Question about Microwave Ovens
Microwave door won't close
I have a nnt793sf panasonic microwave and the door won't close . the two hooks are loose and the door do not connect to the microwave. how can i f ix it?
thanks,
ruth f
  • Anonymous Mar 26, 2014
    the microwave door hook unable to
    close tight
  • Microwave Ovens Master
  • 9,086 Answers
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have critical safety & disassembly info at our site, linked here.
You can order Panasonic parts here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
  • 1 more comment
  • flyingchunk Jan 05, 2011
    Just fixed my microwave door thanks to this. Problem was indeed the piece of plastic securing the spring had broken. Not suprising! I just rigged up two screws wedged in the recess where the plastic piece was. When reassembling the door the plastic cover did not fit back due to the screws. I just heated up my screwdriver on the hob and melted away the plastic obstruced. looking at it you'd never know! Fixed in 10 minutes! Genius! Oh...I used a normal kitchen knife not a putty knife.
  • walleyestalk Jan 16, 2011
    Worked for me too, thanks!
  • Bradley Grupe
    Bradley Grupe Nov 23, 2012
    I had the same problem with a Panasonic NN-H965BFX where the tab broke. I hooked a paper clip around one of the plastic clips that hold the inner door assembly and then hooked the spring to that. The latch on this microwave has always been a little flaky and it works better than new now.
Thanks so much found the problem right away!!
Posted on Jun 16, 2012
One of the hooks on the door is broken. Why has oven stopped working?
The 'hook' on the door is a door catch and it has safety interlocks in the sockets in the body of the microwave. The door has to be firmly closed and all the safety interlocks in place before the microwave will operate.
http://panasonic.eu/ServiceCenter/en_GB/index_uk.html
Feb 07, 2016 | Panasonic Microwave Ovens
Door release buton does not open the door
You can disassemble the microwave oven and check out the release mechanism. You'll find several hooks that hold the door closed and a linkage mechanism to the door opening button. There may be a broken piece of plastic or maybe just a loose or missing screw that holds linkage together. In the case of a broken plastic part, you can fix it with a 2-part epoxy adhesive, but you'll need to permanently splint across the break with a piece of metal or strong plastic that you've scavenged from somewhere. Before epoxying the splint in place, rough up all plastic surfaces where you want the epoxy to stick well.
Good luck.
Mar 16, 2015 | Panasonic Microwave Ovens
Why does Panasonic nn-sn651 usually work; but sometimes, turntable won't start ?
This is an inverter model so there is no diode or hv capacitor.
You must adt. the door latch switch assembly to make sure that the door hooks make contact with the switches. Common problem is that the assembly is bent and must be perpendicular to the door.If it is bent the switch will not make contact with the door hooks.
Place a dab of lithium grease on the tip of the door hooks to ease closing the door. This is the cause of the bent switch assembly!
Aug 31, 2014 | Panasonic 1.2 Cu. Ft. Mid-Size Microwave -...
I have a Panasonic Microwave NN-A524 and I accidentally knocked the bottom hook off just as I was shutting the door. I can't get it to open now or work in any way but when I switch it on at the wall the...
I laughed my socks off. Without the door hook the door opening or closing mechanism is completely broken. If you have the time you could unplug it and dis-assemble the whole thing from the back and re-assemble it with a new hook, perhaps make a new hook from aluminuim sheet. I would throw it away and but a cheaper microwave.
Dec 14, 2013 | Panasonic Microwave Ovens
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Apr 02, 2013 | Microwave Ovens
Samsung microwave #SMH1611B door won't close
If it has the "double hook" type latch on the door,see if the hooks slide up and down.They should be spring loaded,if not,the spring attachment point inside the door may have broken off(my Sharp Carousel did this).I pryed the plastic door trim loose,and reattached the spring by using one of the slots inside to hold a metal wire clip(modified with needle-nose pliers) to hook the spring onto.Your door's design may be a little different,but a similar solution will probably be apparent after you get in there.
Dec 18, 2012 | Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Door on Sharp R-K520S won't stay closed.
check the hooks and door release button and repair or replace, when this is broken, the switch is not close the microwave will not START.
SEE the diagram
God bless you
Jul 14, 2012 | Microwave Ovens
Panasonic nnt774sf door will not remain closed. It appears the top plastic piece on the microwave itself (not on door)that the hooks latch on to is broken. Is there a way to fix this?
You can purchase parts for Panasonic microwaves but home repair is not recommended due to them being lethal if you do something wrong. I would find a good local repair shop and they should be able to find the part and repair. It might not however be cost effective, depends on the part price.
Mar 11, 2010 | Panasonic NN-T774SF Microwave Oven
Microwave Ovens Logo
4,968 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
