Question about HP Pavilion zd8000 Notebook
Keyboard heats up to touch. shuts down frequently. I take out and reinsert battery
This happens even when plugged in. also plug keeps falling out of insertion slot just inherited this computer.
  • 2,028 Answers
This overheating problem is due to the bad connection with the power supply. Check the jack on the machine to see if it's cracked, broken, or loose. If it is, then you need to have it fixed imediately. A broken or loose jack can cause an electrical arch and do severe damage to the machine. If the jack is good check the supply. if the supply is worn out, loose, and not making a good connection it can do damage as well.
Posted on Jul 24, 2008
NEW HP Spectre 13T-3000, 13.3" Touch will not run with the battery and shuts down randomly
you can use the unit without the battery. Remove the battery, plug in the charger/power supply and turn on the unit and wait for the result. if the problem persist?..... maybe the fault is in CPU fan. check the fan...overheating the processor. Cleaning the heat sync and reapplying silicon compound on CPU's can cure the problem.
Sep 02, 2014 | Computers & Internet
I have a compaq presario c700em it keeps shutting down even when: The battery and charger are both plugged in The battery is plugged in by itself The charger is plugged in by itself
are you looking at youtube or a video at the time it shuts down, it might be a over heating problem and i would get the laptop cleaned out and see how you get on after that.
Oct 05, 2010 | Computers & Internet
My laptop turn off, I think it got hot, I can't turn it on now. turn off Sunday
try this,
unplug dc plug from laptop. remove battery.
wait a few minutes. press and hold the power button for 10-15 seconds.
plug the dc power plug back into the laptop, but do not put battery back in yet. Then try to power on. if it powers on, let it run a few minutes, but best to keep checking to see if it is getting warm or hot anywhere. if it is getting hot shut it down immediately. If it isnt getting hot then shut it down and put the battery back in.
if it doesnt power up, then i would have to suspect heat damage to the motherboard.
Feb 15, 2010 | Toshiba Satellite A135-S4527 Notebook
try this:
1. shut down your laptop
2. remove battery and unplug ac power
3. keep it that way for 2-3 minutes and then put the battery back in, plug the power cord and turn it on.
if you have no luck try doing a windows system restore and see if that helps. if not you should contact dell support or return for warranty.
Aug 19, 2009 | Fujitsu Computers & Internet
Compaq presario shut down while plugged in
Greetings my friend, regarding on your problem try to remove your battery then clean it and after you clean insert it back. then used the power connector and insert it in the DC plug and wait for 5 - 10 mins before you turn on your laptop. In that way the battery is already charging then try also to touch the battery of the laptop if it is charging or not by touching the battery and when it warms meaning it charge otherwise it is not charging. Then if your findings are true that your battery are not charging then try to test it with tester so that you check the status of your battery.
Jun 16, 2009 | HP Compaq Presario C306US Notebook
Laptop suddenly shut off and will not turn back on
Sometimes the voltage regulator in the battery hit a point where they fall below a certain efficiancy % they have to operate at. Once they fall below that % you must replace them, even if the battery is 100% charged. Its usually a good idea to pick up a new charger as well with a new battery since they are known to die as well. Make sure you check the socket in the back where your charger plugs into the laptop to make sure its not loose or cracked. Sometimes the plug will crack off the motherboard and not make good enough contact.. But regardless of that it should atleast turn on if the battery was charged and good. Best bet, new battery. Every 2 years you should get a new one.
Jun 04, 2009 | Toshiba Satellite M45-S269 Notebook
Won't turn on
I had the same issue, i removed the Battery and keyboard and reseated the RAM chip under the keyboard. MAKE SURE THE RAM CHIP SITS COMPLETELY DOWN AND NO DEVICE IS IN THE WAY. I reinserted the keyboard and battery and it worked fine
Dec 04, 2007 | Dell InspironTM 1501 Notebook
I cant get it to even turn on
remove battery and use it off A/C power adapter, mine only works this way, maybe shorted battery.
Jun 28, 2007 | iRiver PMC-120 Digital Media Player
Acer Aspire 9502WSMi Shuts Down When Upper Parts Are Pressed!
This sounds like a short of some kind from the motherboard touching either the body or some other peice of hardware, or you have a broken soldered joint on the board causing the problem. I would take to a qualified repairer.
Nov 24, 2006 | Acer Aspire 3000 Notebook
HP Pavilion zd8000 Notebook Logo
48 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
