Question about Belkin Computers & Internet
Have a 1year old Belkin wireless router that has worked until a couple of weeks ago. Unable to connect to internet wirelessly and unable to secure it. Have spoken to several tech people and after extensive problem solving over the phone ,was told my router was defective and to go to www.belkin.com-returnns and order replacement on line. This www address as written is not valid. Model # f5d9230-4 and ver 3100 Please advise. jdavidson_3@charter.net
    Genius:
  • 1,269 Answers
I believe you need to call the netgear support again and ask if you can talk to their department with replacement concerns. Because if the online replacement order didn't work, your only option is to call their customer support number for manual process of replacement.
Hope that helps.
Posted on Jul 24, 2008
I am unable to connect to my internet with my wireless router. It was working fine a week ago. What should I do?
Hi you nedd to change your wireless configuration to 64bit wep manually.
WIRELESS SETTING UP A WIRELESS CONNECTION
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Oct 09, 2010 | Belkin (F5D8231-4) Wireless Router...
Am having difficulty connecting through modem I had the system working up until about two weeks ago. I was trying to access the wireless router with another computer and was prompted to enter the 8 digit...
Ur wireless router is not configured for the wireless lan.Don't worry here is the solution for the problem......
Open Internet Explorer. In it enter the ip address of the wireless router.. Enter the username and password Then go to wireless option and select the security type as wep and provide a network key that will be ur connecting password... That's all
Now when u r connecting to wireless select the network and provide the network key that u have given...
May 06, 2010 | Computers & Internet
I have recently bought a Belkin Wireless Router and I am unable to connect to the Internet on my laptop. What do I need to do to connect my laptop to the internet using the Belkin Wireless router?
your Internet modem or router needs to be connected to the Belkin router's WAN port with an ethernet cable. You'll then need to configure the belkin's wireless settings, it's usually a very easy "follow the prompts" kind of setup.
Oct 03, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin router stopped working properly thereis no wireless outpu
have you restarted the router? if so, then see if Belkin offers a firmware update. You will need to connect with a cable to do the update.
Jun 15, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
WRT54G, unable to install router
  • Since you have Internet connectivity through the router using a direct connection to the router, then you just need to access the router's setup page and re-configure wireless.
  • But first, check if the wireless light is on in the router.
  • Then, using a computer that is wired to the router, launch IE and type 192.168.1.1 on the address field.
  • It will then ask for the password. By default it is admin. Just click ok and it will lead you to the setup page of the router.
  • Then, on the menu click Wireless. Look for wireless network name or SSID. That is the name of your wireless network. By default it is set to "linksys". You may change it to a uniqune name and then save the settings.
  • Then, if you want to enable security in your Wireless network, click on Wireless Security.
  • Set security mode to WPA Personal and create your network key. It should be atleast 8 characters.
Hope this helps!
Dec 03, 2008 | Computers & Internet
Problem securing belkin wireless g plus router
you must enter the WEP key because if type in the pass-phrase it won't connect(don't know why)
Jul 02, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can't connect wirelessly to Belkin Router
have you customized the wireless settings of you router (e.g. ssid, wireless channel, wireless security)? if not, try to change your router's ssid or the wireless channel. it could be that some wireless devices are interfering with your signal.
hope this'll help you.
ciao!
Jun 20, 2008 | Belkin (F5D5231-4) Router
Wireless Router
Greetings...
Here are the steps to hopefully get you reconnected...
SymptomNot able to connect to the router/AP wirelessly, or intermittent wireless connection.
ResolutionTo address this issue, follow the steps below:
Note : The steps below are applicable only for Belkin routers.
  1. Open an Internet Explorer window on your computer and type in http://192.168.2.1 in the address bar. This will take you to the Belkin router's web based configuration page. If you are not able to open the page click here.
  2. You will get a login page. Leave the password blank. Click Submit .
  3. On the left side of the page, click Channel and SSID below Wireless .
  4. The wireless channel on the Belkin router is set to Auto by defualt. Change the wireless to a static channel. Click Apply Changes .
  5. Click Logout in the top right hand corner.
Note: The wireless card in the computer will automatically detect the change in channel number on the router and will update the channel on the card.
Have a great day...
Ed
May 28, 2008 | Belkin (F5D7230-4) Router (587009)
Unable to access router wirelessly
try to reset it (there's a small button on the back you have to push with a pin)
then connect to the router (the ip is the same as the gateway when typing ipconfig in the command prompt of your computer, as soon as you have connected to it) to change ssid's, weps and other important stuff
Dec 13, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
63 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
