Question about Canon Office Equipment & Supplies
Canon ipf8000s can not cat the paper also gives hardware error 03800500-2f2f
Check your cutting wheel is in properly, have had a similar problem on a IPF8100, sometimes the wheel/cartridge just pops out
Posted on May 08, 2009
  • carlos
    carlos Oct 21, 2013
    me sale llenado de tinta como hago para q no salga eso es el ploter 810 canon ayudemeeeeeeeeeeeee por favor
Canon iPF8000s Hardware Error 03800500-2F2F and Inconsistent Cyan Color
Make sure all ink cartridges are installed securely and I would check to see if the Cyan cartridge contacts are clean and free of possible ink residue, dust, poor manufacturing of the ink cartridge or possible mechanism gease which could be causing hardware error and poor Cyan printing performance. If no problems found, then the printer itself will need to be replaced. Be sure to check if the printer has an extended protection plan that you've might have purchased with the printer. Most cases, not. Best of luck...... ; )
Oh! I forgot to mention, be sure to perform the printer head cleaning procedure.
Dec 19, 2014 | Office Equipment & Supplies
I have a canon ipf 8000 showing a error 03130031-2F26 what is the error
problem in the move of the carriage unit. Check visually if there is any paper inside the machine.
Check and come back later for more information
Mar 31, 2010 | Canon imagePROGRAF iPF8000 Printer
Paper stuck in Canon ipf9000 and now it is giving E161-403E code
this is a print head over heat indication.
If you try to turn off and turn on the machine see what will happen.
Otherwise you have to replace the print head.
Before you have to update the firmware to teh latest version.
Try to access the service mode in order to update the firmware if the error remains at normall operation
Nov 03, 2009 | Canon imagePROGRAF iPF8000 Printer
Leading edge detection error When loading paper into printer this is displayed on the lcd scren
This is caused when the size paper loaded into the machine does not match the size the machine expected. Check the paper size settings to ensure you are using the correct paper setting. This also can be caused if paper loaded does not align correctly.
Jul 09, 2009 | Canon imagePROGRAF iPF8000 Printer
Canon ipf8000 won't cut paper
Check to see if the cutter module has fallen off the print heaqd carriage. A common problem. It is a blue module that snaps into the left side of the carriage. Usually if it has fallen out, it can be found in the far left end of the printer, so you have to stop the printer, lift the lid and stick your hand into the left cave.
Dec 13, 2008 | Canon imagePROGRAF iPF8000 Printer
Canon Hardware Error 03130031-2F26
hi
2F26 is a carriage error,you can solve your problem if you update your firmware version to 1.35
if your printer firmware is 1.32 and below. try this link http://software.canon-europe.com/software/0027485.asp?model= follow the instruction included
Nov 12, 2008 | Canon imagePROGRAF iPF8000 Printer
Canon ipf 8000
Try to update the firmware version to 1.32 (latest version on www.canon-europe.com).
Then check the move of the carriage unit if any foreign object is on the move.
Last try a lubricate the shaft and replace the shaft cleaner.
Oct 08, 2008 | Canon imagePROGRAF iPF8000 Printer
Error code 03130031-2F13
03130031-2F13 A/D Converter external trigger output stopped
and the problem is main controler
Sep 04, 2008 | Canon imagePROGRAF iPF8000 Printer
1,051 people viewed this question
old marine
old marine
