Hotpoint Ultima WMA66. It goes thru the wash cycle but doesn't drain to go on to rinse/spin. It continues to turn and when the timer run's out it just stop's and is still full of water. Any ideas??
  • 93 Answers
This must be a European model. If it wil not spin and water will not go out it has to be something stuck in the drain pump. You shoud have access through the bottom panel.If you have one remove it you should see drain pump.
Posted on Jul 24, 2008
Our hotpoint ultima wmd960 washing machine timer stops with one minute remaining, but continues the wash cycle on 'a loop', and does not pump the water from the drum. We turn it off and then put it...
Have a look at this and check if your pump is full of things lost from pockets:
How to remove and clean your Hotpoint washing machine pump filter
However, I suspect the problem is really that something is causing the controller to (falsely) register an unbalanced load, and continually running the wash to try and redistribute the items.
Sorry I'm not sure what the fix is for that - could be motor tacho, or could be controller itself.
Jan 30, 2018 | Hotpoint Washing Machines
I have a Hotpoint Ultima 1200 - WM75. At the end
Check the filter and the actual pump itself for blockage.unless you have already done so, also pump itself could be faulty.
Mar 29, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WF860 Cycle does not end
could b presure system blocked up find this on side of filter long plastic *****
Nov 29, 2009 | Hotpoint Ultima WF860 Front Load Washer
Will complete wash/rinse cycle, start spin and pump out but not speed up
put a full load in it, its telling you that, try 20 shirts, or 10 towels
May 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
Spin/drain cycle won't start
If the timer gets to the rinse cycle and stops,
Check the lid switch for continuity. If no continuity replace the lid switch.
If the timer continues through rinse and spin without doing either, replace the timer.
May 21, 2009 | Kenmore Washing Machines
My hotpoint ultima super silent displays 'test' but dnt run cycle
its in factory test mode, this can be set by pressing the on and start buttons together. to reset, turn on while pressing the on and start together until dOFF appears
Jan 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Goes through all cycles by will not drain or spin.
If the timer hangs at points in the wash cycle, and you can manually advance, then the timer continues to run or runs shortly before hanging again, then the timer is bad and needs to be replaced.
Jan 24, 2009 | Kenmore 24032\24036 Top Load Washer
Hotpoint ultima wma66
Sounds like the PCB is Freaking out. All you can do is Check all the connections between the Main board and Display board and if you still have the problem - then i'm afraid it is probably the Main Board gone Faulty.
Mar 14, 2008 | Washing Machines
Won,t drain on rinse cycle
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
