Question about Toshiba Computers & Internet
Question: Why isn't AHCI available toshiba A210-MS408C with XP and Vista Have loaded AHCI on INTEL desktop and mobile chisets many times. There seem to be great problem with ATI's SB600 chiset AHCI driver for Desktop, and virtual nothing for mobile computing devices. Why is that. AMD and ATI push there solution ans just as good as INTEL Stuff. The Laptop seem to lag because drive sub system is not running with AHCI drivers. Also some power management options are not available without AHCI or Raid drivers. Having AMD Athlon x64 does not impress me any more, because it slow. Also use VMware server, on same unit support VT technoloy, but very slow because not AHCI mode. Who is at fault , AMD/ATI or Toshiba. Would not recommend anything but INTEL chiset from know on. Been trying to find somewhare to send to AMD/ATI or toshiba to get some reponse, can't find any, so trying here Thank You
    Master:
  • 507 Answers
This sounds like a bois problem try reloading the defaults in the bois menu and reboot this should turn everything back to normal
Posted on Apr 27, 2014
  • 4 Answers
SOURCE: Acer Aspire M100 desktop computer device driver not installed
what operating system do you have there?? is it windows Xp or Windows VIsta?
Posted on Jan 17, 2008
SOURCE: Windows XP on Acer Aspire M1610
You must have Microsoft .NET Framework installed prior to installing the ATI driver.
Posted on Apr 23, 2008
Mark_Webber
  • 472 Answers
SOURCE: Desktop problem
This can be caused by almost any of the hardwarein your computer. It should be making a series of beeps, but you will not hear that unless your internal speaker is connected.
Try this in the following order and repost if you succeed or not.
  1. Check the memory is seated correctly. Relase the clips at each end, then press it back firmly into the slots until the clips fully engage. Give it a gentle wigglw side to side as well.
  2. If no response still, then remove the screw from the video card and do as above. Just make sure to do it gently when pressing it in. Use force, but not excessive.
  3. If there is still no repsonse, then do the same for all remaining cards that are plugged into the motherboard.
If you are getting a series of beeps, then please post those back as they have a reference to what the problem is. One beep is good and means the system should boot. Anything else is a motherboard error code.
Posted on May 06, 2008
pagebor
  • 2785 Answers
SOURCE: pci device driver issu intel d945gcnl desktop board
plz try by reloading the sound driver from *********** board cd,plz post your findings
Posted on Jun 13, 2008
  • 136 Answers
SOURCE: Multimedia Audio controller driver for an AMD Athlon xp 200+
Try here.
Posted on Mar 20, 2009
Can I use a Toshiba recovery disk for A210 series if I have an A505 series? They are both Windows Vista
That is about the only thing thew same about them other than the name Toshiba. The A505 is an Intel Processor, the A210 has an AMD processor. They have completely different video graphics chipsets, audio, and LAN configurations, Assuming that the A210 disc will load in the A505, you would not get proper video, audio or LAN drivers. Recovery disks are made for the machine they are bundled with. You can try, but don't be surprised if your result is less than optimal.
Jan 06, 2012 | Toshiba Satellite A505-S6034 Laptop...
I have toshiba satellite L505-S5990 model.i have installed windows xp by changing the settings in Bios that is sata hard disk enabled as compatable mode from AHCI.if i change to AHCI i can't install...
If you would like to make use of the SATA controller's AHCI features, you should enable this BIOS feature. But please note that enabling this feature requires you to load the SATA controller driver during the Windows XP installation routine.
If you do not intend to use the AHCI features, it's recommended that you disable this BIOS feature. This allows you to use the native Windows XP driver. You won't need to load the SATA controller driver during the Windows XP installation routine.
Read more: http://www.techmetica.com/howto/sata-ahci-mode-bios-setting.-what-does-it-do/#ixzz0y5ObAtN8
Aug 30, 2010 | Toshiba Computers & Internet
Could not make it work in AHCI mode
what kindda chipset your laptop is?
It's must obtained in your OEM site
Jan 20, 2009 | Acer Aspire 4530-5889 Notebook PC
Windows XP boots endless if SATA is set to AHCI
this is'nt so easy here an example solution:
Enabling SATA mode to AHCI after XP Install (applicable to most laptops, or systems) If you want to enable SATA mode as AHCI after installing Windows XP, then read on. It's a bit of a long read because of step-by-step instructions, but worth it.
I did this on on Acer Aspire 5315-2153, it seems like the basic strategy should work on other laptops or systems.
For whatever reason, you may have installed Windows XP on your new laptops with SATA Native Mode disabled in the BIOS. Once XP is installed, enabling it in the BIOS will result in a BSOD upon loading Windows because XP doesn't have the correct drivers.
I read that enabling SATA native mode will give you a slight performance inrease and slightly increased battery life, so it seems worthwhile to me smile.gif
Here's how I did it on a Acer Aspire 5315-2153 running Windows XP (32 Bit version):
- Download the Intel Matrix Storage Manager software from Intel (I think it's iata_enu.exe)or AHCI_Intel_v7.5.0.1017_XP.zip from Acer web site.
- Extract files from AHCI_Intel_v7.5.0.1017_XP.zip to e.g. C:\AHCI_Intel_v7_5_0_1017_XP files need: (you may delete the rest)
iaahci.cat
iaahci.inf
iastor.cat
iastor.inf
iastor.sys
TXTSSETUP.OEM
- Now go to Device Manager, under IDE ATA/ATAPI controllers you should
see: Intel 82801HEM/HBM SATA AHCI Storage Controller
- Right-Click on that and select Update Driver
- Say no to connecting to Windows Update to search, hit Next
- Select Install fro a list or specific location (Advanced), hit Next
- Select "Don't search. I will choose the driver to install", hit Next
- Select Have Disk
- Browse to C:\AHCI_Intel_v7_5_0_1017_XP and highlight the iastor.inf file, hit Open
- Select OK
- Now you should have a list of controllers, for the Acer 5315-2153 choose Intel 82801HEM/HBM SATA AHCI Storage Controller, hit Next
- You'll get warned that installing the device driver is not recommended, click Yes to continue installing
- Click Finish
- Click Yes to restart your computer
When your computer boots up, you need to hit F2 to enter the BIOS. Change SATA mode to AHCI, save changes and exit.
After you log into Windows, your computer will find the "new" hardware. Wait until you get the popup message to restart your computer, say Yes to restart one last time.
You may download also from Intel the RAID/AHCI Software - Intel® Matrix Storage Manager (iata70_enu.exe 5640KB) and install it in your system, it may fix in case you got the wrong Intel 82801 AHCI controller.
I give credit to Jamie Rybarczyk at HP Business Support Center forum for doing most of typing.
http://forum.notebookreview.com/showthread.php?t=186471
Jan 06, 2009 | Computers & Internet
How I do disable extended desktop
Windows vista :
Right click on your desktop > Personalize > Display Settings > Click on the second monitor icon (monitor picture with number 2 in it) > Clear the checkmark at "Extend the desktop onto this monitor" > OK
Windows XP :
Right click on your desktop > Properties > Display Settings > Click on the second monitor icon (monitor picture with number 2 in it) > Clear the checkmark at "Extend the desktop onto this monitor" > OK
That should fix it
Oct 30, 2008 | Computers & Internet
How to install XP on Toshiba Satellite L45-S7409
Hi
Ensure AHCI mode is turned off or set to Legacy/Compatible mode. If it says AHCI it will not boot XP
Aug 11, 2008 | Toshiba Satellite A100-S8111TD Notebook
TOSHIBA LAPTOP DRIVER
It looks like that there are so many brothers here with the similar problems as I. I bought the Toshiba Satellite A135-S2386 with Vista Home Basic on it. And, of course, I wiped out the Vista and installed the XP Home. Like most people, I had 6 unfound drivers at first. Thanks to the previous posts, I got video cards, wireless and SM bus working.smile.gif Now, I still can't get modem and two other unknown devices to work.frown.gif Can anyone help me this?biggrin.gif My Drivers does not load From CD. Like Vidio Controller, Graphics etc.. Lindly Send me The Drivers so that I Can Up Load My Labtop Mode No. A 135- S2386. Toshiba Satellite Doul-Core Inside Please Help & Mail me the Drivers Thanks....
Dec 07, 2007 | Computers & Internet
How to install XP in toshiba Satellite L45-S7423 laptop
i have 3-4 kind of xp wireless drivers for toshiba L45-S7423 but it doesn't recognize the driver...the driver is RTL8187B...i have to try with original cd...even if it is 4 vista...maybe it will work 4 xp....couse with this xp drivers no chance :D
Nov 14, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
148 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
