Question about Samsung Heating & Cooling
THE REMOTE CONTROL UNIT FOR A DUCTLESS SPLIT A/C WALL UNIT HAS LOST ITS DISPLAY. AMONG OTHER THINGS, THERE IS NO THERMOSTAT TEMERATURE DISPLAYED, RESULTING IN NIOT KNOWING WHAT THE ROOM TEMPERATURE IS SET AT. THE BATTERIES ARE GOOD AND THE REMOTE TURNS THE WALL UNIT ON, BUT NOTHING IS DISPLAYED ON THE LCD DISPLAY (NOT EVEN THE SEPARATING LINES BETWEEN MODES). WHAT DO I NEED TO DO TO GET THE LCD DISPLAY WORKING PROPERLY AGAIN? THANKS, RICK DiMARZIO
  • 143 Answers
A new remote.
Posted on Jul 24, 2008
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
What does F2 error mean?
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 11, 2016 | Soleus KFHHP18 18,000 BTU Single Zone...
Remote will not communicate with wall unit
try repacing batteries-or/and turn off high voltage to system waite 5 minutes -turn back on---if this doesn't work call an hvac contractor or go on line for troubleshooting advice
Oct 13, 2015 | Sanyo 09KHS71 9,000 BTU Single Zone...
No power at interior unit. power everywhere else
If this is a mini split ductless there is a control wire with 3-4 wires inside (normally red, white, blue and green) that is connected from the outdoor unit to the indoor unit. This wire feeds voltage from the o.d. unit to the I.d. unit. If all connections at the o.d. unit are good, then check for voltage at these connections at the o.d. unit. If no power at these connections then a circuit board has faulted. Call a tech. and have a tech support number ready (1-800#) in case your service tech don't have it.
May 12, 2015 | Sanyo KHS0971 9,000 BTU Ductless...
Why doesn't remote control communicate with Fischer heat pump mini split system
It sounds like the batteries leaked and oxidized the terminals. If you cannot get them clean enough then I would suggest getting a new reomote from the manafacturer.
Aug 24, 2014 | YMGI R410A Ductless Mini Split 16 SEER DC...
Ductless split
Not familiar with this particular unit, but whenever the breaker trips it indicates a problem with the compressor motor. Check it for a short or ground.
Sep 04, 2013 | Carrier Heating & Cooling
LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
First check your circuit breaker or fuse that supplies power to the outside unit. It's probably separate from the inside unit. Then try to turn unit on. If the fan and compressor just make a humming sound then turn it off and check the capacitor if you have a multimeter. You can also look at it and see if the top looks expanded. That's a good sign its bad, but not all bad one's look expanded. Tomorrow I will have access to an LG service manual and can let you know what the code means. Sorry I can't get it sooner. Let me know what you find.
May 02, 2010 | LG LA185HV Split System Air Conditioner
''EMI'' heat w/ac acts weird.
Hi, what you have here is a ductless heat-pump split system. In the heat mode the compressor will run on a heat pump as it uses a reversing valve to reverse the flow of freon to heat your house. If it gets cold enough, the stat will call for the emergency heat strips to energize to come on for back up. Now, if the unit does not come on or go off when the thermostat calls for either heat or cool to come on and it just does it whenever it wants to, the stat will have to be replaced with a new one. If you plan on doing this your self, I would get the exact same heat-pump stat as you have because they make so many different models that the wiring may be much different and you will be lost when you go to wire it up. The heat - pump has many more control wires on them then the conventional heat/ac unit. So make it easy on your self and get the same one. They are easy to replace. If it is ignoring the settings its the stat. Heat strips and compressor running in the heat position together are normal for a heat- pump.
Sincerely,
Shastalaker7
Mar 17, 2010 | Heating & Cooling
20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Jan 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Heating & Cooling Logo
267 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
