posted by duckman123 on Jul 24, 2008
I have a DirectTV reciever,
VHS, DVD ,and I can't get DVD and VHS to play, or VHS to record
1 Other User Has The Same Problem
Comment by Bettylk3829, posted on Jul 25, 2008
Bought a new Zenith DVD Recorder/Video Cassette Recorder, Model Number XBR716 and want to know how to hook it up using Direct TV.
Solution #1
Hi-I used to be a DirecTV installer. Depending on the type of reciever you have, there are yellow/red/white or red/green/blue outputs on the back. You will need to run the dvd/vcr through these and then change the tv to video 1/ video2, or AVI, CV1, CV2, Front (or whatever acronymn your tv has) when you want to switch between the componet and the reciever.... you should only need to change the tv channel to be able to use the dvd player. I've found that vcr's usually need to be on channel 3 and if DirecTV is using ch 3, you may have to slide the button on the back of the reciever to ch 4 instead.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
Audiovox AVP7280 VCR
GE VG2050 VHS VCR
GE VG4060 VCR
Panasonic NV-HS1000 S-VHS VCR
Panasonic NV-SJ500 VHS VCR
Panasonic PV-8400 VHS VCR
Panasonic AG-1330 VHS VCR
Can you Help with these VCRs problems?
Panasonic AG-DV2000 Mini DV VCR
AG-DV2000 output is black &...
My AG-DV2000 has worked for... Answer This...
Panasonic AG-1980 S-VHS VCR
panasonic video cassette...
when viewing chanels using VCR... Answer This...
Quasar VHQ940 VHS VCR
vcr shuts off after about 30...
vcr shuts off after about 30... Answer This...
Repair Service
Find VCR Repairman Near You:
