I have a rheem criterion II FURNACE (rpgh 10eamer) When hooking up a thermostat for air conditioning, the y terminal on the furnace does not turn on the outdoor compressor. Is there a way to configure the control board so that the y terminal is active and would control the compressor.?
  • 143 Answers
The thermostat activates the y command. The wiring passes through the furnace, but the furnace does not activate the compressor.
Posted on Jul 24, 2008
LX2000 gas furnace. It starts and runs for about 5 seconds, then why does it shut off?
Fix Furnace Flame Sensor (Flame That Goes Off) - YouTube
? 1:22
https://www.youtube.com/watch?v=fBJ3r9MUa-U
Nov 29, 2011 - Uploaded by RochNoure
A Furnace Flame Sensor is a safety device that reads the temperature and ... easy fix, but the furnace is ...
Troubleshoot the ignitor of the Rheem RGDA model gas ...
? 5:53
https://www.youtube.com/watch?v=Bx1pXONg2Oc
Dec 12, 2012 - Uploaded by grayfurnaceman
Troubleshoot the ignitor of the Rheem RGDA model gas furnace.... Jun Sim 5 months ago ... My lennox ...Missing: lx2000
Rheem Criterion II No Heat - YouTube
? 0:47
https://www.youtube.com/watch?v=yOSk6qvpWbA
Jan 7, 2010 - Uploaded by Work12Progress
Rheem Criterion II gas furnace model # RGPH-07EAMGR. When a call for heat is made t wo green led's ...Missing: lx2000
Heater will not kick on unless... [Archive] - Self Help Forums
www.selfhelpforums.com/archive/index.php/t-2153.html
Oct 19, 2004 - 25 posts - ‎9 authors
After a certain amount of time of not running, the heater will refuse to kick back on. ... 2 flashes, then a 2 second pause = pressure switch is open. What do .... On LP gas furnaces, the spark starts and the gas valve opens. ... Buffing them up with a little steel wool (5 minute job) is a good annual PM thing to do.
Dec 16, 2015 | Heating & Cooling
I have a Rheem Criterion II gas furnace. I have been looking for the filter. Where is It?
Whatever side the cold air return stack enters into the blower unit of the furnace.
Mar 02, 2015 | Heating & Cooling
I have a Rheem Criterion Furnace that won't stay on! Starts and stops 3 times then shuts off!
Check air filter is clean , jump out pressure switch see if it lights
Jan 08, 2013 | Heating & Cooling
I have a rheem criterion ii a/c and furnace. The power source from the a/c outside unit is not hooked up inside. Where on the unit indoors does the wire attach.
two wires go from the inside unit to the outside unit. Y terminal and C terminal (both low voltage). Power should come from circuit breaker panel (20 or 30 amp double breaker).
Jun 11, 2010 | Heating & Cooling
My Rheem oil furnace is coupled with Rhuud heat pump. Oil furnace runs on emergency mode only and heat pump doesn't work at all!! Now the oil furnace will not even fire up even on emode.
Try and jump it out by taking the wire hooked to R and W terminals on your thermostat and connecting them. It could be you have a bad thermostat.
Feb 11, 2010 | Ruud UBHC Air Conditioner
Are there any recalls on a Rheem Criterion II Model No. RGPH-05EAUER in WI? I have a house that was built in '98. The furnace doesn't dry out the air enough and tons of moisture has built up in the house...
there have been several situations wht rheems as far as control boards cracked heat exchangers cracked inducer assemblys and touchy pressure switches i would call to get a furnace inspection from a rheem dealer
sounds like you really need to buy a portable dehumidifier
Jul 06, 2009 | Heating & Cooling
Rheem criterion II flame stays lit for a few seconds then only cold air blows through the house
Your furnace needs a tune-up. MODERN FURNACES REQUIRE REGULAR MAINTENANCE!
Mar 10, 2009 | Goodman GMS90703BXA Heater
I have a Rheem Criterion II Gas furnace. It is not igniting.  When I switch the thermostat to "heat" - the furnace doesn't not start.  There are 2 green lights - one is one and the other is blinking.  The...
Roscoe007 shouldnt speak unless he knows what he is talking about, as a heater installer i am telling you the ignitor needs to be replaced, the very fact that the ignitor does light for about 30 sec than goes out rules out any issue with the themostat, replace the ignitor!
Dec 13, 2008 | Water Heaters
Heating & Cooling Logo
291 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
