Question about Philips Magnavox 51MP392H Rear Projection Television
Coolant Repair Kit
I saw a link on one of your comments for a repair kit, but the kit is no longer listed there (or at least I didn't see it). Do you have any other suggestions about where to look for this kit? Any idea what it costs roughly?
  • courtneymf Jul 25, 2008
    Thanks! I just skimmed passed Phillips, looking for only Magnavox. That was dumb!
  • Philips Master
  • 8,617 Answers
Its listed under the repair kit catagory. They have the instructional CD by itself or the entire coolant kit which has the coolant and instructional CD. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jul 24, 2008
Where do I get a Remington 16" EL8 chainsaw repaired for what seems to be a Gear Train Failure. I need a repair outlet near Beaverton, Oregon, 97007
Remington Service Center Locater
http://www.remingtonpowertools.com/service_locator.cgi
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
I think your model is 107625. A complete "SPROCKET DRIVE GEAR BEARING KIT 747" part number "122511-01" is listed at $16.99
Are you aware Remington is no longer in production and most replacement parts are exhausted? Before driving to any repair facility please contact them. If you undertake the repair your self please call 1 (800) 475-5660 (have saw within arm reach). Inspect your saw and verify my model number matches your saw.
Please do not punish my rating because you are unhappy with RemingtonPower. I provided a very helpful answer, perhaps not the one you wanted to hear. Sorry
Lou
Nov 30, 2009 | Remington 16" Electric Chain Saw
Yello colour and fuzzy
the coolant will most likely need replacement. Heres alink to the repair kit which contains the coolant and detailed instructions on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
Jun 23, 2009 | Philips 43PP9202 43" Rear Projection...
Color and brightnes fading
the most likely cause is the coolant needs to be replaced in the CRTs. Very common problem. You can get the Phillips CRT coolant kit at the following link which contains the coolant and step by step instructions. Its listed under the repair kit category.
Mar 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 9P6034C 60... Problem
You need to change the coolant in the CRts ( picture tubes) you can get the Phillips coolant replacment kit at the following link with the coolant and the instruction CD with step by step instructions on how to do the replacment with pictures. Its listed under the repair kit category. Heres the link.
Aug 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
Shows alot of blue image/tv 60 in. rear.....
Sounds like the coolant in the CRTs need to be changed, Blue is always the first to congeal followed by green. Its actually a easier repair. I will post a link where you can get the phillips coolant replacement kit which contains the coolant required and an instructional CD with pictures of the process step by step. Heres the link its listed under the repair kit category.
Aug 04, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips 55 in. rear projection tv
You can get the entire to replace the coolant for less than what the tV shop wants to come look at it. And the kit comes with all the coolant for all three tubes and has the instruction CD which explains the entire coolant change process step by step with pictures. Its a very easy process with the CD. Plus they have free instant message tech support in case you need help. Its listed under the repair kit category, and its called phillips CRT coolant replacment kit.
Heres the link.
Aug 03, 2008 | Televison & Video
Changing the coolant fluid on a magnavox 6p6030
There is no free service manual for your model as its a large service manual that covers many models. You can however get the Phillips coolant replacment instructional CD, or the entire coolant kit with the coolant and instructional CD at the following link. Its listed under the repair kit category.
Same Problem with carloscor Philips Magnavox 55P8288A
the following link has the cd with instructions, or the coolant change kit which has the coolant and cd with instructions on the proceedure. Its listed under the repair kit section.
Jul 10, 2008 | Philips Magnavox 51MP392H Rear Projection...
I have a philips big screen tv that it's colors seem to be more green and red. It also seems a bit blurry. What's wrong with it? The model number is 9p5544 c102.
You need to change the coolant in the CRts and that will bribg back the vibrant color and sharpness like it was when it was new. You can get a CD at the following link which takes you step by step through the coolant change or you can get the actual coolant kit that contains 48 oz of high grade optical grade coolant and the Instruction CD. Both the kit and the CD are listed under the repair kits catagory. Heres the link.
Jun 29, 2008 | Televison & Video
I have a Philips Projection Tv. The color is not right. It is to pink and you can't ajust it.It doesn't look like it has any black. It is only 5 years old
Sounds like the coolant needs to be changed in the CRts. You can get a CD with complete Instructions to change the coolant yourself at the following link that has step by step instructions with pictures. Its listed under the repair kit catagory on the left side they have the CD available or you can get the complete repair kit which includes the CD and 48 ounces of high grade optical coolant. Heres the link.
Philips Magnavox 51MP392H Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
