SOURCE: Noise when we are moving like a washboard. It's not loud.
yes it could be. check the noise with the hood open to find the source. You can use a two ft length of garden hose.
SOURCE: my 97 honda civic dx check engine light keeps coming on
Had this issue did you replace the exhaust
SOURCE: 2004 300m where is the vapor canister purge
On the drivers side under the hood toward the back not to far from the the strut housing.If you have the new one try to match it up by the looks :)
SOURCE: Check engine light comes on, car sputters, loses power
you need to change you crank shaft positioning censor
SOURCE: VSC/ Check Engine Light
My 2000 Lexus GS 400 just had the VSC/VSC off light and the check engine light come on. I would have to push the accelarator peddle all the way down to get it to go. Took it to the Toyota dealer and the code pulled up as the Throttle Position Sensor was out. Purchased one and having it put in. Will update if this fixes the problem.
1 Turn the ignition key to the "II" position.
