Question about Bosch SHU9915UC Dishwasher
Is there a way to turn off the cycle completion signal. I have a Bosch SHY66C02UC/14
  • mattlandrum Apr 04, 2009
    I have an SHY model but have the same problem. The manual gives identical instructions for chaning the amount of rinse aid dispensed AND changing the volume of the cycle completion cycle (including turning it off).
    When I follow the instructions, the LED display behaves like I am doing the first one. I figured they just gave the wrong button in the manual, but it doesn't seem like the other buttons work.
OK, I think I have figured this out. Let me first give this important piece of information. The control panel for my dishwasher was replaced recently. That's why I now have to deal with this issue. I have a Bosch SHY66C model. As I stated in a previous post, the user manual I found on the web has identical structions for changing the amount of rinse aid dispensed and for changing the volume on the cycle completion beeper (or for disabling it). Following the instructions fixed the former.
Here is what I did
1) With dishwasher off, I pressed and held the "Delay Start Hours" button
2) I pressed the on/off button. The beeper begin to sound.
3) I released both buttons (not sure this step is necessary)
4) I repeatedly pressed the "Delay Start Hours" button until the signal turned off
(LED display showed 0)
5) I pressed the on/off button (not sure this still is necessary)
That seems to have fixed the problem. So, I don't know if the user manual is wrong or my control panel was replaced with one from a different model (such as the SHU9950 where I found these instructions).
Posted on Apr 04, 2009
Bosch Dishwasher Model # SHU53E02UC/14 started running about 3 times longer than it should and its not cleaning very well.
If the Rinse cycles completes within the normal time, but other cycles are slow - particularly a Heavy or Super Scrub cycle - it is most likely that the water heating is not happening or is very slow. The control will not advance (proceed) the cycle until the temperature sensor signals the control board that the water temperature is correct. Otherwise the control will wait, indefinitely, for the heating to happen. This also affects cleaning and drying performance. Loose wire connectors, bad heater, bad temperature sensors or a bad controller are possibilities.
Oct 10, 2016 | Bosch Dishwashers
Bosch end cycle beeping
The Self-Help section in your manual states you can adjust the volume or deactivate the beeping signal. Instructions on how to do so are supposed to be in the "cycle completion signal" section of the manual which it appears the tech writers forgot to include in the published version of the manual. I have not worked with this particular model so your best option now is to call their customer service number and talk to someone that knows how to turn it off. FYI, their customer service phone number is 800-944-2904.
Sep 02, 2012 | Bosch SHE3ARL2UC 24" DLX Recessed Handle...
Want to disable the alarm
To Set the Cycle Completion Signal Tone Level
• With the "CLEAN" and "SANITIZED" and "RINSE AGENT" Indicator
Lights flashing.
• Press the "Tone Level.
• As you press the "Indicator Lights illuminating and the Cycle Completion Signal
Tone level changing.
o If none of the Wash Cycle Indicator Lights are illuminated,
there will be no tone. The Cycle Completion Signal is turned
off.
o If one of the Wash Cycle Indicator Lights are illuminated,
there will be a low Cycle Completion Signal Tone Level.
o If two of the Wash Cycle Indicator Lights are illuminated,
there will be a medium Cycle Completion Signal Tone Level.
o If three of the Wash Cycle Indicator Lights are illuminated, you
will be at the maximum Cycle Completion Signal Tone Level.
• Press "START" to save your settings.
Dec 16, 2010 | Bosch SHX3AM05SS Stainless Steel 24 in....
How do you disable the cycle completion signal/beep on the Bosch SHU9915UC dishwasher?
Welcome to FixYa.
I think can answer your question..."How do you disable the cycle completion signal/beep on the Bosch SHU9915UC dishwasher?"
Follow these steps...
**How to Operate the Cycle Completion Signal**
1. Open door, hold down program button (see
Beeper Table below) and simultaneously turn the unit "ON".
MODEL Program BUTTON
SHU 9950 Delay Start Hours
**SHU 9910-9920 Delicate/Econo** should be yours
SHU 8800/8810 Quick Wash
SHV 6800 Delay Start Hours
SHV 4800 Delicate/Econo
SHV 4300 Delicate/Econo
2. Release program button.
a. For SHV 6803 and SHU9950 models:
The display will blink with a code of "0", "1" or
"2". You are in program mode.
• If the display blinks with a "0", you will hear
no signal (indicates OFF).
• If the display blinks with a "1", you will hear a
LOW volume signal.
• If the display blinks with a "2", you will hear a
HIGHER volume signal.
b. For all other models with the beeper
function:
• If the machine beeps, then the Cycle
Completion Signal has been enabled.
• When you push the button again and it does
not beep, it means that the Cycle Completion
Signal has been disabled.
3. To change the program, press the program
button until the desired setting is selected.
4. Turn the Dishwasher off to take it out of
program mode.
* At the end of a wash cycle, the beeper will sound
off two times, and again every 15 minutes until the
dishwasher is turned off.
Hope this answers your question and provides you with what you needed.
Thank you for choosing FixYa and good luck.
Please take a moment to rate the solution provided and a short testimony if you feel it's warranted, but also let me know if you require further assistance.
Regards,
Macmarkus :)
Oct 07, 2010 | Bosch SHU9915UC Dishwasher
After the wash cycle dishwasher beeps
Hello, welcome to FixYa. While I don't have access to my PC files at the moment as I am on my iphone, I believe this is the procedure for most B/S/H/ built dishwashers ( that means Bosch, Thermador, Siemens and Gaggenau ). To Enable or Disable the Cycle Completion Signal... 1. Open the door, hold down the ?Quick Wash? button and simultaneously turn the Dishwasher on. The ?Quick Wash? light will blink (program mode). 2. While the light is still blinking, push the ?Quick Wash? button. ? If the machine beeps, then the Cycle Completion Signal has been enabled. ? When you push the button again and it doesn?t beep, it means that the Cycle Completion Signal has been disabled. 3. Turn the Dishwasher off to take it out of program mode. I hope this answer's your question. Thank you for choosing "fixya". Please rate the solution favorably if indeed it was helpful, if not please let me know. Good luck. macmarkus :)
Jul 13, 2010 | Bosch 24 in. SHV4303 Built-in Dishwasher
Beep's incessantly after cycle is complete. How can we re-program it to turn off after one or two beeps?
Hello, welcome to fixya.
1. Open the door, hold down the “Quick Wash”
The “Quick Wash” light will blink (program mode).
2. While the light is still blinking, push the “Quick
Wash” button.
doesn’t beep, it means that the Cycle
program mode.
Good luck.
macmarkus :)
Jun 28, 2010 | Bosch SHU9915UC Dishwasher
Bosch Nexxt 500 Series Front Loading Washer
The only way is to disonnect the device from the controller board.
Sep 12, 2009 | Bosch Classixx WVF 2402 Front Load...
Hi: How do I turn off the beeping signal when the cycle is completed on my Bosch dishwasher? It's a fairly new model, with the control on the top of the door. Thanks, Jean Ferrario
I just tried this and it worked.
this Cycle Completion signal is a tone that sounds to alert you when your dishwasher finishes washing and drying your dishes. You can either disable the tone or set the volume.
to activate:
· press and hold the right “Cancel Drain” button then press and hold the on/off button.
· When the light on the “Cancel Drain” button you are pressing illuminates and the tone begins to sound, release both buttons.
· press the right-most “Cancel Drain” button until the tone is either at the desired volume or is silent.
· press the on/off Button. the Cycle Completion signal is now set.
Jan 22, 2009 | Dishwashers
Dishwasher bosch beeping noise
Found this on the Bosch website..... see 2nd to last step
This Cycle Completion Signal is a tone that sounds to alert you when your dishwasher
To activate:
· P ress and hold the right “Cancel Drain” button then press and hold the On/Off button.
· P ress the right-most “Cancel Drain” button until the tone is either at the desired volume
or is silent.
· P ress the On/Off Button. The Cycle Completion Signal is now set.
Sep 27, 2008 | Bosch Dishwashers
Detergent cup not opening on Bosch SHY66C02UC dishwasher
BEHIND THE INNER PLASTIC OF DOOR PANEL THERE IS USALLY A SOLENOID ACTUATOR MECHANISM THAT OPENS SOAP TRAY IT PROBABLY GONE BAD
Jan 16, 2008 | Bosch 24 in. SHY66C02 / SHY66C06 Built-in...
Bosch SHU9915UC Dishwasher Logo
458 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
