Question about Sharp SF 2020 Copier
Sharp Copier 2025 error steady CH
Error code is steady CH. How do I reset the copier?
  • 81 Answers
I believe that that error code relates to the dorter. Make sure it is seated correctly against the copier.
Posted on Jul 24, 2008
My sharp ar-5316e error code CH please help me
Hope you are fine, ch are in two forms steady one and the blinking ch.
Steady CH
This is associated with door switch for either front cover or side cover. Check that the front cover of the copier and the right side is well closed.
Blinking CH
This is associated with the toner cartridge or the developer unit not being sensed by the machine. Make sure that the developer unit is well locked in the machine. Pull out the toner cartridge and insert back with some force into the machine, it should clear this sign. If it does not, replace a new cartridge Sharp Ar016ft and you are done. Good luck.
Nov 23, 2010 | Sharp AR-5316 Advanced Digital Imager...
Error code CH on sharp sf-2027
Hi olixrules
CH light blinking - The DV tank is not installed.
CH light steady - Door switch is not turned on (interlock switch is ON).
Source here.
Hope this gives you some idea, unfortunately I'm not sure how to resolve these error on this particular copier.
Scott
Feb 01, 2010 | Sharp AL-1642CS Copier
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Our Sharp AR-N275 copier is displaying error code "CH" (steady, not blinking). What does it mean?
Hello sir; CH it means somewhere the door is open, check it out all the door inside and outside.
Sep 30, 2009 | Sharp AR-N275 Copier
Sharp copier SF-2025 displays an error code U%.
Hello sir; It can be reset by power on and open the front door, press and hold exposure key while you closing front door.
Sep 29, 2009 | Sharp SF 2020 Copier
Sharp ar 250 copier error code CH
CH - open cover in the paper feed area
CH blinking - Dev unit is not properly installed
For the 'CH' check the covers and make sure all covers are closed properly.
For the 'Blinking CH' take the dev. Unit open and the reinstall unit properly.
Pls rate – thank you
Mar 03, 2009 | Sharp AL-1641CS Laser Digital Copier
Sharp AR-160 has an error code CH when you power it on
Actually that means your out of ink. Odd code, but that is what is means.
Jan 29, 2009 | Sharp AR-160 Copier
Toner error message on copy machine
Is "CH" steady or flashing? If it's steady, the door is not shut properly.
If it's flashing, the machine doesn't detect the presence of the toner cartridge (defective toner cartridge). Try another toner cartridge (an empty cartridge will do).
To get the blue handle to stay locked sometimes takes fiddling with it when the cartridge is in.
Dec 07, 2008 | Sharp AL 800 Copier
382 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
