz
Enabled
2. Write down the xxxYYYzzz number (including +1) - this is the number to your voicemail.
3. In order to make the + appear on the keypad in the next step you'll have to hold Zero down for a few seconds, then it will become a Plus (+). Dial **61*+1xxxYYYzzzz**30# and hit Call. +1xxxYYYzzzz is the number you wrote down previously, 30 is the delay in seconds. The delay can be set in 5 second increments, 30 is maximum.
4. Dial *#61# to verify that the new settings are active.
5. Verify working voice mail.
If you find you or your contacts are not being forwarded to your voice mail you have incorrectly altered your voice mail forward number.
To find out what it is and try again:
Dial ##002# and send. This will reset that forward number to factory defaults.
By then Dialing *#61# you will again display the your current (default) voice mail forwarding number.
Return to step [2] and continue.
*** Use this tutorial at your own risk ***...and if you have the time you can always give AT&T a call to have them change the number of rings on an incoming call before Visual Voicemail kicks in. I was able to quickly change the duration on my own, using these diagnostic iPhone GSM codes. The default time duration before Visual Voicemail intercepts the call is set by AT&T to 20 seconds. You will be able to add another 10 seconds yourself, but if you want your callers to wait more than 30 seconds before voicemail picks up then you'll need to contact AT&T technical support - they can change the duration to 45 seconds upon request.
Dec 19, 2010 | Apple iPhone 3G
How to you change the number of rings before voice mail kicks in?
Before the Auto Attendant picks up or an extensions voicemail?
May 20, 2010 | Avaya Corded Phone avaparp18d
Voicemail picks up too soon and New voice mail message always on
Check call waiting feature with mobile provider on number of rings to voice mail. Many problems repaired with booting phone (holding on/off button down till screen logo comes on & removing charged battery cleaning contact connections on phone and battery with DRY SYnthetic NOT cotton cloth ideally clean battery with alcohol swab let dry before returning to phone
Aug 07, 2009 | Vtech DS6111 Cordless Phone
Phone rings 10 times before voice mail picks it up, how do i change it?
In my VZ wireless I have to change it by calling tech support.
Your carrier may not offer it. Since your phone needs to be found, the number of rings you hear and the intercept time may be different. The stock answer is "if your cell is close to a tower it will work after X rings".
Carl
Apr 15, 2009 | Lands Phones
Receiving Fax using a phone line with voicemail on a Lexmark 5470
well, your voicemail can configure to key tone?? or have some one configuring options????
Nov 26, 2008 | Lexmark X1270 All-In-One InkJet Printer
Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
Oct 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Voicemail
Hi nexy - the best I can do for now is a couple things snd nothing definitive. Usually when a cell is off it takes 2 to 3 three rings before it goes to voice mail. When its' on about 5 to 6. There's a real good chance these are at the discretion of your service provider. That's my best bet. I've included a link to your manual in case you don't have yours. Look at page 50 (i think) and it tells about voice mail settings. You can go in there and take a look but don't get your hopes up. If this answered your question PLEASE rate as fixed. If your going to rate helpful or otherwise please don't rate. I've had many cell phones and I think I answered your question. So please rate fixed or not at all. I'd appreciate it. Thanks much nexy. Call you provider!!
http://www.wirefly.com/resources/phone-manuals/pantech/Pantech_C300_Manual.pdf
Jeff
May 18, 2008 | Pantech C300 Cellular Phone
Voicemail
It sounds like you are using a voicemail service from a provider, meaning you did not buy the voicemail system with the phone system. If you confirm, I can tell you how to fix this.
Apr 29, 2008 | NorStar M7310 Corded Phone
Lucent PARTNER18 Corded Phone Logo
373 people viewed this question
Top Lucent Lands Phones Experts
Paul C.
Computer Repairing
Computer Repairing
Michael Galve
Michael Galve
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
