Question about Whirlpool Washing Machines
Ive replaced the motherboard but still get Error 11.
  • 93 Answers
Need model and serial number please.
Posted on Jul 24, 2008
Biostar motherboard led error a5
i think its the video card make sure that your power supply is big enought to work for everything that you are using as well ok.
Oct 04, 2013 | Biostar Computers & Internet
The PC does not start.Only it beeps and a red light blinks,also fen is not working.
here are some of the basic codes, depending on which BIOS you have...
Also you do not indicate which fan? I would guess you mean the main Power Supply (PS)? In which case it could just be you need to replace the PS.
Here is a link to some other codes as well...
http://www.computerhope.com/beep.htm
AMI BIOS ERROR BEEP CODES
  • 1 Beep - Memory Refresh Failure (check memory)
  • 2 Beeps - Memory Parity Error in first 64KB block (check memory)
  • 3 Beeps - Memory Read/Write Error in first 64KB block (check memory)
  • 4 Beeps - Motherboard timer not functioning (possible motherboard replacement)
  • 5 Beeps - Processor Error (may need replacement Processor)
  • 6 Beeps - Gate A20/keyboard controller failure (possible motherboard replacement)
  • 7 Beeps - Processor Exception Interrupt Error (may need replacement Processor)
  • 8 Beeps - Display Memory Read/Write Failure (reseat or replace video card)
  • 9 Beeps - ROM checksum Error (replace BIOS chip or motherboard)
  • 10 Beeps - CMOS shutdown Read/Write error (possible motherboard replacement)
  • 11 Beeps - Bad Cache Memory - test failed (replace cache memory)
Phoenix BIOS ERROR BEEP CODES
Phoenix BIOS beep codes are a series of beeps separated by a pause, for example:
beep --- beep beep --- beep --- beep beep would be 1-2-1-2
  • 1-1-4-1 - Cache Error (level 2)
  • 1-2-2-3 - BIOS ROM Checksum
  • 1-3-1-1 - DRAM Refresh Test
  • 1-3-1-3 - Keyboard controller test
  • 1-3-4-1 - RAM Failure on address line xxxx (check memory)
  • 1-3-4-3 - RAM Failure on data bits xxxx of low byte of memory bus
  • 1-4-1-1 - RAM Failure on data bits xxxx of high byte of memory bus
  • 2-1-2-3 - ROM copyright notice
  • 2-2-3-1 - Test for unexpected interrupts
I hope this helps.
Mar 29, 2011 | HP Computers & Internet
Uncaught exception 11>=11 bb
my phone went dead last night went i was in bed and when ive woke up this mornin ive put it on charge and the screen was white and said app error 523 reset so i reset it and it says uncaught exception:11 >11 and then went i press ok it just goes straight back to app error 523 .... and i need my phone :( how can i fix it without sending it off and paying for it?
Nov 30, 2010 | RIM BlackBerry Storm 9530 Smartphone
My board does not turn on and its beeping. Ive counted 7 beeps. i tried replacing the memory with known good ones but still the beeping persist.
MSI states that 7 beeps means "Virtual mode exception error "
Explanation: Virtual mode is one of the different modes that the processor can run in. The system is reporting an error when testing this mode.
Diagnosis: There is a problem related to the processor or motherboard. Note that this doesn't mean that the processor is necessarily dead, since the system won't boot at all with a dead processor.
Not knowing the price of either your processor or the board it is hard to say what to do for the best
Good luck
AMI Beep Code Deep Code Description 1 short DRAMS refresh failure 2 short Parity circuit failure 3 short Base 64k RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed AWARD Beep Code Deep Code Description 1 Long, 2 Short A video error has occurred and the BIOS cannot intialize the video screen to display any additional information
Jun 19, 2010 | MSI K9N6PGM2-V Motherboard
3 beeps when i boot my pc with ram but no beeps when i boot without ram
Here is the info I found on the Asrock website. This would be a normal code if you have no RAM in the system.
Beep Code Descriptions 1 short Memory refresh timer error. 2 short Parity error. 3 short Main memory read / write test error. 4 short System timer failure. 5 short Process error. 6 short Keyboard controller BAT test error. 7 short General exception error. 8 short Display memory error. 9 short ROM BIOS checksum error. 10 short CMOS shutdown Read/Write error. 11 short Cache Memory bad.
Apr 14, 2010 | Asrock K7S41GX Motherboard
Infinity car stereo/ CD changer Error 30
Must be Bose system. Sorry but they were all doomed from the start. Ive replaced too many to count.
Mar 19, 2009 | Intel D101GGC Motherboard
Hi!!! I NEED TO GET THE intel ima adpcm 11 codec BUT I COULDN'T FIND IT COULD YOU PLEASE HELP???'
THE BOARD NEEDS TO BE REPLACE
GO TO INTERNET EXPLORER AND IN THE ADDRESS BAR TYPE THE FOLLOWING INFORMATION.
INTEL MOTHERBOARD CODE ERROR 11
ENTER
ROD
Jan 25, 2009 | Intel Motherboard
Acer aspire laptop wont boot
y dont u dispose it off if it is a problem computer, i guess it is a generic problem of laptop need to replace motherboard or so. avail warrent if it has...
Nov 25, 2008 | Acer Aspire 5100-5033 Notebook
CMOS Settings is Wrong! USB Device over Current Status Detected!
It would seem that you posted twice, pls see you other post.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | ASUS P5PE-VM Motherboard
Washing Machines Logo
24 people viewed this question
Dan Webster
Dan Webster
Sal De
