Sharp FO 5800 Fax
Problem for Sharp FO 5800 Fax
Zaurus 5800 Question
By Odud - usenet poster
Can I use a Zaurus and modem to dial into and get access to the computer
nextwork (TCP/IP) at my work, i.e. can I use it as a VT102 terminal to log
in and use Pine (e-mail), read news, use lynx etc.  If so, will I be able
to do that with a 5800FX out of the box, or will I need to buy extra's,
and if so, what extras?
Thank you.
Solution #1
posted on Aug 11, 2005
Not Rated)
Rogers
Rank: Apprentice
Rating: 0%, 0 votes
In article <01bb71a1.1e70c180$821ed @Cyberus.cyberus.ca>, "George
Hi George!
Oh please oh please what is said auto log on script?
Good to see you on the compuserve Zaurus forum.
John Mckone, RPT
John W. McKone, RPT
Was this helpful?
Yes
No
Solution #2
Not Rated)
jessie25
Rank: Apprentice
Rating: 0%, 0 votes
To be correct all Zaurus models work perfectly OK with supported PCMCIA
fax/modem cards.  Of course not every PCMCIA fax/modem available on the
market has it's driver buit into Zaurus, but many of them do (a list of
supported models is available from SHARP).  Some of the not officially
supported models also work, like Megahertz XJ1144 PCMCIA 14.4 kbps
fax/modem.
The problem which all Zaurus models have is the screen refresh (repaint)
problem when connecting at speeds HIGHER THAN 2,400 bps to most services.
This is due to the fact that most of them (but not CompuServe, for
example) send high speed data as rapid bursts of information.  This causes
Zaurus to have the screen repaint problem.
This problem does not exist when connecting to BBS, ISP or whoever at a
speed of 2,400 bps or slower.  Even PCMCIA fax/modems work flawlessy
then.
SHARP's CE-FM4 "sidecar" modem has a maximum speed of 2,400 bps, hence the
above described problem does not appear when using this modem.
I hope this clarifies the issue.
Cheers,
R.J. (George) Czajkowski
74131.2 @compuserve.com
<31E37707.2 @interport.net>...
work very well with PCMCIA card modems.
but I don't buy it - it hasn't worked
Was this helpful?
Yes
No
Solution #3
Not Rated)
Hart
Rank: Apprentice
Rating: 0%, 0 votes
I set screen size to match Zaurus' display size (I use a set of Unix
commands embedded in my auto log on script to do that).  Once ISP's server
is set to Zaurus' display size everything works beautifully, ESPECIALLY
lynx.  Navigation is not a slightest problem, with properly defined UNIX
environment.
Cheers,
Addmitedly
Was this helpful?
Yes
No
Solution #4
Not Rated)
Charlie
Rank: Apprentice
Rating: 0%, 0 votes
I beg to differ on the PCMCIA card modem "problem" issue.  It all
depends on which modem you use.  I use a 14.4/14.4 Piceon fax/modem card
with absolutely no problems.  I use pine to check mail and even lynx to
do quickie web browsing (non-graphically of course).  Addmitedly
navigation is a bitch on that little screen in lynx, but when there's
info I need, I'll deal with the small screen.
:)Aaron
Was this helpful?
Yes
No
Solution #5
Not Rated)
maartenw
Rank: Apprentice
Rating: 0%, 0 votes
James,
The ZR5800 (and the rest of the Zaurus line) comes with a nicely done VT100 emulator. I've used it with no
problems to check email via Pine and run other shell apps.
One caveat, however: the VT100 emulator has a major flaw...it doesn't work very well with PCMCIA card modems.
Sharp claims that the problem is a handshaking limitation with the app, but I don't buy it - it hasn't worked
with 2400 baud card modems, either.
This means that you'll need to buy the Sharp "sidecar" modem, or get the FX version of the Zaurus that
includes this. It's a bit slow (the sidecar does only 2400bps), but everything works fine this way.
Personally, if you want a handheld for Internet apps, I suggest that you look at a Newton 130. It beats the
pants off the Zaurus in this area.
| Jonathan Hirschman   |   hirsc @interport.net  |
| NYC                  |   jonat @pathfinder.com |
Was this helpful?
Yes
No
Popular Solutions for Sharp FO 5800 Fax
Questions and Unsolved Problems for Sharp FO 5800 Fax
Do you recommend Sharp FO 5800 Fax?
Answer
Answer
Unable to send faxes on a Canon Pixma MX700
Answer
I am looking for a manual for phillips Magic 3 primo, can anyone give me a download link or copy.... (More)
Answer
I have a brand new Cannon Image Class MF4380dn. It prints and faxes - but will not scan.I have a... (More)
Answer
changed ink cartridges and machine still says there empty.
Answer
installing hardware on new computer
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp FO 5800 Fax:
Top Fax Machine Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Fax Machine Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
