Question about Panasonic CT-27SL15 27" TV
Pink screen My 12 year old panasonic 27' TV have a pink screen at channel position and red screen at Video1 or Video2. Last week it could work for 0.1-2 hours before turning to pink. Is it fixable?? Thanks.
  • InField Jul 24, 2008
    Sounds not very bad.
    The model is CT27SF21, 27", 1994. Now the screen is steady pink with good audio right after it is turned on both at channel or vedio position.
    Is it possible to be fixed under $100? Otherwise I just get rid of it. Need suggestions to make my mind. Thanks.
    President:
  • 1,284 Answers
Anything is fixable just a matter of cost or availability of parts.
Posted on Jul 24, 2008
  • Don
    Don Jul 25, 2008
    Looking at the cost maximum that you have set (and probably a good thing with the age of the TV) I would look at replacing it now as you will pay at least half of that just for a shop to look at it. I would almost bet you are looking a t a bad CRT (picture tube) and the cost on those will exceed $100 and that doesn't include the labor for installation and alignment. It could be the video driver transistors or what they call the jungle IC in the TV. In that case you will still approach the limit fast. Since that TV doesn't have a digital tuner in it I say replace it. That is my opinion and I have been repairing TV's for more than 26 (gulp) years now. Good luck and hopefully that information helps.
Video input
require pin to acces on demand
Dec 26, 2013 | Sanyo DS27930 27" TV
Pip now is on the souce menu whereas cable, video1, and video2 were there before. How do i get rid of pip and return to the former sources?
close the pip window first
if your tv/video button on your remote brings up
an input selection menu either press the number
of the ones you want or use the chan^chanv buttons
to select
Nov 29, 2007 | Zenith A27B33W 27" TV
NO PICTURE
Refer to the manual (free download here). Generally, a blue screen indicates a very low or non-existent signal. This can happen when the antenna is unable to gather enough of a signal from a particular broadcaster, or if an A/V input is selected, but the A/V device is not on or providing a signal. Since you are not seeing channel information when tuning, I suspect that the television is set to display an A/V input instead of the internal tuner.
With a working remote, locate the TV/AV button on the lower left (manual page 3 - item 8). When this button is pressed, you can choose to display signals on the ANT, VIDEO1, VIDEO2 or COMPONENT jacks. The ANT selection chooses the input on the RF jack such as an antenna or cable TV (with or without converter box). If using a cable box, the TV tuner should be set to Ch3 or Ch4 as determined by your cable box. Otherwise, select the VIDEO1, VIDEO2 or COMPONENT input that has the source signals you wish to watch from a cable box, DVD player, etc. that is connected to the rear input jacks. Page 7 of the manual details the connection and remote operation.
I hope this helps!
Apr 16, 2012 | Insignia NS- 27" TV27 TV
I have the toshiba 27 d46, cathode ray tube tv (old school) and I can not access the video1, video2, or video 3 content. I don't own the remote.
you can get a cheap universal remte at most stores that will work with it or you can use a remote offof a vcr or dvd player fromthe smae manufacturer.
Jul 01, 2011 | Toshiba 27D46 27" TV
We understand that your problem is: I have a Panasonic PT-53WX42 53 and I am trying to connect with the component connection but it will not cycle through component connection Just cable, video1,...
This problems,most of the times component cable are old and time passing and wheather conditions is ur ememy.Replaced the RCA component cable and do a hard reset the tv by unplug,replug it back like about and hour later.Go into ur tv menu and tries every setting to resetting back to the factory setting,this problems.Should be solved.
Dec 19, 2010 | Panasonic PT-53WX42 53" Rear Projection...
I cannot seems to get to the imput channels to play a dvd
on remote should be under video,,or input,,,on front of tv ,,i think input,,,or source,,it will come up 2 video1,,,video2 and so on
Nov 03, 2010 | Emerson EWF2703 27" TV
Light green and pink spots on my hd tv!!!
For the spots....
I had the same problem, first a blue spot then a green spot showed up. I contacted Panasonic Customer Support. They sent someone out and they fixed the TV for free. They reprogrammed the EEPROM chip in the TV. It is a defect. My TV was 4 years old and out of warranty. They came out last week.
So long as it is not happening by something you have done. It will be fixed free of charge. Call them, it solves the problem.
May 27, 2009 | Panasonic PT-44LCX65 Television
Help me fix my orion tv problem
Let it run an autoscan or see if in the menu it has channels that are blocked or disabled.
Nov 26, 2007 | Orion STV2763 27" TV
Sylvania 6432td 32" screen
You have to choose the right INPUT on your TV where your DVD player was connected. If your using the Yellow/Red/White cable from your DVD player you need to choose on your TV the input Example Video1 Video2, etc... If your using the COAX,(like cable wire) Put your TV on Channel 3 or 4. Hope this may help you. Please post the outcome, if you need further help. Is this TV is a COMBO?
Aug 13, 2007 | Sylvania 6427TE 27" TV
Panasonic CT-27SL15 27" TV Logo
469 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
