Question about Brother HL 5250DN Laser Printer
Brother 5250 DN Paper Jams
The Printer is about 10 months old now and it seems to jam almost every time that a print job is sent. The duplex function is on and it seems to print the first side, but constantly jams while printing the second side ( when I clear the jams only one side has been printed). I am using standard 20lb paper and have cleaned the unit multiple times with compress air and wiped down other parts according to the brother maintenance. I'm not exactly sure what else to do, any help would be greatly appreciated.
thanks.
Paul
  • Anonymous Jul 25, 2008
    I have the same problem. It started after my first drum replacement, right around one year (the end of the warranty.) I called Brother and they said the solution was to use heavier weight paper. That did not help for long. When it works it works great. My solution will be to not purchase another Brother product.
  • 138 Answers
You problem is actually in the pick-up roller and separation pad areas. the paper is delaying and not making it through to the next check point in the machine fast enough.
1st
Take it by your closest Brother Service Outlet. They're in the phonebook under "Computer Service & Repair". It's a cheap fix but requires parts.
2nd
Use good paper. Paying a little more for paper will save you a lot over time in repairs and premature toner and drum failures. Brother printers are really finicky about paper quality. Recommend "HP Office" brand paper as a minimum. It's a known good paper for general everyday printing and won't break the bank.
Posted on Aug 26, 2008
I have a paper jam at the back of my printer, where do i open it
Hopefully this will help you. Good luck !
Causes of jams
NOTE If you are experiencing jams in the duplex paper path, make sure that the duplex-tray
lever is set to the correct media size for your country/region. Open the duplex-paper-path door
and look at the embossed arrow on the lever. Make sure that it points to the media size for your
country/region. If the size needs to be changed, push the lever all the way in for duplex printing
on letter- and legal-size media, or pull it all the way out for duplex printing on A4-size media.
A4
LTR,
LGL
A4
LTR,
LGL
Occasionally, paper or other print media can become jammed during a print job. Some causes include
the following events:
? The print media that is being used does not meet HP specifications.
? The media is damaged or has objects attached to it, such as staples or paper clips.
? The environment in which the print media was stored is too humid or too dry.
? The input trays are loaded incorrectly or overfilled, or the media guides are not set correctly.
? Too many sheets have accumulated in an output area, or sheets are blocking an output area.
? Media is added to or removed from an input tray during a print job or an input tray is removed from
the all-in-one during a print job.
? The cartridge door is opened during a print job.
ENWW
Mar 13, 2015 | HP LaserJet 3300 All-In-One Printer
How can I stop paper jams when using duplex printing?
1. Replace "Roller top out put bin" (RL1-0527-000CN)
2. Clean duplexer unit & chk the rollers in size change assembly(RM1-1318-000CN)
Apr 29, 2014 | HP LaserJet 1320tn Printer
Duplex printing with card stock paper jams in back on Brother MFC-9840CDW
I would try manually inserting the paper for the back side. Most of the time it's best to wait a few minutes before trying the back side to give it time to cool so it will lie flat.
Sep 08, 2017 | Brother MFC-9840CDW Laser Printer
Brother mfc 8670 paper jam duplex
remove the small, or scratch into pieces inside the duplex to clear the paper jam.
Feb 10, 2014 | Brother MFC-8670DN - 30 PPM Multifunction...
Printer jams only when I put paper into the tray, and not when I feed the paper manually
in your paper feed tray there is a paper separation pad which is setup on a spring.just scratch it with some fine sand paper and clean with IP solution.
May 27, 2012 | Brother HL-2040 Laser Printer
Hello, I just bought a brother hl-5370DW and am trying to use it to print out manuals for a class of mine using the duplex print but after a few papers print the paper going back in jams and it tells me i...
I just returned my HL-5370DW printer to Staples. I only had it for 3 days and found it running hot, warping card stock and envelopes, and jamming regular size paper constantly. It appears to be OK for very small print jobs but not very robust. I did like the duplex printing and the price. I do not believe there is a solution other than replacing this printer.
Xelzbear
Aug 06, 2010 | Brother Hl5370dw High Speed Wireless Mono...
The paper gets jammed when I'm duplex printing
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry. Keep printer unplugged for about 2 minutes and replug and try a test print. Also make sure that you have waited long enough for the printer to heat up before giving a print job. Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Aug 19, 2009 | OKI C6100n Laser Printer
Brother 5250
I had the same problem on 4 Brother HL-5250's, I checked the whole printer, and couldn't find a paper jam, yet the red printer light wouldn't shut off. I finally followed the instructions on Brother's website for removing a paper jam, and the solution for all 4 printers was paper stuck in the fuser cover. See below on how to open the fuser cover.
Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
  2. Hint
  3. There are 2 kinds of covers at the rear of the printer. Please make sure to open both the back cover (step 7) and the fuser cover (step8).
  • May 27, 2008 | Brother HL 5250DN Laser Printer
    Brother HL5250DN Printer duplex problem
    I have never seen that happen on one of these.
    check to be sure that they go backward at the end of printing, they may reverse on startup
    I think maybe you are missing the door that sits inside the rear door (called outer shute assy). When you open rear door there should be another before fuser.
    How old is this machine, because there is a fuser and outer shute and cover mod, that goes in to early product run of this model. Machines affected are from the Initial production up to and including Serial No.'s K6J702822 (last 9 digits of S/N), this mod is to help with paper curling at exit causing jams.
    Nov 08, 2007 | Office Equipment & Supplies
    Paper jams
    The Pickup roller of the printer is not properly aligned, send the printer to repair and see the jam
    Sep 29, 2007 | Brother HL-2040 Laser Printer
    Brother HL 5250DN Laser Printer Logo
    1,078 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Jim Keysor
