Question about Toshiba e-Studio163 Copier
COPY IS NOT GOOD....
I have a e-studio 163 copy and after put new supplys(drum, blade, developer), reset the code,,,,,
the copy still opaque, very clear and is not good....
What happend?
betomendo@hotmail.com
    Problem Solver:
  • 8 Answers
Weast toner is not go properly.or paper jam in drum unit or paper dust clean in drum unit.
Posted on Jul 25, 2008
When want a copy ,it says ready to copy but won't. ?
Sir/Mam,
Have you had the developer and drum replaced recently, or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum or next to it depending on the series. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Apr 30, 2016 | Konica Minolta Bizhub C350 Digital Copier,...
My AR-163 copier is bringing out half copy, it will copy and leave the down part uncoppied, how do i solve that problem
Half copy is never an issue with the toner. If you leave the lid open and make a skyshot copy what does it look like, is the copy all black with a thin white border around it, and do you see the scanner light comming on all the way across? You will want to make sure that your developer is evenly distributed across the magnetic roller. Also try looking into the score tron and check the drum cleaning blade and drum.
Oct 11, 2014 | Sharp AR-163 All-In-One Laser Printer
When i try to photocopy it always shows c-6 400
try entering 1087 1087 then 163 then 01 to return to normal copy mode. This code can come up when machine loses power while turned on. this will reset the fuser which is probably causing the code.
Jul 16, 2014 | Kyocera Mita Drum Cleaning Blade Km 1620...
E studio 600 error cod f 105 how can reset
sir i have a toshbia estudio 600 the copy is coming light but i put the toner manually in the developer tank the copy is o.k. toner is full and the developer also new
Dec 01, 2013 | Toshiba E-STUDIO 650 Copier
MAINTANANCE M2 MINOLTA BIZHUB 163
Need to have the drum and developer and cleaning blade replaced, then have that M2 counter reset. Resetting the counter with out replacing the drum developer and cleaning blade will cause codes and image problems. Machine uses the counters to determine voltages for certain assy. If you clear the counter and not replace the parts the machine adjust voltages for the drum and developer assuming it new when in reality it is old.
Jan 31, 2013 | Minolta bizhub 180 Black and White Copier
My bizhub 600 is showing message warming up ready for next copy
Sir/Mam,
Mar 31, 2012 | Konica Minolta Bizhub 600 750 Image...
Where we can buy toshiba studio 230 developer?
677864645f7a396c54674d71464b78424b4677-100x100-0-0.jpg Toshiba E-STUDIO 163 202l Developer Black
New Genuine Original D2320 TOSHIBA E-STUDIO 163 202L DEVELOPER BLACK Each $88.21ExtraMileToner
at
GenuineBrandSupplies.com
New Genuine Original D-2320 TOSHIBA E-STUDIO 163 202L DEVELOPER BLACK Each $65.33
Oct 21, 2011 | Toshiba e-Studio163 Copier
Konica di620 ghosting and streaking
What about the starter/developer last time its been changed? Upper fuser/fixing roller (Hot rollers) don't forget to clear counters once those parts are installed.
Aug 05, 2009 | Sharp AL 1631 Copier
I have konica 7130 i got my error in the screen f-26-3
F26-3 at power up.
Solution:
CAUSE: The toner supply unit (p/n 26WA-3200) is bound up preventing toner from being added to the developer unit.
SOLUTION: Replace the toner supply unit.
Jun 04, 2009 | Office Equipment & Supplies
Toshiba e-studio161 Developer
Technical Service Procedure
Correct procedure for service of TOSHIBA e-Studio 161
When the spanner light and the developer (sun) light are illuminated it is time for a service.
* Try and run the PM Service and drum life counters together.
* Part that are required for a 50,000 copy service (OD 1620 DRUM, D1620 DEVELOPER, BL1620D DRUM BLADE)
* Clean and inspect drum unit.
* Clean all optics and glass.
* Clean and rewire transfer corona.
* Clean and check main charge needle electrode [saw tooth]
* Clean and check fuser units including blades, rollers and scraper fingers.
* Clean erase lamps and ozone filters.
* Clean and check all feed rollers.
* Clean machine inside and out.
* Replace the required parts.
* Reset mini maintenance counters:
* [CLEAR] > [EXPOSURE] > [CLEAR ]> [EXPOSURE] and the machine will die.
* Input [20] [START] [01] [START]“000””000” will flash on the display.
* Reset the drum life counter:
* Input [24] [START] [07] [START] "000"000" will flash on the display
* Reset developer life counter:
* Input [42] [START] [01] [START] “000””000” will flash on the display.
* Once all the part have been replaced and the counters been reset, check the copy quality.
* Notes: Application of the patting powder is for reducing the friction between the drum and cleaning blade. If the application of
patting powder is neglected, the drum and cleaning blade may be damaged. Please clean off the patting powder before putting the
cleaner unit into the machine.
Developing doctor gap adjustment
1) Loosen the developing doctor fixing screw A.
2) Insert a thickness gauge of 1.5mm to the three positions at 20mm and 130mm from the both ends of the developing
doctor as shown.
3) Push the developing doctor in the arrow direction, and tighten the developing doctor fixing screw. (Perform the same
procedure for the front and the rear frames.)
4) Check the clearance of the developing doctor. If it is within the specified range, then fix the doctor fixing screw with
screw lock.
* When inserting a thickness gauge, be careful not to scratch the developing doctor and the MG roller.
CHANGING A TRAY’S PAPER SIZE SETTING
Follow these steps to change a tray’s paper size setting.
* The paper size setting cannot be changed when the machine has stopped temporarily due to running out of
paper or a misfeed, or during interrupt copying.
* During printing (even in copy mode), the paper size setting cannot be changed.
* A5 (ST) size paper can only be selected in upper paper tray.
* Do not load paper that is a different size than the paper size setting. Copying will not be possible.
Hold down the [PAPER SIZE ENTER]
key for more than 5 seconds to
set the selected paper size.
The currently selected
paper feed location
indicator will blink and
the corresponding paper
size (which is currently
set) indicator will light
steadily. All other
indicators will go out.
If the machine has two paper trays,
use the [TRAY SELECT] key to
select the paper tray for which you
wish to change the paper size setting.
Each time the [TRAY
SELECT] key is
pressed, a paper tray will
be indicated with a
blinking paper feed
location indicator.
Use the [ORIGINAL SIZE ENTER] key
to select the paper size.
The indicator of the
selected paper size lights
up.
Apr 11, 2008 | Toshiba e-Studio 161 Copier Copier
Toshiba e-Studio163 Copier Logo
143 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
