Borthers Intellifax 2800
We cannot make a copy, nor can we send a fax - it always says "receiving" when we want to send. Can you help?
Try to unplug the machine and plug it back.
Posted on Jul 24, 2008
Line goes through page when fax is sent
Open up the document feeder and clean the small glass. If the line is more than 1/4 inch wide you have a bad scanner block.
May 13, 2010 | Brother IntelliFAX 2800 Laser Fax
When I send a fax from our Brother Intellifax 2800, the person receiving the fax gets the fax but half of the page is blacked out, what is the problem?
sounds like your cis (contact image sensor) which lights up and reads your original, is bad. that component is located under the keypad/control panel. if you make a copy, it should also be partially balck if that is the problem.
razors
Mar 25, 2009 | Brother IntelliFAX 2800 Laser Fax
I have a Brother Intellifax 2800 and it can send faxes but just rings and rings and won't receive them.
what does the display read. If you want the fax to auto answer. the display needs to read ( fax only). to chang this setting if not reading that massage press the receive mode button till fax only is in the display
Jan 30, 2009 | Brother IntelliFAX 2800 Laser Fax
Cannot receive fax on a Brother Intellifax 885MC
make sure your receive mode is set to "auto" or "fax only". if thats not it, you may have a phone line problem. i have seen that before.
hth,
razors
Jan 12, 2009 | Brother IntelliFAX 2800 Laser Fax
BROTHER FAX MACHINE 2800
Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
3. Press the MENU/SET key to confirm your choice.
4. Press the STOP/EXIT key to exit the menu.
NOTE: If you frequently print, copy, or fax, set the idle time long
enough to insure that you will not always have to wait for the Brother machine to warm up.
Dec 02, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother intelli fax 2800
It could be that your sending fax is sending paper not facing the scanner. In that case tell them to turn the paper over to send. Other than that, it could be that the telephone lines are so dirty that the fax protocl fails at the check frame signal. You will have to adjust the equalisation and line attenuation. Don't count on the telephone company to help you, they always want you to do everything 1st before they will admit to any fault on their part.
May 06, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother Intellifax 2800 Plain Paper "NO DOCUMENT"
no document mean that there is not paper in the paper feeding
Aug 29, 2007 | Brother IntelliFAX 2800 Laser Fax
23 people viewed this question
jasbo
jasbo
