Question about Panasonic Panafax UF-585 Plain Paper Laser Fax
Error 011 Panafax 585
Even after installing & re-installing the paper cassette still the same problem. What is the next step should I follow.
  • pivi7532 Jul 25, 2008
    Finally I found the problem. It is the paper cassette. The elongate part which acts as a sensor was broken. It was hard since this was the first time I looked at the cassette. Replace with new paper cassette and the machine works.
The extension at the back of the tray has broken off, so the machine doesn't recognize that the tray has been put back in. Solve this by taking a piece of cardboard (business card works good), fold it up and insert it into the sensor at the far left where the extension would have gone when the tray is inserted. This will trick the machine into thinking that the paper tray has been inserted.
Posted on Oct 03, 2008
Still working on it. I understand the problem could be in pick-up feed assy or clutch or sensor.
Posted on Jul 25, 2008
Alarm - check cassette info code 011 - what is
The tab on the base of the paper cassette is broken off.
How to cheat it:
Remove the paper cassette
remove the tray in the back
remove the toner cartridge
set the machine upright
Wad up a small piece of electrical tape and shove it into the small black u-shaped sensor on the left side bottom.
it should work OK after this.
Nov 20, 2009 | Panasonic Office Equipment & Supplies
Beeping sound coming from machine! When I take out the paper tray, the annoying beeping sound goes off; the second I put it back in, the beeping starts again.
Is there an error message in the display such as 011 ?
Try this
open top cover
remove toner cart
press
function
7
monitor key slowly 4 times
6
scroll down to ALL JOB CLEAR
set
wait for the machine to reboot
Nov 10, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
We cannot recieve faxes check cassette error code 011
The small tip on the left side of the paper cassette is broken off.
wad up a small piece of electrical tape up and stick it into the black u-shaped sensor hole where the tip used to go in.
Jul 07, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
Panasonic Panafax UF-880 Plain Paper Laser Fax - Info code 011
Remove the paper cassette completely, look in the cavity for a broken magnet or crumpled up paper. The machine thinks that there is no paper tray installed
May 08, 2009 | Panasonic Panafax UF-880 Plain Paper Laser...
Fax machine with error code. Panasonic UF-780. Error: "Check cassette info code = 011"
you broke the tab on the back of the paper cassette. if you look in where the cassette goes on the back left you will see a hole with a sensor that looks kinda like a upside down letter U . put paper inbetween the sensor and the machine should say out of paper and put the cassette back and you should be fine
Dec 29, 2008 | Panasonic Panafax UF-780 Plain Paper Laser...
Error 011
Where is the broken left tab. Sometimes on that cassette the tab breaks that tells the unit that the paper cassette is installed. If this is the case then the tray has to be replaced.
Nov 06, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
Panafax uf-790 - info code = 011
Check cassette refers to the paper cassette. If there is no paper or the cassette is not seated correctly, then you will get that error. If you tried those, then check the left rear of the cassette for a tab. If that tab is broken off you will get this error and you need a new paper cassette. Good luck.
Jun 14, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
Brothers intellifax 4100
cassette is in front, put hand on bottom front of machine and pull, check to see if it is set to letter ( is the paper adjuster the part that can slide back and forth set to letter is there a switch in the cassette for custom and letter size? is it set to letter?
Dec 06, 2007 | Panasonic Panafax UF-585 Plain Paper Laser...
Recording Paper Cassette
Error code 11 means that it does not see the cassette in the machine,. there is a tab on the back of the cassette that is broken . thats why your getting that code.
if you leave me a msg that you want to fix this i will contact you
Oct 09, 2007 | Panasonic Panafax UF-595 Plain Paper Laser...
Panasonic Panafax UF-585 Plain Paper Laser Fax Logo
149 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
