Question about Acer Aspire 5500 5570-2609 Laptop
Not booting up
For some reason I am not able to boot up my laptop to. it tells me no operations system can be found.......I purchased this laptop from Best Buy and I was not given a back up to the vista operation system
    Genius:
  • 2,028 Answers
Many times this error message indicates a hard drive failure. You will need an operating system disc in order to fix this or determine if the hard drive has failed. There is no other way around it unless you want to take it to a shop for repair. I wouldn't recommend Bestbuy, their very expensive. At Bestbuy you're looking at around $200 just for the system reload, this doesn't include a new hard drive if it has failed. If you decide to do this yourself, again, you will need an operating system disc, then do a system repair. If the repair doesn't take, then reformat the hard drive and install a fresh operating system. If you have any problems during or after the format or reload, then the hard drive has failed and will need replaced.
Posted on Jul 24, 2008
Error '1962: No Operating system found. Press F1 to repeat boot sequence'
What is the size of the download OS, which is giving error '1962' while installing?
This is error code for faulty or incomplete OS.
Jan 18, 2014 | Microsoft Windows XP Professional
Operating system not found in mini loptop samsung because accident i ereased the boot in drive c... i can't boot it with usb
you will need a new Windows cd with a program to boot up the system again for the manufactures do not give you one when purchased.
Jul 04, 2011 | Samsung X15 Notebook
Operating system is not found. How can I repair this? And the F4 does not work. The laptop is an NC10 mini laptop. Could you please help
Obtain an Operating System disk. Most people use Windows which can be purchased from any online retailer, or you could download ubuntu for free and burn it to a disc. Insert the disc into the tray, and when you boot the machine, go to the boot menu. (usually involves pressing F12 or esc when the BIOS posts). Boot from the disc that you burned and follow the installation steps.
Jul 03, 2011 | Computers & Internet
When booting the laptop it says PXE-E61: media
When you start your computer, the motherboard searches connected drives for the operating system. The search order is usually the optical (CD/DVD) drive first, possibly a USB drive next, then the hard drive. If none of these work, some systems are set to try booting the operating system over a network cable. What the cryptic message you're getting is telling you is that the system tried a network boot without success, and that maybe the trouble is a bad cable.
This all means that your hard drive isn't being detected, or that there's no longer an operating system on it. It's possible the connector from the hard drive to the motherboard has come loose, which can sometimes happen since laptops get moved around. The hard drive may have gone bad, or there may be a problem with the motherboard that is causing it not to find the hard drive. Or the hardware may all be fine, but something (a virus or other malware, for instance) has deleted files needed to load Windows.
When the computer first starts, you'll see a message about how to enter BIOS setup. The BIOS is the motherboard's built-in program, and through the setup pages you can see what devices it detects. This will let you know if the hard drive is being found. Some boards include diagnostic tests you can run on the hard drive if problems are found. You can also check the boot order; you may find that for some reason the boot order has been changed so that the network boot is being tried first. Strange things can happen to BIOS settings, often a sign that the backup battery for the memory where the settings are stored is getting weak.
If you have access to a Windows XP operating system CD, you can set the BIOS to boot from the CD drive and try using the Recovery Console feature. Information about this can be found at Microsoft's site.
Good luck getting your laptop back up and running quickly. Thanks for using Fixya!
May 29, 2011 | Acer Computers & Internet
Hi Im having a problem booting, it appears on my screen PXE-E61: Media Test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating System not found. How can i fix this one without a...
it's trying to boot up from the network instead of from your harddrive. It could mean that it's unable to find your harddrive. One thing to check is the BIOS settings for the boot option - make sure the harddrive boots BEFORE it tries to boot from network.
Once you turn on your laptop it will tell you what to press to get in to the bios to change these options (could be either F1, F2, F10, DEL or maybe even something else) Once in the BIOS look for BOOT OPTIONS
May 04, 2011 | Toshiba Computers & Internet
When i boot up its telling me no operating system. Is there a recovery file i can download to fix the problem.thanks
You need to access the bios to see if the hard drive has been recognized by the laptop.
Press either F1 or F2 to access the bios.
If the hard drive is not listed on the general page then this is the reason that it says no operating system found.
If it is there then chances are you have had a Win32 virus on the computer which has wiped the boot files.
This means that you willhave to use your recovery disk to recover the operating system.
Regards.
Jul 03, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
On my Lenovo ThinkPad Windows 7 laptop, I have got "Operating System not found" error, to fix problem,Windows Boot Genius helped me finally!
May 20, 2010 | IBM ThinkPad R30 2656 Notebook
Dell mini inspiron 9 - operating system not found
On my Dell Insprion Windows 7, I have got "operating system not found" error, to fix problem, Windows Boot Genius helped me finally!
Oct 14, 2009 | Dell Inspiron Mini 9 Notebook
Acer TravelMate 4200 Laptop
there are two posibility,
your hdd don't have operating system
or your hdd isnot detected.
check in bios, check if your hdd is there.
Jul 31, 2008 | Acer Aspire 5500 5570-2609 Laptop
On my Windows 7 laptop, I have got "Operating System not found" error. to fix problem, Windows Boot Genius helped me finally!
Mar 15, 2008 | Gateway M305CRV Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
93 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
