Question about Nokia 5230 Cell Phone
My Nokia 5230 wont charge. I believe that the very small charging port is not passing on the power. The battery can be charged in another similar phone. Our charger will charge the similar phone. So it all points to the charging port being suspect. Is there a cheap solution? Can I charge the battery outside the phone?
SOURCE:
  • 67 Answers
SOURCE: Nokia 3250 charging problem
you must change the charging block /base pluck or go to the service provider will do it for you. advice by dogy.
Posted on Dec 21, 2007
jaffi
  • 8 Answers
SOURCE: NOKIA 6630 displays not charging when connect charger
hi dude,
>>> dont remove any thing from u r mobile, first confirm the problem where it is...
>>> first try to put the charge by using other charger... still u r getting same problem means change the charging unit
>>>good luck... thank u....
>>> dont forget to rating the solutions...
Posted on Feb 16, 2008
mohammed387
  • 1952 Answers
SOURCE: nokia 2300 charging problem
just adjust or change the pin in mob
Posted on Feb 23, 2009
270rexton
  • 782 Answers
SOURCE: nokia 5800 wont charge?
Use different charger. When charging leave the phone off. Fully charged after 4 hours.
Posted on Jun 10, 2009
  • 105 Answers
SOURCE: my nokia 6500 slide does not charge i have bought
it is the charging port that has a problem, so you have to change it.
rate this
Posted on Nov 23, 2009
The battery on my 5230 wont charge up even tho its on the charger overnight ,ive charged it externally ,that is connecting the pos and neg from the charge lead diectly to the battery pos and neg this way...
just use a ziner diod neg leg of ziner sold to positive of charging connector and positive of ziner to battery connector plus ur problem will be solved
u can find ziner diod in old mobile like 1100 , 3300, 3310, 6600 etc.
Jun 06, 2011 | Nokia 5230 Cell Phone
My n96 16gb wont charge but battery charges in another phone
Hi, if you N96 is not charging when plugged to a power supply outlet and the battery charges in another phone, then it obviously means the charging i.c in the phone is bad thereby affecting the charging port.
You need to get the phone to a mobile phone repair tech to replace the charging i.c. Meanwhile you can use a desktop charger to charge your battery pending the time you fix it....
Feb 26, 2011 | Nokia N96 Smartphone
I have a 5230 and ive lost the settings menu
Call the store where you purchased the phone and ask to have the operating system re-installed for you. There is usually no charge or small charge for this service.
Oct 28, 2010 | Nokia 5230 Cell Phone
I want to rerset my cellphone battery ,i have a nokia 5230 and i never charged the battery full the first timeand now it only lasts one day
Hi, you can not reset a battery. A battery can only get weak to power up a phone for too long due to the battery cell inside the battery that is weak and can power the phone for too long.
When you replace the battery with a new one, and charge the battery for about 4 to 6 hours, and insert the battery inside the phone. Then you can now say..Problem solved...
Thanks for using fixya.....
Oct 20, 2010 | Nokia 5230 Cell Phone
My LG-VX9200 wont turn on and the battery wont charge. I assume is the battery, its a practically new phone. It hasnt get wet either. What can it be? Thanks in advance
Before you conclude that the battery is the problem, i suggest, you get a similar charger to charge your phone first, if the similar charger charges the phone, then, ii means you are having charger problem, but if it does not charge the phone, you should be considering the idea of getting another battery to see if it will charge on your phone.
The problem can also be that, the charging port of your phone is bad, you can use your charger to charge a similar phone and see if it charges, if it does, then, the problem is either th battery or the charging port.
Check the following one after the other to detect what the problem is,
1. Try use a similar charger to charge your phone to see if it will charge.
2 Get a battery from someone that as a similar phone to test your phone to see if it will power up.
If it works with your phone, get a new battery for your phone, the one you have on it is dead and will need to be replace.
Take care.
Jul 18, 2010 | LG enV3 VX9200 Cell Phone
My sanyo pm 8200 wont hold charge!
Since the battery and charger are new and yet it does not still hold charge.
Have put the battery in another similar phone and try to charge with your charger to see if it will hold charge? if you have.
It means the charging port of your phone is bad and you will need to replace it.
The charger is not charging the battery in anyway because the charging port is bad, so just change your charging port, your phone will now hold charge.
Take care.
Apr 14, 2010 | Sanyo PM-8200
Nokia 6300 my cell phone shows charging on screen but still not charging cell phone battery. can you suggest me solution of charging battery?
hello,
I suggest you remove the battery and test it with another similar phone to see if it will charge, if it does, it means the battery is ok but if it did not, it means the battery is bad and need to be change.
But if the battery is good, it means the charging port is bad, all you need to do is to change your charging port because that is the next action place to check.
Looking at this two areas should profile a solution to your problem.
Thanks and wish you best of luck.
Feb 06, 2010 | Nokia 6300 Cellular Phone
Nokia 5230 Cell Phone Logo
374 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Damen Wong
Damen Wong
