Question about Samsung SGH-D900 Cellular Phone
No charge my d900 which is 2 yrs old will not charge.i have been told it is either just the charger block,which can be repaired or unrepairable if it is the power card itself.as i have read a lot of other users are having the same problem,surely samsung should repair free.i know the phone is out of warranty,but this must be a design fault.please help
    President:
  • 625 Answers
It very well could be the charging port. As for getting samsung to repair for free, willnot happen. As long as it lasted through the warranty period they are satisfied with the design
With a bad charge port, You have 3 options.
1. get it repaired, warrant if possible
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay.
For more information and links to the parts check the following link below.
Samsung SGH-D900 Broken Charging Port Repair
Posted on Aug 18, 2009
Testimonial: "thank you"
Samsung w259 charge battery
Hi prosenjit,
please try with another battery.
i think the new battery is not good.
regards,
nuwan
Jan 08, 2014 | Samsung Cell Phones
Battery charger reads battery full when dead
The battery is no longer good. You will need to buy a new battery. Don't over charge your batteries. They all vary. Expensive cordless tools will come with a charger that shuts off automatic to prevent over charging. I own cheap Skill drills that has served me well. These batteries lasted over 11years. It makes no sense. They should not have lasted more than 5 yrs., even 2yrs. I make sure I never over charged them, but they should not last that long. Freaky. Your battery is dead forever, sorry. I have others just like yours waiting to be recycled.
Sep 29, 2012 | GRACO INC TrueCoat 18V Lithium Ion Battery...
The life of my battery is too short..that's ;;why I always use my laptop with tha charjger on..
How old is the unit? On average if used only a few times a week good for 3 to 5 yrs. before no charge at all. As time goes on the charge will get to be shorter and shorter. If used every day and always plugged in 1 or 2 yrs the battery will be dead to almost dead. If the unit is not very old then quickly get it replaced via warranty from the MFG or the retailer who sold it to you. You can get a battery (Probably) from the MFG for around $40 to $75. You MAY be able to find one at www.walmart.com or www.bestbuy.com or ebay or amazon. Beware of the auctions, some bad people sell regenerated batteries only good for a few times then trash. There is a possiblity that the "Charger" is not charging completely. If that is the case then one of two problems, either the voltage is too low from the BAD charger or the "Charge cycle" is cutting off too soon. You can test for low votage easly with a simple and cheap $10/$15 multi meter. The charger should say what "Output voltage" it should have on the unit. If the charge cycle is bad, you need some one with the correct equipment to do a charger test. Walmart, best buy and others carry some generic chargers also. If you know anyone with the same charger (best if exactly same MFG, but exactly the same output different MFG should work ok also), you can use theirs to see if that fixes it, if so you need a charger.
Jan 04, 2011 | HP Pavilion dv6110us Turion 64 X2 TL-50...
My DeWALT 18v drill will only hold minimal charge. I took the drill and battery to my local home depot and was told that the batt checked fine it must be the charger but i wasnt totaly convinced. any...
I bought brand new replacement batteries from Grainger Supply.Charged the batteries and they would go dead without even using them.When you did use them they were good for only a few minutes.Called Grainger,they called DeWalt and found there was a recall on the Yellow topped batteries I had just bought.I don't know what series but they were the yellow topped 18volt batteries.Hope this helps?
Jan 14, 2010 | Drills
Goes from fully charged to almost zero charge in seconds
HI,
Please make sure the charger is working.I suggest you try replacing it with a new charge and then give it a try.The problem can also be with the battery if it is more than 2-3 yrs old.In this case the problem is with the battery.
So i suggest if the battery is more than 3 yrs old buy a new one and then test it with the old charger and if the battery is not old then replace it with a new charger and try charging the battery.
Let me know the result
Jul 02, 2009 | Samsung BlackJack II Smartphone
Draining battery
This camera has had problems with the primary switch block faulting. The camera will power up all by itself when unattended and drain the battery. Another symptom would be the battery refuses to charge fully because the camera must remain in the "OFF" mode for the charge process to begin. Sony in Laredo, TX is replacing these controls at little or no cost, I would call them to see if they will repair this for you. Hope this helps you. Joe Weibel Custom Electronics (customelectronics.org)
Feb 11, 2007 | Sony Handycam DCR-HC40E Mini DV Digital...
Samsung SGH-D900 Cellular Phone Logo
85 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
