Question about Uniden CLX485 Cordless Phone
Answering machine sounds like a fax machine??
I'm having issues with my answering machine...whenever you call the phone to leave a message, a horrible screeching noise answers in place of the answering machine message - sounding almost like a fax machine. The only way that I have been able to fix this problem is to call the phone...and during the fax machine like noise, press buttons on the phone that I'm making the call with (i.e. cell phone) and after about a minute it stops and you are able to leave a message. However...if you don't review the message and leave it as new on the machine, on the next incoming call the machine works and and you are able to hear our outgoing message and "leave a message after the beep"...??? We've had the phone company come out and test our lines and they are seems to be the phone that is the problem.
Called Uniden tech support and they were not able to provide any solution but to return it. We bought it a year ago and don't have the receipt and I'm sure the store we purchased it from would not accept any return after a years time.
Can anyone help!??
  • 2 more comments
  • jeb55 Aug 16, 2008
    I have the same problem with my Panasonic cordless phone...
  • dpantill Oct 13, 2008
    I have this problem with a GE phone
  • Anonymous Mar 25, 2009
    Exact same problem, I know it is not the answering machine because I have bought a new one and I have the same problem.
  • gatorbiker Mar 25, 2009
    I have the same problem on a different machine
SOURCE: Request help to retrieve message,then turn off answering function
You might try going to, scroll down to "customer service" and click there. a FAQ list comes up. #8 is remote access messages, maybe your other issue would be answered as well.
Posted on May 15, 2008
  • 594 Answers
SOURCE: answering macihne won't answer, disconnects after a few minutes
unplug your unit and allow it a few minutes to reset it's self. than call it using a cell phone and see if it does the same thing. If so check you menu option and make sure that the anserwing machine is not set up to only record for a certain period of time before disconnecting the call.
Posted on Aug 03, 2008
SOURCE: The phone will not ring
problemas con telefono uniden no conecta la linra telefonica
Posted on Oct 29, 2008
SOURCE: vtech w/answering maching does not allow outgoing calls or record
unplugging the unit from the power source and waiting 30seconds seems to be the answer. the answering machine is working and i can call out again.
thanks you to everyone who posted that answer in different parts of FixYa.
Posted on Jan 31, 2009
Vit Avaya BP
  • 211 Answers
SOURCE: Answering system and fax do not operate together
You want to change a timer on a fax machine to ring more times before it picks up.
Posted on Mar 25, 2009
>first run fax test, press set up go to tools menu then select run fax test,all entries should be pass
>then check your connections, do you have one line or number for your fax and phone?or a separate line or another number for fax and another number for phone?
>let me assume you only have one number for fax and phone..
>check connections, this should be downstream connection, the fax machine using the black phone cord provided by hp should be connected directly to the phone jack using line 1 at the back of the fax and the answering machine or the telephone should be connected to ext 2 or line 2 at the back of the fax...there should be no other devices phone or answering machine connected directly to the phone jack.
>next set rings to answer on the fax machine higher than the answering machine...if your rings to answer on answering machine is 4 rings, set the fax to 6 rings...if it is a voice call the answering machine will pick it up at 4 rings then if it detects that it it a fax tone then it will transfer the call to fax.
>also check if auto answer is on in your fax
>you can check auto answer and rings to answer by pressing set up or menu button on your machine look for it in basic fax settings or advance settings
>also check if your voice prompt for your answering machine is not too short there should be like at least 5 seconds after cutting your message to allow the machine to transfer the call to the fax if it is a fax tone.
Sep 14, 2009 | HP 1040 Plain Paper Inkjet Fax
How to you hook up an answering machine to a Samsung all in one printer
there should be two phone jacks in the back one says phone plug your answering machine into it
Aug 28, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Have a new all in one printer (print, fax, scan and copy) feature
Here's where a Panasonic TA-824 would work great. At a street price of about $200, you can control your 3 lines and up to 8 extensions, one of them being your fax machine that would have access from both lines, and an answering machine that could take messages.
Some of the fax machines can detect a fax tone on a phone line, so you could have the answering machine answer the call and you tell them to press send (or it listens for a CNG tone, but the fax machine is limited to only one line.
Apr 01, 2009 | Panasonic KX-TG2740 Cordless Phone
Mar 25, 2009 | Uniden Lands Phones
Can I use as phone/answering machine and fax
no, this machine does not have a message center. the only way is to hook an actual answering machine up to the "ext" jack on your fax. set fax to answer on 1-2 rings, and set your answering machine to answer on at least 4 rings, and set your fax receive mode to "tad" which means telephone answering device.
Feb 09, 2009 | Brother IntelliFAX 4100 Laser Fax
Problem with answering machine on Panasonic Model # KX-FPG376
i followed the advice posted & it worked fine after that. thanks.
Nov 22, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Answering machine does not work for second number on our line
Is there any chance that there is a fax machine or modem attached to this #?
Aug 08, 2008 | Uniden TRU8885 Digital Answering Machine
Fax & Phone sharing the same line
I am not really familiar with your machine, but have worked on faxes for 20 years. Most models are fax, fax/tel, and tel, meaning it is either or, or a combination. The function you seek was on many models with a built in answering machine. As the machine answered, you said in your message to press start now, or leave a message.
I would say, use your *9* solution with phone while you are there, but switch it to fax mode when you leave. Any regular call coming in at that time will not get answered anyway, but faxes would automatically be received. I know it is an extra step, but that would work.
Mar 08, 2008 | Samsung SCX 4521F All-In-One Laser Printer
HP 7410 fax tone when answering machine starts
you can only have it set to fax or phone at a time; the computer does not know if it is a fax or phone call. Therefore if you are running your fax software it will treat all calls as a fax. You really need two phone lines, one for the fax and one for the phone.
Dec 28, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Uniden CLX485 Cordless Phone Logo
1,284 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
