Question about Sony Video Cameras
Date and time superimposed over footage-HELP- IS THERE ANYWAY TO REMOVE IT. THERE ARE A FEW TIMES DURING THE FOOTAGE THAT THE DATE AND TIME DISAPPEAR AND AFTER A MINUTE OR SO IT RE-APPEARS.
HI,
I shot footage with this camera and had the date and rec set to on- big mistake- now the date and time is superimposed on footage- there are a few times- when that information disappears but after a minute or so it re appears. Is there any way to remove that information during play back-please help- any advice- i had no idea this would occur and don't know if 'super imposed ' really means 'burned'
my email- chitchatfilms@yahoo.ca- or meccafilm@yahoo.com
please help.
brishkay
  • 2 more comments
  • chitchatfilm Jul 25, 2008
    the model of this camera is sony hdv
    Sony HVR-A1U sony hdv/ mini dv recorder. I recorded hdv.
    can i get the date and time removed? any way
  • chitchatfilm Jul 29, 2008
    I shot footage on a sony Hdv 1080i HVR_A1U camcorder- the date and time rec was set at on and as a result the date and time is now superimposed on top of the picutre- is their anyway to get this information removed- I am not sure if superimposed is the same as burned- hope not- but in the manuel it says "it will be superimposed over picture"- please help- this is really important footage and a dumb mistake resulted in this- let me know if there are any softwares or even some really expensive way of getting it removed. I have no choice but to work with this footage.
    On this camera, one has choice to set the date-rec switch on or off- if it is set to on- then the date and time is automatically superimposed on it- now -i shot with the switch being on and now have the date and time superimposed on my footage and my question is - can I - during playback or editing- get this date and time removed or not to show-please help
    Date code is already at off- and date and time still shows during playing back- manuel does not offer any help about how to remove it- I guess I am burned! although still hoping not to be.
    Master:
  • 497 Answers
Why not adjust the size of ur video and then just blur it or mask it...
Posted on Jul 29, 2008
  • Yaz  S
    Yaz S Jul 29, 2008
    There is a trial version you can try at www.puremotion.com
    u cud try this site to smudge the picture at the date and time location
    hope this helps!
    Thanks for using Fixya
  • 4,234 Answers
With the settings set to include the date and time during the recording process an internal character generator creates the date and time and this is merged with the video signal from the CCD before recording. Since the merge occurs before the recording, they are part of hte same "picture" that is being recorded. The short answer is no, you can not separate these two images as they are at this point a sinlge image. High end pro decks contain what is called a time code that is recorded on a separate track. In that case, the "monitor" output from a tape deck will show the time, while the standard video output will not.
Hope this helps,
Dan
  • 10,594 Answers
I think, during editing of movie, you can superimpose part of same picture on date n time data, so resulted no image of date n time on movie.
  • Shahid Electronics
    Shahid Electronics Jul 29, 2008
    Hello again,
    Regarding your camera date problem, Go to camera menu> Display out> select LCD.
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
Click this link for download the manual and check the setting is correct is to set or not?
www.vasst.com/HDV/hdvimages/HVR-A1Umanual.pdf
Thanks
Good luck
Don't forget to rate the solution
  • Asfiya Ahamed
    Asfiya Ahamed Jul 29, 2008
    Dear sir/madam,
    Once video is recorded with that option active there is no way to
    remove it. It is permanently embedded in the digital encryption on your
    tape. However If it is shot on a 4x3 aspect ratio (not wide screen) the
    cheapest way to do it is to put black bars over your footage to make it
    16x9 ratio and in return, remove the time stamp.
    OR!
    Expand your movie (make it larger by zooming into it) and from zooming
    into it, it should remove the time stamp on the corner. You can make
    your footage larger with such programs like Adobe Premiere, After
    effects or Magix Edit Pro.
    thanks
    good luck
    "Don't forget to rate the solution"
  • Sony Master
  • 19,396 Answers
What is the model of your camcorder?
Posted on Jul 24, 2008
  • 3 more comments
  • Ginko
    Ginko Jul 24, 2008
    Check screen indicator settings and display settings in your user manual, post model for more help.
  • Ginko
    Ginko Jul 29, 2008
    The time code is not superimposed, it only appears if you play back using the camera, here is the manual, but I did not find the procedure to remove date and time.
  • Ginko
    Ginko Jul 29, 2008
    Go to Standard Set Menu and set DATA Code OFF.
    Check pages 64-65 of manual to find out how to remove, if you still get data recorded in movie, then I am afaraid movie had been recorded with data and the only way to remove it is to zoom into the picture or to cut the picture.
  • Ginko
    Ginko Jul 29, 2008
    The point is, if the date had been set on while recording, then the date is overprinted in the movie, in this case the only way to remove it is cutting the movie, sooming in, or putting a logo on top of the date, as the pixels on the date area cannot be reverted to what you were shooting.
    Try first removing the display date option following instruction from manual , just in case you have set the date in playback only, in that case the date won't be in the tape movie, but only on display.
  • Ginko
    Ginko Jul 29, 2008
    Thanks
My cam only records 17 min of footage at a time???
This sounds like it's one of two things: 1 - it's an over heating issue. This is to ensure than nothing gets damaged on the mother board or inside components - this most often found in Canon products. This is a very good feature. 2 - since you said it doesn't stop recording, it's merely make a cut point, it's more than likely cutting the footage to fit the FAT32 hard drive rules of not exceeding 4.4 GB of date for a single file. This is to help with post production work flow so you can edit easier and your system won't be as bogged down. All around this is a good feature. Helps in post production greatly.
May 09, 2014 | Sony Handycam HDR-CX160 Camcorder
How do I get time date stamp to show on video footage taken with JVC Everio GZ-HD620
The AVCHD file contains the time date stamp as subtitle track. Any player that can show subtitles can show the time/date stamp (I use Videolan Player).
Usually, after downloading the avchd files to my computer, i do an OCR on the sub file and convert it to .srt, as well as conver the avchd into .mkv and include teh subtitle file into it.
Dec 01, 2012 | JVC Everio GZ-HD620 (120 GB) AVCHD...
How to insert date
This Camera does not have the feature for superimposing the dates on images. The new models do not have the feature of superimposing directly as many customers did not want this feature because accidentally they had this option On and the Date and Time stamp got printed on the photos even they didn't want it.
However, the new cameras that are equipped with the EXIF technology gives you an option to superimpose the date and time later by using compatible EXIF software. When you print the images at a shop, images can be printed with the date if you ask them to do so.
You can use the Picture Motion Browser Software for inserting the date and time. Click here for the steps to insert the date using the Software.
You can also connect the camera to a Pictbridge compatible Printer to print the images with Date and Time. You can also use the MS Paint to insert the Date & Time.
Thanks for using FixYa.
Feb 04, 2011 | Sony Cyber-shot DSC-W80 Digital Camera
I need to get footage off of my camera, but it says I need to connect to my AC Adaptor, and I have no idea what that is. Also, do I need certain software to put this on my computer?
If is asking to connect to the AC adaptor means that your power adapter must be pluged in to supply power wile connected to the computer.
The software need it in your computer so you can watch the footage would be http://www.videolan.org/vlc/ but windows media player usually does the job as long as is upto date!
Anyway hope my reply helps you.
Nov 27, 2010 | Panasonic SDR-H40 HDD Camcorder
Hi i need to put the date/time stamp onto my footage. So i can present it in court..please help Adam
Google BatchPhoto and download the software. The program has a free 30 day trial and it'll add the date/time stamp to your photos. BatchPhoto can read the original date/time when the photos were taken from the embedded EXIF data. It can add the date/time on dozens of pics very fast and in one operation. Also it offers extensive options for setting the timestamp: the font, color and even the text's transparency can be adjusted, also the date format as well as placement of the stamp are fully customizable.
Sep 02, 2010 | Cameras
Time and date not coming in the print
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C410907&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=147252374&stateId=1 0 147256393
time and date are not superimposed on 2006 cameras and later. However it can be printed:
Solution
sp.gif sp.gif Current camera models (after 2006) do not have a superimpose function to display the time or date stamp on pictures. However, the time and date can be printed on images from a computer using Picture Motion Browser software. Additionally, if the camera is compatible with Canon® PictBridge™ technology, the time or date can be added to a picture by a printer that also has built-in PictBridge technology.
NOTE: When time and date stamp information is superimposed on an image file, it cannot be removed without editing or cropping the image. Therefore, the function to superimpose the time and date stamp was removed from newer-model cameras to prevent users from accidentally overlaying the information on images when the feature was inadvertently turned on.
Aug 02, 2010 | Sony Cyber-shot DSC-WX1 Digital Camera
I have a Sony HDR-SR11 and the time/date stamp is on all my videos? How can I remove it? The simplest solution would be much appreciated.
I believe that you can select the DISP button on the left side of the camera to make the date and time display disappear from the viewscreen on the camera. I do not know if this will remove it from the footage that you will need to download to your PC or DVD. If you have downloaded it already you may need to select the DISP (for display) button and then re-download the movie footage.
Mar 28, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
SHR-1040 - rewind from end of footage??
I'm wondering if the firmware can be upgraded as that might be the easiest thing. My other thought was that putting the hard drive into a PC and trying to view the video might be a way to see it.
Nov 14, 2007 | Samsung 4 Channel Dvr
Capturing GR-PD1 Hi-Res clips in Final Cut Pro 6
Check out: http://jvcgr-pd1.blogspot.com/2005/07/dealing-with-pd1s-format-m2t-or-mpeg-2.html Use MPEG Streamclip to convert m2t to a useable file (MPEG).
Aug 27, 2007 | JVC GR-PD1 Mini DV Digital Camcorder
Video Cameras Logo
620 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
