Question about HP PSC 2410 All-In-One InkJet Printer
Printer turns off by itself
Printer makes a strang sounds then turn itself off
You need a new printer, its not worth getting it fixed, is it still under warranty?
Posted on Jul 24, 2008
I turn it off and it turns right back on by itself
Very strange... it sounds like you're getting the glitch with the remote start feature. If you have a PSP and you use it with your PS3 that could cause it at times, and there is a glitch with the remote start feature that can make it randomly turn on. Try disabling remote start, and of course you could always just use the power switch in the back of your console when you turn it off also, that's what I do whenever I turn it off.
Apr 06, 2011 | Sony Playstation 3 (PS3) Console
My 2001 eclipse makes a strange roaring sound and wont turn over when i try to start?????
If I had to guess, I would say that the starter is not engaging the engine. When you turn the key to start, it energizes the starter and a solenoid that "pulls" the starter gear into the flywheel gear to turn the engine ovr. I suspect the roar is the starter motor turning and not engaging. You need to replace the solenoid, on some cars it is part of the starter and not available by itself.
Jan 25, 2011 | 1992 Mitsubishi Eclipse
The power light is not coming on but printer is making noises when plugged in.
Not sure if it's the same problem as yours or not..... Even when the printer is turned off, it will make a noise about once an hour or so. It sounds like the print heads 'un-park' then park themselves again. Strange......
Sep 25, 2010 | Lexmark X5470 All-In-One InkJet Printer
My Printer wont print or scan!! It makes strange sounds when it turns on and off. Please help!!
Try to check and observe plastic gear may some of them broke or worn-out, of course scanning not work if error indicated on the machine. This occurs mostly on all in one printer scanner machine.
Mar 21, 2010 | Office Equipment & Supplies
Our samsung le40r87bd is making a strange clicking noise wont come on can u help its about 3yrs old and has not given us any trouble before this!
The clicking sound is coming from the regulator in the power supply. It is trying to turn itself on, notices that the voltages are not correct and turns itself off to protect the rest of the TV and repeats. You need to replace the power supply.
Oct 09, 2009 | Televison & Video
2004 S4 Strange Sound
Sounds like the noise is coming from the rack itself (commonish fault)
Feb 12, 2009 | 2004 Audi S4
Power head has power but motor won't run
Circuit brealer switch may be bad, but the fact that Rainbow nozzle made this strange sound makes me think that it may have happened because there is something wrong with the motor.
While unplugged - remove the brush and belt. Try turning brush ends - see if they yurn easily... Try turning the motor shaft - see if it turns and if it does - if it turns smoothly and if makes any strange sounds...
To really test the motor you can just bypass the circuit breaker switch.
Dec 09, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Epson C64 Printer
It sounds like the print head is jamming on the parking mechanism (usually because the actuation lever is stuck in the up position). Turn the printer on, and as soon as the print head moves, pull the power cord out of the back, or switch it off at the mains. You should now be able to move the print head over to the left by hand out of the way. Now look in the "parking bay" at the right end where the print head parks itself and see if there is a plastic arm sticking up. If there is, gently pull it towards you and it should spring down. Now turn the printer back on and it should operate normally. If it happens again, repeat the process a few times to see if it clears the problem. Otherwise it means the parking mechanism is gummed up with dried ink and needs a good clean (see below).
Alternatively, if you see that the whole parking mechanism itself has moved up to block the way, this means a spring has come off. To get this back on again requires the printer to be dismantled - as does the cleaning job above!
Should you decide to have a go at cleaning or re-fixing the spring, let me know via a new posted comment so I can provide further assistance.
Nov 09, 2008 | Epson Stylus® C64 InkJet Printer
Tv turns on then turns off with no picture
What make and model set do you have?
Feb 14, 2008 | Televison & Video
HP PSC 2410 All-In-One InkJet Printer Logo
144 people viewed this question
Ben Johnson
